Question about Intel D101GGC Motherboard
Hi... i'm using DG31PR intel motherboard. for the past few months am getting these errors while booting... CMOS CHECKSUM ERROR CMOS BATTERY FAILURE i've replaced many new CMOS batteries.. but still not working... what to do now? do i have replace any parts in motherboard or i've to buy a new one? please help me... :-(
    Champion:
  • 331 Answers
I would reset the CMOS. This is done by removing that CMOS battery. Also, find the jumper that says "J-21" and move it to the alternative position. The jumper is located on the motherboard. Boot up without that battery in , and choose "Reset" that should clear out the junk. Also, replace the battery. Go to www.intel.com and look for a "bios update" the DG is a value board. a huge value board and one of Intel's bummer boards. Update the firmware. Once you do that, you should be good to go.
Posted on Nov 07, 2010
Cmos checksum error
You just need to replace the button CMOS Battery CR2032.
Reboot. Press F2 and enter the correct date and time.
Jul 10, 2014 | Intel Computers & Internet
Intel 101ggc comos checksum error
you can change BIOS battery this may be due to the fact that the battery powering the CMOS (when the computer is shut down it allows the CMOS to store information), is depleted.The CMOS battery is a small pin found on the motherboard; you can refer to the manual provided with your motherboard to change it.
Jun 15, 2012 | Intel S5000PSL - MOTHERBOARD - SSI EEB 3.6...
CMOS load error
Hi j5recs ,
  1. If this error says cmos checksum error defaults loaded , then you can try pressing and f1 key and it should load your system.
  2. If you get this error repeatedly , it means that the battery on your motherboard needs to be replaced.
  3. This could be as a result of CMOS crash, all you need to do , is to get the motherboard to an authorized service center for Intel so that they will load the CMOS for you once again and your motherboard should work fine, if *********** board is under warranty you can even get a replacement for this one.Hope this helps.
Hope this helps.
May 12, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
:CMOS Checksum Bad error Hi, My system had intel c2d 2.13ghz processor and 2gb ddr2 ram to begin with. I recently added 2gb more (both are 667 mhz). Now i'm getting an error while booting which says CMOS...
Yes--most probably a memory error.
If you added memory and kept the original memory, they might not be compatible.
Try running with only the old memory.
Then try running with only the new memory.
Bet both work. But not together.
Dec 20, 2009 | ASUS P5B Deluxe/WiFi-AP Motherboard
Ref GA-81PE1000L Error message on boot up
all the computer bios settings are stored even when the computer is off (like time and fsb)
these are stored due to the help of a cmos battery
when this battery finishes it gives the CMOS Checksum error Default loaded error
all you need to do is replace the cmos cell
it is a mercury cell (looks like a silver coin) and will be placed on your motherboard
it is very very cheap so go buy one and replace it and be happy
Sep 30, 2009 | Intel Motherboard
I want to locate jumper pin to clear bios because its showing cmos checksum error and i am unable to use keyboard to enter booting also cn anyone help...am using intel 810,p3 processor
You can take out cmos battery for 5 minutes or 10 and CMOS will automatically discharges. You havent specify motherboard name to give exact instructions but what i say works for 95% of motherboard.
Aug 04, 2009 | ASUS Intel 810 Chipset CUW-FX Motherboard
Boots to 'CMOSS checksum error'
CMOS checksum errors
Explanation: A checksum is computed as an error-detecting code, to protect the BIOSsettings stored in the CMOS memory.Each time the system is booted this number is recomputed and checked against the storedvalue. If they do not match, an error message is generated to tell you that the CMOSmemory contents may have been corrupted and therefore some settings may be wrong. BIOSesreact in different ways to encountering this sort of error. Some will warn the user andthen continue on with whatever settings were in the CMOS. Others will assume that thesettings that were in the CMOS were corrupted and will load default values stored in theBIOS chip "for safety reasons". The error message will indicate which yoursystem is doing.
Diagnosis: The most common cause of checksum errors in CMOS is a battery that islosing power. Viruses can also affect CMOS settings, and motherboard problems can alsoaffect the stored values.
You should make sure that all of theBIOS settings in the system are correct, by rebooting the system, going into BIOS setupand double-checking all the values (hopefully against a recent BIOS settings backup).
If you have created a backupcopy of your CMOS settings then use them to restore the settings to the correctvalues. To find the problem itself:
Apr 06, 2009 | Intel Motherboard
Checksum error
Hi robynonis
Yes, definatly the cmos battery. Please make sure you replace with same type battery.
Regards Go-Tech
Dec 22, 2008 | ASUS P4PE Motherboard
Intel 102ggc:The Firmware has detected that Cmos Checksum Error
if you have vista you could do a memory check in the boot options by resarting computer and key f10 boot options, then find memory check witch will display any errors with soloutions.
Dec 12, 2008 | Intel D102GGC2 Motherboard
CMOS Error
Are the CMOS batteries good?
Oct 15, 2008 | Biostar P4M80-M4 Motherboard
Intel D101GGC Motherboard Logo
414 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
