Question about Minolta Office Equipment & Supplies
Konica minolta opc drum magicolor 2350 printing problems I have replaced the opc drum on magicolor 2350 and also the black (k) ink cartridge and now can only really print in yellow, sometimes the other colours show when printing a solid (100%) but is not showing any gradients of each of the colours nor black, I have tried sending test page one from the printer menu and it only displays yellow.... please help!!!
  • 300 Answers
When you print stop the printer half way through then check the image on the opc drum and transfer belt to see if it's complete or not, also you may want to check the aidc sensor (sometimes the cable comes loose). I can e mail you the 2300 series service manual (4.17mb) if you reply with your e mail address
Posted on Jun 15, 2008
I have magicolor 2300 DL.I just replaced Cyan
make sure your cartridge is not stuck and pushed in all the way in printer. If it gets struck it will dump ink out and waste it.
Aug 19, 2009 | Konica Minolta magicolor 2300DL Laser...
Konica minolta 2530 dl Replaced black cartridge now says others not installed and "cannot rotate cartridges"
Clean toner chip reader, remove OPC drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it.
Jul 21, 2009 | Konica Minolta magicolor 2430 DL Laser...
After replacing black toner cartridge printer displays Drum Low
The drum and the black printer cartridge are two separate items. You will have to purchase a new drum for it. I just had to do the same thing and it ran me $150.00 at Staples.
May 19, 2009 | Konica Minolta magicolor 2430 DL Laser...
I've replaced all neccesary ink colors and now my 2530DL Konica Minolta wants me to replace my Drum Cartridge... I don't know what that is or how to do it!
Open the Front Cover and remove the OPC drum cartridge by pulling up from the green lever. I'm sure you'll find all these instructions on the box the new drum is comming.
May 14, 2009 | Konica Minolta Magicolor 2530 DL Laser...
To change opc drum in konica minolta
To Change OPC DRUM UNIT in KONICA MINOLTA 2300 w
Switch Printer Off
Open Front Door Cover
Remove Waste Toner Box
Lift Transfer Belts Blue Knob until it's placed at 11 o'clock. (it's directly behind the waste toner box)
The OPC DRUM UNIT is directly under the BLUE KNOB
SQUEEZE HANDLE and PULL OUT the OPC UNIT
Be VERY CAREFUL NOT TO SCRATCH THE GREEN COLOURED ROLLER on the OPC DRUM UNIT.
Replace new OPC DRUM and turn BLUE KNOB of TRANSFER BELT back to 7 o'clock position
Replace Waste Toner Box, Close Front Cover and Switch On.
Status Display will show OPC Drum at 100%
(You can also replace the fuse in the OPC DRUM UNIT and save yourself HUNDREDS on a new one)
I posted this on another solve problem previously, worth looking at.
Jan 06, 2009 | Minolta magicolor 2300W Laser Printer
Drum Cartridge Warning won't go away
Replace the fuse on the bottom of the drum cartridge.
Oct 03, 2008 | Konica Minolta magicolor 2430 DL Laser...
Magicolor 2430 DL vertical white blank stripes
remove PC drum and under that you can see laser glass, clean it and reinstall.
Aug 28, 2008 | Konica Minolta magicolor 2430 DL Laser...
Magicolour 2350
Try updating the drivers for the printer from the manufacturers web site. I doubt the issue is related to the printer itself, otherwise it would fail to print magenta all the time.
Jul 25, 2007 | Minolta magicolor 2350 Laser Printer
238 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
