Question about Samsung WF337AA Front Load Washer
My Samsung WA82HAG washing machine was working perfect till a couple of days back, now its giving beeps and 1E message when i try to power it on.
caroldon
  • 17130 Answers
SOURCE: my Samsung WA75B9 Washing machine
Disconnect the power for some time and if the machine shows the same errror it indicates a faulty application on the board.
Please make sure that the top lid switch is closing, check the lid switch mounted at the hinges to activate the main controller. check the wires to the switch.
secondly try to disconnect the output lines to the main motor and the inlet valve. if the fault changes then one of these has failed and needs a change.
Otherwise the main program controller is a suspect.
Posted on Mar 25, 2011
SOURCE: My brand new Samsung J845
I contacted Samsung Australia and was informed that this was a Water Sensor Level fault. The machine will be fixed under their warranty guidelines. Thank you.
Posted on Apr 18, 2008
futureloginn
  • 734 Answers
SOURCE: No Drainage on my LG WD-8050F washing machine
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
  • 1531 Answers
SOURCE: 1E appears on my samsung washing machine
this is a pressure sensor error and it needs to be replaced can usually be done fro under thirty dollars
Posted on Sep 16, 2009
heatman101
  • 43501 Answers
SOURCE: - machine is not letting water in
The soleniod valve may be bad.... here is a tip that will help...
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Posted on Apr 25, 2010
My Samsung Washer has a code of 1E which means maybe the water level. My problem is that it want turn off. Even when I push the stop button. The door is locked and it keeps beeping and flashing
1e is usually a pressure sensor error. To open the door you will need to switch off the appliance at the wall then after about 2 minutes the door should unlock. You could try the appliance again as it may just be a glitch but you will probably need the pressure sensor.
Good luck.
Dec 17, 2015 | Samsung Washing Machines
Samsung WA82HAG water leaks while running the machine
WA82HAG water leak :
I have been using a WA82HAG top loading washing machine for 7+ years without any issues. Of late water had started to leak out of the drain pipe when the machine was in wash or rinse.
I contacted the customer care and was pleasantly surprised with their professionalism. The support personnel patiently listened to what I had to say. They even called back when the line got disconnected during the conversation! All details were asked for, expected cost estimate and technician visit time estimate was provided over the call.
The next day the technician arrived and diagnosed the problem to be a faulty drain valve. The rubber in the valve had become hard over time and was not plugging the drain correctly.
The following day he returned with the spare part, fixed it and demonstrated that the problem had been solved.
The total cost was Rs.300 for engineer visit + Rs.750 for the spare part.
Attached images of the replaced part. Black rubber can be seen in the second image.
I am completely satisfied with the how the issue had been handled. I will consider a Samsung washing machine if i plan to upgrade in the future.
Thanks Samsung!
82352738-7acb-4c99-8997-c18e55abcd8b.jpg b6d9e50b-dbf2-46d8-b193-f961a1ac2bd2.jpg
Sep 30, 2013 | Samsung Washing Machines
Samsung washer E5 message
my washer machine work perfect the day before, they gimme a code e5 and stop working no power and look the door
Jun 20, 2012 | Samsung WF337AA Front Load Washer
Daewoo DWD G1243S washing machine not filling properly. 'ie' coming up on display & bleeping. What can i do to solve it?
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
Dec 27, 2010 | Daewoo Washing Machines
Samsung model number WA7589 when switching on gives an error message 1e after about 20seconds n beeps . Help out because at times it works after a day or two . Please let me know if it can be fixed or...
The simplest soulition to try is to unplug the unit from the outlet for at least 5 min's and this reboots the cpu and if this not resolve issues is maybe other things. If water remains in tub check the pump of objects preventing it from draining completely.
Dec 24, 2010 | Washing Machines
Samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
Samsung wf337aa front loader
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Jul 13, 2008 | Samsung WF337AA Front Load Washer
My brand new Samsung J845 washing machine keeps showing an error message (which is not in the manual of 1E. What could this possibly be and how do I fix it?
Apr 17, 2008 | Samsung Washing Machines
Samsung WF337AA Front Load Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
