Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer dries very slow - Maytag Atlantis MDE7400AY Electric Dryer
  • Maytag Master
  • 43,501 Answers
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Nov 07, 2010
Dryer drying very slow seems hot. any way to clean out to improve dry time
heatman101
Jul 09, 2011 | Whirlpool GEW9250 Electric Dryer
Dryer heats but is slow to dry. Have to set it at least three times before completely dries clothing
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Sep 02, 2010 | Roper REX4634KQ Electric Dryer
Slow dryer
If your dryer IS still heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 28, 2010 | Kenmore 63942 Dryer
Dryer gets hot close wont dry cleaned vent as well
how long is the vent run,anything over 15 feet will slow drying process
Mar 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Brand new samsung dryer not drying fast enough took 2hours to dry and still damp. the dryer was on more dry, high heat,
try checking your vent exhaust
and vent tube
soometimes airflow is slowed by clogs and build up causing long dry times
Oct 14, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
There is heat, but drying takes two cycles
Clean out your dryer vent. Many times the lint and other stuff plugs up the vent and slows the dry time down dramatically.
Aug 05, 2009 | Whirlpool WGD5300S Dryer
Dryer does not heat
check the heater and fuses.
Jun 28, 2009 | Roper RGX4634KQ Gas Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
If you have'nt done it yet, my first suggestion would be to have the vent on the dryer (inside the dryer all the way to the fan chamber) and the dryer vent pipe to the outside thoroughly cleaned.
That is leading cause for dryers not drying completely.
Also, has the dryer always been a bit slow to dry cloths? If so, try leaving a window open the next time and see if it makes a difference. Some houses are sealed so tight, the dryer can't get enough air. A typical dryer will use up to 200 cu/ft of air per minute when drying. If there is not sufficient air, the cloths take longer to dry.
Good luck, let me know.
Regards,
May 12, 2009 | Maytag PYG2300A Gas Dryer
My kenmore 70 series dryer will not dry clothes, but it does heat up inside and lets hot air out the dryer vent on the outside of the house.
make sure the dryer vent and the house vent are not clogged with lint this will slow down the drying process-mike
Mar 14, 2009 | Kenmore 62802 Electric Dryer
Dryer slow to dry
Take the vent off the back of the dryer and dry a load unvented too make sure you don't have an obstruction in the line too the outside. If still takes too long too dry you might have a bad operating thermostat located on the blower housing it is a 4 terminal thermostat.
Jul 25, 2008 | Whirlpool Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
74 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
