Question about Mitsubishi WS-65809 65" Rear Projection Television
The tv's convergence is off but the resetting the convergence manaually in setup mode is not correcting the problem.
  • Mitsubishi Master
  • 1,255 Answers
The convergence ICs located on the signal board will need replacing. This is the board with all your RCA and RF connectors are. You will also need to inspect those low ohm small wattage resistors and check the bottom side of the boards for bad grounds. (These will need to be resoldered) Take this note to your local TV doctor, you have concrete proof, you know what needs to be done.( This can save you a few bucks.) Good Luck and thank you for asking. Show a few hands of support!
Posted on Nov 07, 2010
52" rca hdtv has a shadow ghost when it plays. It
convergence issue. Press menu and then scroll down to the setup option enter setup and scroll to Autoconvergence and activate the auto convergence feature that will realign the convergence . If that doesnt correct the issue you will need a Convergence power board, If the auto convergence feature is missing from the setup menu then you need the convergence option missing repair kit. Both the board and the repair kit are available from www.tvrepairworld.com
Jun 18, 2011 | RCA D52W23 52" HDTV CRT TV
Tried convergance, but would work
i think you need to replace the IC convergence modules..
Jul 13, 2008 | Mitsubishi VS-70601 70" Rear Projection...
Can a ps3 cause problems for your tv
If the convergence is normal with VHF antenna or video input, convergence circuit is OK.
If convergence problem becomes visible when you switch to HD input, the convergence needs adjustment for that size or picture mode. Sony TV has different memory data for different size or format pictures.
If adjustment in the customer convergence adjust screen is not satisfactory, someone has to enter the service mode and adjust. Not recommended for rookies.
The game box or any other input will not damage or stress the TV if the game box is working normally.
If convergence is not correct in all size modes and can not be adjusted you need a repair to the convergence circuits.
Occasionally the convergence ICs are on the verge of failure from accumulated AC power bumps or lightning pulses on the AC line.
A small spark from poor grounding or static electricity can occur when connecting an input and the TV is powered on. Semiconductors (transistors, diodes and ICs) that have accumulated junction damage may fail when the effect of the arc is applied to the junction of the semiconductor.
The failures are often blamed on the Game or other external device. The TV would probably have failed in a short period of time with normal operation.
Turn off power to TVs and external devices when connecting or disconnecting video, audio or antennas. It is also important to use power sockets correctly. All electronic equipment has polarized plugs or 3 prong plugs to make sure the grounding is correct. Using multiple extension cords that are not grounded correctly or incorrect house wiring causes ground loops and unexpected problems. Best is a power bar with 3 prong plug in the wall.
easyab
Jul 20, 2010 | Sony KP-51WS500 51" Rear Projection...
My tv is showing at teh bottom of the screen the red and green lines from the projectors , and if a change the bullb how do I focus the lense again
This set does not have a bulb. It has three picture tubes and a convergence correction circuit. Find the convergence adjustment mode in the setup menu. If you cannot adjust the convergence, most likely you have bad convergence IC's. This can be a complicated repair. Have a shop check it out for you. Thanks for using fixya.
Dec 13, 2009 | Philips 60PP9202 60" Rear Projection...
My big screen panasonic tv has a double fuzzy picture what am I supposse to doto fix it
Adjust the convergence or reset it to factory default. Use only the remote when adjusting convergence. The front controls have no effect.
  1. Press action button to enter MENU.
  2. Navigate to SETUP.
  3. Scroll down to CONVERGE.
  4. Press VOL > to select.
  5. Press CH buttons to navigate up or down.
  6. Choose CONVERGENCE ADJ or RESET TO DEFAULT.
  7. Press VOL > to select.
  8. If CONVERGENCE ADJ is selected the align Green to Center screen will be displayed.
  9. Use the navigation buttons on the remote control to align the horizontal and vertical green lines on screen, with the cabinet reference marks on top center and left
    center of cabinet.
  10. Press ACTION button to display red center correction screen.
  11. Use the navigation buttons on the remote control to align the red cross with the white cross pattern at the center of the screen. To prevent picture tube damage do not leave test pattern on for an extended period of time.
  12. Press “0” on the remote control keypad to display the BLUE center correction screen, repeat procedure for adjusting blue. If needed press “0” again to return to RED correction screen. An adjusted cross pattern appears white with a minimum of color protrusion.
NINE POINT CONVERGENCE CORRECTION
Remote Control must be in TV mode.
  1. Press ACTION button to display red correction screen.
  2. Press the 1 through 9 keypad buttons on the remote control to select the desired convergence position.
  3. Use the navigation buttons to align the RED cross with the white cross pattern.
  4. Press “0” on the remote control keypad to display the BLUE correction screen, then repeat procedure.
  5. To exit press ACTION button repeatedly, then press CH up.
Nov 07, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Convergence board swap questions....
You can try to change it out and go to convergence adjustment mode on service mode to setup the template.
But I rather replace couple trans and leaky diode on your old convergence amp board to save my time
Jan 06, 2009 | RCA D61W20 61" Rear Projection Television
Convergence problem on rca model d52w23
Replace convergence board or repair it. Try this with TV off Press and hold vol-and ch- at same time hold untill set comes on Now you should be in service menu Go to convergence Adjust the 16x9 mode.
Dec 21, 2008 | RCA D52W23 52" HDTV CRT TV
SERVICE MODE
I have a tv bluesky model PR14 .can anyone help me with service mode-
Jun 10, 2006 | JVC AV-56WP30 56" Rear Projection...
Mitsubishi WS-65809 65" Rear Projection Television Logo
412 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
