Attempting to connect Teac SDB420 set top box without the instruction manual and I am not having any luck.
joeymille916
  • 143 Answers
SOURCE: NEC FS5195 TV instruction manual
No manual found. But, I found this post on the web....
"if you press the "menu" button for 3 seconds you can set it up automatically (grey button on the lower right) and have 1 additional menu by pressing menu again. Hope this helps!"
Posted on Oct 12, 2010
SOURCE: I have just purchased a
If you are trying to connect it in composite mode (the one yellow video cable) it won't work with the PIP turned on which is how it comes from factory. This is crazy as it means that you cannot see anything (menus) on the screen to disable it. I have a walk through guide here to turn it off blind or the other option is to take the STB and connect it to another TV via Component or HDMI and then turn off the PIP.
Posted on Dec 30, 2010
  • 3 Answers
SOURCE: I just bought a teac
I find that with my HDB849 I have to be very carefull with the positioning of the aerial/rabbit ears to get all the channels to (ABC, 7, 9, 10, SBS and their sub cahnnels) to recieve them at all. Also once you get all the channels it is prone to digitization or pixilation at times due to bad weather/very overcast days.
Try the Teac.com.au for a firmware upgrade as this also solved not being able to view avis & images, listen to mp3's etc.
Overall the majority of reviews say the HDB849 is to be avoided.
Once set up correctly through trial and error and an absolute shitload of patience and re-tuning it seems to operate fine. Just pray you do not get a power outage or you have to start all over again.
Last point, try the teac 1300 number in Australia (or relevent country) and harras them for info whilst trying to stay calm and nice with the unlucky "tech support" person
Posted on Apr 17, 2011
  • 115 Answers
SOURCE: i need to tune my
I have no idea what an antennae connection is. I assume you are talking about a Coaxial cable converter (large box that connects in line on the cable input). If this is the case, the box is override either channel 3 or 4. It either has a switch to pick which one of these to use or it is written on the box which one it uses.
If you are using a VGA connection (3 pins with 1 yellow, 1 white, and 1 red connector), then you have to find the AV channel. Every TV has one, unless it is like 4 decades old. If the TV is a few decades old, it may not have a channel called "AV" or "AUX". For example my dad's 25 year old TV uses 91 as the AUX channel. It is common for channels in the 90's to be used for this or channel 0. Best to just turn all the manually add/remove channels while the box is on. Then you can spot the right channel and add it to the listings.
Posted on May 09, 2011
  • 1746 Answers
SOURCE: I set up teac HDB840
Hi, Your set top box (PVR) is running on channel 3 or 4. Go to menu and sellect a source TV, DVD
Note: Do not connect more than 1 set of cables to tv or you may damage something.
TV > box connect RCA cable or HDMI not both.
Set top box > connect RCA or HDMI Not both.
audio devices > TV connect RCA or HDMI not both.
Good luck.
Posted on Jun 18, 2011
TEAC HDB850 set top box code
Hello John Laurence McCann...
A "down-under" model ... HDB850
Oddly enough our (usa) FREE MANUALS site has
your instruction... (owner manual...
Less than 10 pages... page 3 gets into
your REMOTE FUNCTIONS...
See it here:
https://www.manualslib.com/manual/767313/Teac-Hdb850.html?page=4#manual
Read the manual... It will help
Carnac the Magnificent
Dec 18, 2017 | Teac Televison & Video
Teac model crx-35. I want to set the radio alarm. Please help!!
Try Googling (teac)(crx-35)(manual) without parens to get instructions.
May 11, 2017 | Teac Audio Players & Recorders
What is the code for a teac set top box model hdb850
Codes are in the remote. If you are using a TEAC remote with a TEAC STB, you may be able to find something that will work.
Jul 16, 2016 | Teac Televison & Video
I am unable to find the owners manual for the Teac MC-DV100 SuybWoofer
For almost any set-top box, there isn't a sub-woofer output. Without that output (it would be labeled on the STB), you can't hook up a subwoofer directly to it.
HOWEVER, the model number you give isn't just a subwoofer: it's a whole sound system with a subwoofer attached to it. If you have the whole sound system, you just hook the STB's audio output to the amplifier's "Aux Input" (it might also be called "line input").
If your model doesn't have that (can't tell from the web), you'd have to buy an "AV Receiver" that has at least a 5.1 set of outputs. These start at maybe $150 new, $50 on eBay. MAKE SURE YOU BUY A RECEIVER WITH A "powered" SUBWOOFER OUTPUT!! You connect the receiver to the STB, and the subwoofer to the receiver.
Jul 15, 2015 | Teac Audio Players & Recorders
With set up box audio in to tv causes high pitch sound
I am assuming this should read 'Set top box'. What kind of cable are you using?
Usually the set top box connects via a SCART lead but yours may be HDMI if it is a very new set top box.
If you are using RCA plugs, you may have cross connected the wrong cables. The RCA cables should be colour-coded. RED and WHITE are for audio, Yellow is for video.
Best advice is to switch it all off, remove all the cables you attached, and start again. The instruction manual/user guide usually has an illustration to help you identify what your set up looks like - there are usually several examples.
If the cables you need did not come with the set top box, you will need to purchase them.
When you are connecting audio leads, you should use the 'audio out' on the set top box and the 'audio in' on your TV set.
It would help to know the EXACT model number of LG screen you have and the make and EXACT model number of the set top box.
Good luck.
Mar 07, 2015 | LG 42LC2D 42 in. LCD HDTV
I set up teac HDB840 to tv- via coxial cable from wall to set top box, then rca cables output of set top box , then to input to tv.-tried av button on tv showing av1 av2 and av3 but still no picture only...
Good luck.
Jun 18, 2011 | Televison & Video
Connet Hd set top box
May 31, 2009
Born to Race,
I have just bought a TEAC HBD841 which was on discounted sale at a local Electrical Store
Besides not being able to figure out how to connect the device to my elderly TV because the inadequate instruction booklet that is written in a language an Electrical Engineer would have difficulty understanding - does not explain which plugs go where, (try plugging a three plug lead into a 2 plug TV) but since then I have found out that the HDB841 has been withdrawn from sale and is no longer available.
No wonder it was cheap!
I suggest you get rid of it - quick
GB
Apr 20, 2009 | Televison & Video
Cannot set the clock--No manual
http://www.teac.co.uk/manuals/R-2(EFS).pdf
this is the manual,shows you how to set clock etc
good luck
Dec 29, 2008 | Teac R2 Clock Radio
Teac digital set top box prompt every five seconds
I had the same problem - pretty easy fix. You'll need a usb flash drive with all other files removed. Go to following link:
http://www.teac.com.au/pages/hdb842softwareupgradever161008
Print out the instructions and make sure you have winzip installed on your computer. Instructions were pretty easy to follow and seemed to fix the problem. I haven't watched the TV for a long period of time, but it seemed to sort out the problem you described and system seemed to run better than previously eg. didn't hang - receception better.
Good luck
Dec 27, 2008 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
