Question about LG Heating & Cooling
Hi all: We have a LG HMC009KD1 split Air conditioner. At about the same time in the morning the AC fails and the external condensor freezes up. The outside temp is ususally about 5 Degrees Celcius. It has worked flawlessy for the last 5 years in much colder weather. We have had 2 different AC techs look at it and one recharged the Freon to no avail. Thanks
    Problem Solver:
  • 12 Answers
Internal breakage might causes this problem,tell ur present technician to charge nitrogen and test the leakage after rectification and compleate testing,tell him charge freon
Posted on Nov 09, 2010
I i`ve got a haier split type air conditionner model HSU12XCA on R22 gaz which barely cools and freezes after a while. The suction pressure is at 120 PSI and it is freezing on the liquide line. I`ve clean...
The unit has a leak and is low on freon...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Haier HSU12XCA Cooling Only Mini Split Air...
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as...
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Feb 02, 2011 | LG LSC121PMA Split System Air Conditioner
Have a LG Split Room AC Model LSN2665 DMO and its freezing from the inside what should we do?
Split a/c freezing. Reasons; Indoor coil and air filter blocked- clean it. 2.Less rpm of blower motor-Replace capacitor.3. short of gas-find leak,arrest and do gas charging.
Jan 04, 2011 | Heating & Cooling
Blover weal in my ac unit LG dosnt runing , during ac run in cooling mode, whot is problem ?
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 28, 2010 | LG LS-L1210CL Mini Split Air Conditioner
Ice fallingfrom split ac
Try turning off the ac unit for about an hour.(Your might have too small of ac unit or just have the ac set too low..Causing the coils to freeze.
May 27, 2010 | LG Art Cool LA121CNP wall/window Air...
LM-2430C2L 24000 BTU Cooling Only Dual Zone Mini Split Air Conditioner: Does LG makes AC which can cater two rooms at time...
Yes they Do they are called Dual Zone Units. At http://www.paylessminisplit.com they are very helpful if you call them they can answer alot of questions about many brands of mini split air conditioners.
May 16, 2010 | LG LM-2430C2L Cool Mini Split Air...
24000 BTUs LG split air conditioner external unit board leds flashing. What does it mean?
Hi; Look into Your owners manual for troubleshooting codes. If You dont have a manual call or google the manufacturer...alpharome416
Jan 19, 2010 | LG LM-2430C2L Cool Mini Split Air...
I have a split air conditioner my out fan keeps
It depends on the effiency of the unit. The fan could be cycling because the condensor coil is not hot enough. When it get hot enough the fan will turn on. If not you have a bad fan motor
Jun 25, 2009 | LG LSC091PMA Split System Air Conditioner
Lg split system ch 05 error outside fan not working
Solution # 1, Check Condensor Fan Motor Capacitor 4uf or MFD
# 2, Check Motor Windings
# 3, Check Relay OR Defination Contactor
# 4, Check Connection Terminals
hope will help u 2 solve this
GOOD LUCK
Jan 26, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
125 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
