Question about Westinghouse Televison & Video
I recieved a westinghouse flatscreen from a friend. i have power but the screen wont come on.
  • 11,361 Answers
It may have problem with the 24vdc power supply, backlight inverter board, main board, T-CON board.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 07, 2010
My 32 inch westinghouse digital flatscreen lcd tv appears to be broken, I can turn it on from the remote but the screen does not show, it can even go to sleep but where is the picture?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 26, 2015 | Westinghouse Televison & Video
22" flatscreen LCD Westinghouse TV.
try use a lowest resollucion 720p and after change to 1080
Sep 20, 2011 | Westinghouse 22" Widescreen LCD Flat Panel...
I have a westinghouse 32 in flatscreen tv it is
This problem is caused by a bad backlight power supply. Check out this page on our web site:
www.ccl-la.com/capacitors.htm If you can solder then you should be able to do the repair yourself.This page gives pictures and parts information. You will need to open your monitor and replace the parts call capacitors that are damaged as directed on the page. If you don't want to do the repair we do offer a repair service for $40 plus shipping.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Jan 28, 2010 | Televison & Video
I CANT GET MY MONITOR TO TURN ON
It could be the Monitor, the VGA adapter, or the PC itself. If you power on the monitor without anything connected to it, do you ever see anything on the display?
If not, it is probably the Monitor. If yes, it is likely the vga adapter and/or PC.
Mar 18, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Westinghouse SK32H240S TV will not show picture...
Some solutions to this same problem were posted here, hope this helps.
Nov 22, 2008 | Westinghouse SK-32H240S Television
Westinghouse Flatscreen TV
Our Westinghouse Flat screen tv plays for a little while then turns the picture off but the sound is still on. How can we get this fixed?
Thomasville, Ga.
Jan 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
121 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
