Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Trying to watch dvd HDMI channel says receiving auto control signal (now) at top of screen and keeps flashing in and out
I have dish network and have my satellite receiver connected to TV via HDMI port 1 and have no signal flashing across screen while on. I can change volume and use all buttons on TV and remote except...
Based on what you're saying it can only be a few things.
Trying putting the HDMI cable into a different port on the tv and change input.
Try changing the HDMI cable.
If that doesn't work, change over to component cables, change TV input again and see if that works.
Nov 03, 2013 | Proscan Televison & Video
The tv keeps saying run auto channel scan
I have run the auto scan many times and it never finds any channel. I found that you have to put it on the HDTV, PC, AUDIO channels in order to watch or connect anything on the TV. Try doing that.
Sep 13, 2013 | Proscan PLDED3273A 32" LED 720p HDTV with...
Hi, I am in Melbourne Australia. Can I receive gem hd channel thru my dmr-ez48v. I haven't tried but I do have a hd monitor screen that I can plug the unit into. Also what does the hdmi on the unit do....
HDMI means high definition multimedia interface.
When connected to an HDMI compatible unit, an uncompressed digital audio and video signal is transmitted, enabling you to enjoy high quality digital video and audio with just one cable. When connecting to an HDMIcompatible HDTV, the output can be switched to 1080p, 1080i or 720p HD video.
Panasonic uses Viera link option between their video products.
When connecting with a Panasonic TV (VIERA) or a receiver equipped with 'HDAVI Control' function, linked operations are possible. [Linked Operations with the TV (VIERA LinkTM HDAVI ControlTM)]
Please use HIGH SPEED HDMI cables that have the HDMI logo (as shown on the cover).
It is recommended that you use Panasonic's HDMI cable.
Recommended part number: RP-CDHG10 (1.0 m/3.3 ft.), RP-CDHG15 (1.5 m/4.9 ft.), RP-CDHG20
(2.0 m/6.6 ft.), RP-CDHG30 (3.0 m/9.8 ft.), RP-CDHG50 (5.0 m/16.4 ft.), etc.
Non-HDMI-compliant cables cannot be used.
(the above is from the owner's manual of this model - page 40 tells you about linked operation using HDMI HDAVI control and how to set it up)
As for Gem HD, this unit has an SD (standard definition) digital tuner - it will not decode/receive HD channels. I should point out that 7mate also is a HD channel but is not specified as such in any menu or even their website. (I found this out by accident when I tried to record on timer 7mate one day and all I got was 'unable to decode HD channel' banner at the bottom of a blank screen)
Channel 11 is a SD channel - so this will work with your DMR-EZ48 as will all the other relevant main free to air channels (ABC/7/9/10/SBS). GO! is also a SD channel.
To be able to record HD to this combo unit you will need a HD set top box connected via its AV inputs. HDMI simply means you will get HD video quality from the combo to the TV, you will not receive HD channels from your HDTV to your DMR-EZ48 unit via this method.
Mar 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
LD4088 LCD will not play sound via HDMI cables. Component cables are fine. Hear a faint "click" from speaker when switching to HDMI input. Have tried all three HDMI connectors and have tried...
This is how AUDIO works in HDMI setup, you can select the source to send the digital audio along with the digital video through HDMI, the receiving end HDMI sound setup must be set to receive the digital audio through HDMI. Otherwise the audio may be sent and received through analog audio ports (Red (Right channel) and White (Left channel) RCA jacks) in stead. Most of the new TV and DVD player use auto detection.
So please check the HDMI audio setup to see how the audio signals are set to be processed.
Please leave rating if it helps.
Jan 14, 2011 | Apex Digital LD4088 LCD TV
The words "weak signal" flashes on screen at different places and do not receive a picture.
seems like you are using an "off the air antenna" that receives weak signal, you may be too far from the station, go get a roof top amplifier antenna or subscribe to digital service from cable, satellite or at&t uverse. If you think your antenna is getting good signal, try to rescan your tv for available channel. Make sure your TV set up is correct, if you are using Off the air signal, your setting should be set at "Antenna or off the air", then rescan your TV. Normally on Satellite or cable box, you just watch it on video channel or component input, if you are using HDMI then tune to HDMI channel.
Check your connection to make sure they are making good contact. If you can post your set up, I can better solve your problem.
For a resource on "off the air" antenna, go to www.antennaweb.org for help.
Aug 16, 2009 | Sceptre X32BV-Naga 32 in. LCD TV
I just got a new tv, and have hooked it up to my Directv receiver per their phone helpdesk person's instructions. I can't get the channels to auto-program on the tv - it keeps telling me there's no signal....
How are you connecting the receiver to the television? RCA cables? HDMI? Coax cables?
Auto tune only works if you are connecting via coax and plan to use channel 3/4 to view. If you are using either HDMI/Coax/Component/etc, then you would need to use the input button on your television remote (Not the DirecTV remote, the one that came with your television) to toggle through the various inputs until you find the signal from the DirecTV receiver.
Feb 24, 2009 | Directv RC23 Remote Control
I cannot seem to get DTS-HD master to show on the receiver screen
You need to check 3 things:
1) DTS will only work through a digital connection (coaxial, optical, or HDMI) between your receiver and dvd player. DTS and Dolby 5.1 cannot carry a signal over red and white rca connections.
2) After number 1 is solved ensure the reciever is set to the digital channel, your DTS-HD in this case, or in an auto mode.
3) Finally the most important is that the signal is a DTS signal. Start a DTS capable dvd, go to the sound menu and set it for DTS.
Press play and all should be well...
Cheers,
NTIMID8
Dec 13, 2008 | Onkyo Audio Players & Recorders
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
I bought dvd hdd recorder 3 days ago from lidl it is a targa DRH-5700X seriel no. e5809000859. Imust not have it connected right as i cannot get anything from it on the television.Ihave the recorder...
i have a targa 5500x from lidl cant copy from hard drive to dvd as i have done this many times but the dvd drawer keeps opening telling me to put in blank dvd and i keep doing this but getting no where,
mary
Apr 23, 2008 | Toshiba SD-4000
Receiver won't put out sound to LCD Sharp aquos
I have the same problem with my Sharp Lcd and Onkyo 804. I believe one problem is that the TV can not accept dolby digital or dts digital audio signals through HDMI. It will play sound if it receives a PCM signal through HDMI. You can try switching the type of signal on the cable box settings and on the dvd player. I switched to PCM and got sound through the TV and the receiver. The problem is that PCM is usually only a 2 channel signal and Dolby 5.1 will sound better through the surround sound theater system. I have not found an absolute solution to this yet, but I am willing to not get sound through the lousy TV speakers in order to get top notch sound through the Onkyo.
Nov 12, 2007 | Onkyo TX-SR803 Receiver
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
776 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
