RCA DHG 535-2 Cable/telephone modem installed by Comcast. It is beeping about every 10 seconds. All front light are solid green except "link" which is flashing. How can I stop the beeping?
    Scholar:
  • 33 Answers
Have you contacted Comcast about this?
Since they installed it, it is more than likey their equipment. Give them a call on their support line. Their support people will be able to remote in and check that box.
Posted on Nov 07, 2010
I have a Netgear WNR2000 v4 router. We recently had a power outage.Power came back on in 5 seconds.The cable modem is fine,however the router ONLY shows me a solid green light for power, nothing else.
I would just do the reset, this should allow you to access at factory defaults. (I hold button in for 10 sec).
A solid green (power?) light is good
LAN ports should only light if connected
WiFi port should light if set to active
Mar 02, 2015 | NetGear Computers & Internet
I have a RCa broadband modem from Comcast. I want to connect my computer Fax card to it. IS that ok? How do I do it? Just connecthe telephone cable from the port at the back of the computer to the RCA...
Yes it is perfectly OK. Remember that a fax essentially works as a phone, so you would run a line from the RCA modem to your fax card, then from the fax card to your telephone. In this scenario you would have to accept your faxes manually though.
Mar 16, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
The modem is blinking for PC link and cable activity and is steady on cable link and internet on, yet I cannot get it to access the web. The comcast guy left without leaving the disk. Is it possible it...
You're paying monthly fees to COMCAST, correct?
So, telephone them, and get their "technical support" department to help you get it working.
Threaten to switch to some other Internet Service Provider.
Mar 06, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Comcast is my service provider and I have had an RCA DCM 245R modem for almost 10 years. Until recently it has worked fine. On an ever increasing basis I am losing internet connection and when I look at...
It can be an issue with the modem or with the line. When the line drops the link then the modem shows only two lights. And, when you power cycle the modem (unplug and replug it) it establish the session again with the comcast.
So, i'll suggest you to get the line checked first and if comcast finds that line is working fine then get the modem replaced.
Rashish
Aug 15, 2010 | Thomson RCA DCM245R Modem
I have a RCA Thomson DHG 535-2 without the disk for the installation and the ethernet wont help everything is hooked up etherent/cable to tv power yes... and that's about ti all im really missing is the...
Thomson Cable modem has an ethernet connection...
The ethernet connection goes to your computer via a standard Cat5e patch cable. There is no USB that I know of...
Cablevision wire goes to the modem. It should be the first device on the cablevision wire. If you need a splitter, it needs to be a GOOD one, connected DIRECTLY to the incoming Cablevision wire as it enters the house. Use good copper wire.
Order of events:
Connect the cablevision wire to the Modem.
Connect the Ethernet cable to the computer and the modem.
Power on the cable modem.
Right click the network Icon near the clock and click 'repair' (Or reboot the computer)
Apply for and get an account for cable Internet from your Cable company.
After a few days, cable Internet should work.
Apr 16, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
When connect the power I get all solid lights except for the Internet light. Reset does nothing. I got the Modem on Ebay from a past Comcast user. Any ideas? Is it a goner? Thanks... Darryl From Portland...
You have to notify comcast, to let them know you bought a new modem. Comcast uses a two way communications to all of there devices, and it is not setup on your new modem.
Dec 06, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Comcast internet
Yes you can get the internet with that modem but only through a cable connection.
Here is the specs on that particular model for your information >>>>>>>>>>
http://www.newwavecom.com/phone/pdfs/DS_DHG535_200802.pdf
Regards.
Jul 20, 2009 | Thomson RCA DCM245R Modem
Thomson rca cable modem dhg 535-2
Here is the usb driver it is directly from the disc for the Thompson 535-2 cable/voice modem. I know this is not on the internet anywhere so please share.
http://rapidshare.com/files/303844631/RCAThompson535usbdriver.rar.html
Jun 24, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
1st time installation: cannot install modem properly
Hey try this one, if doesn't work let me know. First you have to powercyle your modem - meaning turn it off for 10 to 25 seconds then power it up again. Then check status of the modem lights. It should all be in solid green. Else you have to check if cables are properly connected - Data cable (green cable) one end connected to the filter with labeled "DSL/PHN" or the one with monitor engraved, then other end connected to the green port on the back of your modem. Then check also connection of filter to walljack. After which check status of the lights. If still not all in solid green. Check devices near to your modem, these might be the reason for interference of DSL signal. Electronic such as monitors, speakers... must be 2-3 feet away from your modem. Check modem lights. If all in green, test connection. Also there should only be one phone jack connected to your DSL phone line.
Jan 14, 2009 | AT&T High Speed DSL Modem
I have an Arris modem TM502g. internet and cable TV are working fine but I have no phone service. all the LED lights are blinking except for the 2 telephone lights and they are solid green.I have tried...
Hi sorry about the chat session the other day, i was not able to see your chat message so I end the session, but to help you with your concern, since internet is already working, then the problem here is the VoIP settings on your modem (since you said it has phone ports on the modem), usually resetting the modem wont change the VoIP (Voice over IP) settings. It would be better if you ask you VoIP provider to check if the modem's VoIP settings is setup correctly. If yes, and you have internet with the modem then upgrading the firmware may help.
If you dont have a VoIP provider then you need to get one in order for the phone line to work.
If you already have one, then contact them so they can configure the VoIP settings on that modem.Get your money's worth with their service
Sep 20, 2008 | Computers & Internet
Computers & Internet Logo
286 people viewed this question
David Payne
David Payne
