Question about Summit Toys
I need an instruction/owners manual for Summit BI-605B refrigerator-freezer. Can you help?
    Problem Solver:
  • 16 Answers
Http://www.summitappliance.com/catalog/display_repository_file/1
also
http://www.summitappliance.com/catalog/model/bi605%20series
Posted on Nov 07, 2010
I need a manual for body champ 605b weight bench
Try Googling (body champ)(605b)(manual) without parens.
Jul 02, 2017 | Bench Exercise & Fitness
Where is the thermostat located on the Hotpoint fridge/freezer RSAV21
Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer
? 3:27
www.youtube.com/watch?v=YPglk963cXM
Sep 7, 2012 - Uploaded by Ezee-Fix Basic Fridge Repair & Maintenance - Hotpoint Fridge Freezer. Ezee-Fix .... Refrigerator Repair- Replacing ...Missing: rsav21
Free Hotpoint Refrigerator User Manuals ' ManualsOnline.com
kitchen.manualsonline.com > ... > Hotpoint > Kitchen Appliance Hotpoin
Products 1 - 50 of 299 - Hotpoint Top-Freezer Refrigerators Owner's Manual and Installation Instructions 18, 19 .... Hotpoint BL31 Larder Fridge Instructions for Use.
Oct 29, 2015 | Heating & Cooling
The freezer section of my refrig has a LOT of "snow". Any fix?
KitchenAid KBRS19KTMS Owner Manual
see page 16, moisture buildup
consider:
draw not closing tightly enough or not closing all the way
bad gasket allowing moist air into freezer compartment
defective defrost cycle
Aug 14, 2015 | KitchenAid Kitchen Aid - KBRS19KTMS...
Ice buildup summit freezer
Check if fan is working by pressin the door switch, or if you have exceptional high load recently. Remove everything off the unit overnight before you turn it back on again..
Oct 11, 2014 | Summit Refrigeration FFBF245SS - Counter...
No power to freezer fan on hotpoint ffa91
On some of theses units the fans are connected through the defrost bi metal. When the bi metal gets cold the fan comes on. Check and replace bi metal. Should solve your issue.
Aug 18, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
My bottom freezer needs to be defrosted. I have this refrigerator for about 8 years, what is wrong? and how do I defrost it?
This unit uses an electronic control for defrosting.
Control Board
Item #1472681 (OEM Part)
Electronic control board with two LED digital displays and installation instructions Available from Bi Coastal Appliance Parts @ 1-800-673-1262
Mar 22, 2011 | Amana ABB1927DE Bottom Freezer...
IFrost Free Sharp Refridgerator & Freezer-Fridge not keeping cold
hello sir/mam
please check the blower of the refrigerator if this is not working the refrigerator wont get cold.
Sep 14, 2009 | Refrigerators
I'm getting frost in my freezer and loosing temperature in my frig
Hi, Unplug the refrigerator. The automatic defrost is not working properly. You will need to remove the rear panel inside the freezer section and test the defrost heater and bi-metal switch. The bi-metal switch located on the top of the evaporator coil needs to be tested while it is still cold. Check and see if the switch has continuity. If the bi-metal switch shows an open circuit, replace it. If it shows a closed circuit, test the defrost heater the same way. If both the defrost heater and the bi-metal switch are ok, the defrost timer will need changed.
You will need to defrost the evaporator coils with a hair dryer. Please let me know if this helps you at all or if I can assist you further.
Thanks
Vic
Aug 14, 2009 | Refrigerators
Full of ice, no deforst , I change the timer and it seems to work, but after somo days start again, the model is WRT18DKL , i think is the termosthat but i need to know how to check it.
Hi, You will need to check continuity on the bi-metal switch and it needs to be tested while cold. If the bi-metal has an open circuit, it will need changed. Remove the rear inside panel of the freezer and locate the bi-metal switch at the top of the evaporator coil.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 11, 2009 | Whirlpool ART535 Top Freezer Refrigerator
2001 top freezer won't defrost
Hi, You will need to check three different parts of the defrost cycle. The most common problem is the bi-metal switch. UNPLUG the refrigerator and remove the rear inside freezer panel and locate the bi-metal switch attached to the evaporator coil in the upper corner. You will need a voltage/ohms meter for this test. Check the switch to see if it has continuity. Note: This switch has to be cold in order to test it! If it tests open circuit, you will need to change the bi-metal switch. If the bi-metal switch tests ok, then test the defrost heater the same as you tested the bi-metal switch.
IIf both of these parts test ok, you will need to change the defrost timer.
Please get em a model # and I can assist you on locating the timer.
Vic
May 29, 2009 | Kenmore 64802 Top Freezer Refrigerator
Toys Logo
281 people viewed this question
Top Summit Toys Experts
Ashlay Adams
Ashlay Adams
Are you a Summit Toy Expert? Answer questions, earn points and help others
