Not connected correctly
I had a wall mounted VENtop Air Con Unit installed 18 months ago and it blew more cold air out of the motor outside than the vent indoors. Installer came and said problem was it needed more gas. Problem persists. Installer no longer around. Cannot see a model number, stickers say VO5030035 and INT9000BTU2J, it's 220-240V and uses a seemingly universal remote (GZ-1002B-E3). Friend who completed air con installation course recently cannot find diagram for electrical connection & through trial & error managed to get it blowing cold air into room but outside motor fan did not function. Unless can get help with how to connect wires am stuck with a large white elephant! Please help.
  • 3 more comments
  • SadCanary Jun 15, 2008
    The gas appeared to be a ruse, the equipment was not correctly connected and now need installation diagram.
    Friend seemed to think all major companies have some sort of connection diagram on unit, in order to make installation.
    Do not believe to be Hyundai - any suggestion where to find product or model number? Only ID can find is "VENtop", which appears to be a Polish company.
    Suggestions on correct procedure for connecting wires from outside Vent unit to internal fan?
    Yes, that's the problem, the wiring diagram seems to be missing. Outside unit says EXT9000BTU CF C407 and Refrigerante R407C?830g but think that refers to type of gas or something. Anywhere else ID might be hidden - there's absolutely nothing obvious!
    Many thanks.
    Genius:
  • 1,036 Answers
Connect up and use the control to go through the sequence of options you have.
Using suitable test equipment, take readings from the output connections you have.
One will turn compressor on off.
You should be able to find the motor connections quite easily, as the voltage will rise according to the setting.
As long as the compressor is wired to the correct on/off outputs it will cool.
There will be a temperature feedback loop in this to stay within limits - so will turn off when not required.
This should get the system working at least, but may need fine tuning to find the right connections so that the compresor turns on and off automatically.
Hope you found this useful.
Obviously a full wiring diagram would be very helpful if anyone can find it???
Posted on Jun 15, 2008
  • Richard Perkins
    Richard Perkins Jun 15, 2008
    Just to explain a bit better, One supply will be an on/off for the compressor. One supply will be variable - for the blower fan.
    The thermostat override will turn off the compressor supply when the temperature is cool enough, and come on when too warm.
    Hope some of this onfo will help you.
  • Richard Perkins
    From what you've said, The outside (refrigeration unit) is not working because the refrigerant gas has escaped through a leak.
    Therefore it has no gas to compress - and therefore won't refrigerate anything.
    Repair to refrigeration units is a specialist job, as the fault needs to be found, then repaired - often by high temperature brazing of conections. It then requires purging and refilling of refrigerant - then checking for leaks.
    I advise you find a different specialist refrigeration engineer to solve this problem, as it is not an easy self-fix.
    Hope this ends in a satisfactory manner.
    Master:
  • 638 Answers
Better than trying some useless solutions i will provide u with a link of a site which will give u all th repair diagrams,installation details .its helped me many times n i feel it will help u too:
http://www.repairclinic.com/0047_16.asp
  • hemant somaiya
    hemant somaiya Jun 15, 2008
    show ur appreciation by rating my solution as fixya if it helps u understand n solve ur problem.thanks in advance
    Scholar:
  • 198 Answers
Did u try to check the motor...also check the gas connections.. if its rite... it shud work proper
    Sergeant:
    Champion:
  • 230 Answers
As you that it is a gas problem, then the only thing you should do is better contact near service center because it seems to be big problem if you repair by own then it will cause serious problems .If warranty is there then go for it dont do trial and error method
  • 1,512 Answers
Hi SadCanary
The first number you gave looks like a serial number, and the second a rating 9000btu is the heating/cooling rating. Can you find another model number anywhere? If you can, I will try to get a manual for you to assist with sorting it. Just remember that there are regulations about power switching and supply circuits for air conditioners that a qualified installer understands. They may only charge you a callout fee and say 1/2 hour labour to connect it for you. These guys don't need circuits and so on. Familiarity with these things means SAFETY.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
  • Graeme Ross
    Graeme Ross Jun 15, 2008
    there are often wiring diagrams under the cover for the unit. Have you checked already for this.
  • Graeme Ross
    yer... good luck with that
    Guru:
  • 1,894 Answers
If it is the gas problem then it is a serious problem
I have an Air-con air conditioner and heating system
Check your filter, if it's clean check the condensate drain to be sure it's draining if ok your system has a leak and will need an ac tech to repair and recharge the system
Nov 28, 2013 | Air Con 9,000 Btu Split ditioner Wall...
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
Hello, My condensing unit (LG-LMU245HV) and my wall unit (LG-LMN185HV) are brand new and were installed just one month ago. Everything has been running fine but now all of a sudden now the air coming...
Hi, when the copper lines at the condensing unit, the larger of the 2- start to form ice, you have a freon leak. The unit is new, so I would expect the leak to be at one of the welded/brazed joints. What will happen, is the indoor unit, the evaporator coil will start to ice over and block off all air flow through through the coil. I hate to tell you this, you will need to call the installer out to do a leak check on the unit. They will then need to pump it down, braze the leak with sil-phos, or silver solder and recharge the unit. This is the problem, I see this a lot on new units. Someone forgot to do a leak check on it. Being only a month old, it has to have a warranty on it, shouldn't cost you a dime, but this is the problem, indeed!! Please keep me updated on this and get them out there. It will never cool until they fix the leak and recharge it. Please don't forget to rate me on this, I know you will be kind. Keep me posted and you can contact me by my user name below. Thank you Zeke! You still have freon in the unit, just low enough to start the suction line outside to start to ice and loose your cooling.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Aug 06, 2010 | Heating & Cooling
Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Nov 08, 2009 | Fujitsu 24C1 Air Conditioner
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
My Goodman a/c unit will not turn on ..
You have a short circuit in the outside system. Either a bad compressor,bad fan motor or possibly a bad capacitor. Visually examine the capacitor. If it is bulged out anywhere,replace it. Check for burned wires on the capacitor and all other connections.
Remove the compressors wires from the circuit and restart the unit. If the fan runs the problem is in the compressor. If the fan does not run,the problem is with the fan motor.
Jul 20, 2009 | Goodman CKL42AR42 Air Conditioner
Panasonic air con unit is not blowing cold air out.
This unit is use in motels etc. Check the ouside coil ( conderser) from the inside (discharge fan ) for dirt. Most of these units are floor level . This can cause a unit to short cycle ( cold air is at the floor) .
Jul 17, 2009 | Carrier 52PQ307 Wall/Window Air...
Fan just circulates air instead of exhausting the air outside
The exhaust motor was not installed properly - it has to be turned 90 degrees so that the blower openings face up instead of the front. Whoever installed it didn't read the directions:)
Unfortunately, the unit will have to be taken down from the wall to correct the motor.
Dec 21, 2008 | Maytag MMV5207AAS Microwave Oven
Heating & Cooling Logo
190 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
