Question about Dell Inspiron 1720 17" Widescreen Notebook, 2.0GHz INTEL CORE 2 DUO, WiFi, 2GB RAM, 500GB, CDRW/DVDR... (883585945740)
What usb cable should i buy to connect mydell inspiron 1720 to my printer which is epson stylus c7400
    Guru:
  • 846 Answers
I'm not too sure. Still check out this link http://www.amazon.co.uk/Usb-To-Epson-Printer-Cable/dp/B00007G1X4
Posted on Nov 07, 2010
How to connect epson c43sx printer to a compaq laptop?
get a printer USB cable you can buy from Staples or Bestbuy about 30 dollars. Then install the software/driver to your laptop then connect the USB cable to the laptop
Feb 01, 2011 | Epson Stylus C43SX InkJet Printer
What cable do i need to connect my netbook to an
The Epson Stylus C86 has both USB and parallel port connectivity. A USB cable would be better.This should be availible in any nearby computer store.The driver is availible in this link:http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=41661&prodoid=46048263&infoType=Downloads&platform=Windows
May 16, 2010 | Epson Stylus C86 InkJet Printer
Where can Iget drivers / software to use my RX620
Windows 7 will install its own driver for your Epson printer. If you have connected the USB cable, disconnect it for now.
With your computer on, power on your printer. Now plug in the USB cable. Win7 will automatically install a driver for your printer.
The Win7 compatible TWAIN driver and Epson Scan Utility software can be download from Epson support:
Epson Stylus Photo RX620 Downloads
Be sure to choose the file(s) for your Win7 version.
Jan 11, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
I need a cable to enable connection from Epson lq 1050 to my computer - (DELL Inspiron-530S)
The "data" cable for a printer either is:
* USB -- a small almost-square socket, less than 1/2 inch (1 centimeter),
* parallel-port -- a very-wide connector, more than 2 inches (5 centimeters).
Some printers have *BOTH* connectors.
Determine which connector(s) you have, and buy a cable.
Often, a "Thrift Store" will have the "parallel-port" cable for a dollar.
Don't pay more than $4 for a "USB" cable.
If you're buying a USB cable, make sure that there is a "square" end -- some USB cables have a smaller "mini-USB" connector, in order to connect to a digital camera.
Nov 27, 2009 | Epson LQ-1050 Matrix Printer
Install epson stylus photo 820 printer
Hi
you can get the software driver at www.support.epson.com
just select the printer driver and download it//
Jul 17, 2009 | Office Equipment & Supplies
Problem printing from Dell Inspiron 1720 with Vista Home Premium to Epson Stylus Colour 1160 using Nikkai USB to Parallel Convertor. Cable supposed to be plug and play. Any pointers?
You pretty much said it when you mentioned "Other than buying the cable in the first place" I have never successfully used a USB to parallel converter cable on any system. My suggestion, asisde from getting a true USB printer, is a parallel port card
http://www.newegg.com/Product/Product.aspx?Item=N82E16839328010&nm_mc=OTC-Froogle&cm_mmc=OTC-Froogle-_-PC+Cards/PCMCIA+Add-on+Cards-_-Syba-_-39328010
May 16, 2009 | Dell Computers & Internet
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
Connectivity of printer with newer computers
does ur unit have The LPT connection or COM ports .
u can use this ports as a alternative connection.
also check for MAC converter cables!!
plz rate this post as good as u can
Feb 06, 2009 | Epson Stylus Color 3000 InkJet Printer
Epson Stylus C46 InkJet
Check USB cable.
Try different cable and connect it to different usb port.
If it is not the cable, do the following driver reinstall:
Disconnect printer from usb
Remove printer from 'installed printers' in Windows.
Install again driver from disk with printer not connected.
connect printer when required by setup procedure or after installing drivers.
If it still does not wark then the printer is faulty.
Jul 11, 2008 | Epson Stylus C46 InkJet Printer
Hoe to connect the epson stylus to my computer
Hi Please provide more details.....I'll assume you have an older computer with only the large parallel port to connect to a printer, but the new printer requirews USB printer connection. If this is the case, unless your computer is VERY old, you should be able to buy a USB card to install in an empty PCI slot in your computer, and all should be fine. If you have Windows 98 you will probably have to install drivers. Good Luck!
Jul 10, 2007 | Epson RX620 All-In-One InkJet Photo...
Dell Inspiron 1720 17" Widescreen Notebook, 2.0GHz INTEL CORE 2 DUO, WiFi, 2GB RAM, 500GB, CDRW/DVDR... (883585945740) Logo
79 people viewed this question
Alun Cox
