Question about LG 50PX4DR 50 in. Plasma TV
No audio on pasma when cable set box set to certain channel
I lose audio on certain channel when selected and lose audio after that point on all channels until I turn off cable set box and tv. I have had the cable box replaced and connected another HDD on the cable set box which will work fine.
  • JR52 Jun 15, 2008
    When I connect a coax cable from the set box to the coax cable input of the plasma audio does work. So it is definitely with the HDMI/DVI connection. I have tried both HDMI/DVI inputs on the set with the same results. All channels work fine from the set box except for one channel.
  • Banji Lawal
    Banji Lawal May 11, 2010
    Have you tried to do cable direct i.e, connect cable wire directly to your tv set, to determine if problem is from your tv or from cable company? You might want to check whether your tv is on what we call SAP. You can find out this by going into menu opf your tv and select audio. If is in SAP you want to change it to Stereo
  • 4 Answers
In that case two things might be happening. 1. HDMI/DVI cable you using might be faulty you want to change that or 2. The HDMI input of your TV set might be the problem. I will suggest you use component cable instead, I am talking about the 5-color-coded (green, blue, red and red/wihte) cable to connect the set top box to your TV.
Posted on Jun 28, 2008
Can i use a rosewill lcd monitor as a tv
That depends upon what you are using with it. Monitors do not have integrated tuners and thus cannot select channels. However, most cable providers use set-top boxes that perform the channel selection function for you. Many of these boxes have HDMI outputs that can be used with monitors that have these input capabilities. Otherwise, you need separate audio and video connectivity from the cable box to the set, either in the form of composite video plus audio cables, or a DVI cable with audio cables. Again, this is dependent upon what the cable box and monitor support.
Jul 09, 2016 | Rosewill Computers & Internet
When changing channels sometimes I lose audio
Are you using a cable or sat box. if so I would suspect that device. If your are using the tuner in the tv rescan for channels. be sure you have antenna selected. If problem still occurs replaced the main board .
Jan 06, 2014 | Vizio E390-A1 39" LED TV 1920x1080, 60 Hz,...
Rca entertainment series pip. The audio is messed up. Some channels r silent, some are in spanish, some music play but not the voices. Called cable company they said the cable is fine. Help me please.
You have a simple problem:
It can be either in the set or a cable box if you use one:
The set in the audio menu or setup menu will have a setting called SAP- WHICH is secondary audio program--it will on certain channels do exactly what you describe--Spanish for Monday Night Football and music and such.
Find it in either the box if used or the set and switch it with the remote to Stereo (move it OFF of SAP)
I am surprised the cable company did not suggest this but ......
Mar 29, 2012 | RCA Televison & Video
Picture but no sound magnavox HD tv
check to see in audio menu for set and sat or cable box if SAP is engaged as this will (Spanish) cause no sound on certain channels.
The problem or setting exists in the set and most boxes providing signal to the set.
Mar 12, 2012 | Magnavox Televison & Video
Tying to hook-up my 1100 dvd player to tv I have the three cables white yellow and red audio out to audio in on tv. the recoder plays but no picture. is the a certain channel i should be on?
The connection should be the cable box out to the DVD in, the DVD out to the set. The DVD should have a channel select, Either 3 or 4- set it to the channel that is not used by the cable decoder. which should also have a switch for 3 or 4.
Then all you do is switch between channel 3 or channel 4 with the TV remote or by TV channel buttons. One will be cable, the other will be the DVD.
Dec 22, 2011 | Spectroniq PD-1100 DVD Player
I am trying to hook up my cable box so i can watch tv.
At the cable box input, connect the cable (probably labeled "Cable In" or "Signal In").
Depending on the cable box model and available inputs on your TV, connect one of the following (listed in descending order of video quality). Colored phono plugs must match the colors of the plugs on each end.:
  • HDMI (a single rectangular connector at each end - sometimes you need to connect the Audio separately with a two - line cable with red and white phono plugs).
  • YPbBr, AKA Component (Cable with Red, Blue and Green phono plugs, plus a separate Red and White cable set for Audio).
  • S-video (a single round connector and separate Red and White audio cables).
  • Composite (Yellow video cable plus Red and White audio cables, usually sold as a single set).
  • RF out on the cable box connects to ANT or Cable In on the TV with a coax cable.
The various options are always grouped in some manner on both the Cable box and the TV. On the TV, note which input set you use, for example, "Component 1". This is the input you will select to watch whatever channel you select on the cable box.
An unused output on the cable box can go to a video recorder. Some cable boxes may permit setting up two different channels for this purpose; others will only put out the signal from one channel at a time on all outputs.
You may, if you prefer, connect the audio cable from the cable box to a stereo receiver instead of the TV. Usually people connect the audio to the TV, then connect another audio cable from "Audio Out" or "Monitor Out" on the TV to the stereo receiver. That way the sound is from whatever video source is currently selected, and the TV remote control can be used to set the volume. TV sets with this option usually have a setting to turn off the internal speakers so you hear only the external stereo speakers.
Feb 05, 2011 | Televison & Video
HBO is in Spanish, other channels are English. How do you get HBO in English.
SAP IS : secondary audio program--if engaged certain channels will have audio in Spanish instead of English.
Both the set and any cable or sat box etc hooked up can cause this---check the audio mode on the TV first to make sure SAP is not selected. If not, check the box providing the signal to the set, it also has SAP.
If you cannot find the setting on the box you can unplug the box and it will in most cases revert to NO SAP or you can contact your provider for signal to learn how to change the setting.
The set does not cause this kind of problem--it is something set by accident wrong.
If this helped you rate this solution as "very helpful" as I do this here for free.
If you have questions feel free to comment here--I am here to help.
REGARDS, SD TECH
Aug 11, 2010 | Zenith H27F56S 27" TV
Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
May 19, 2009 | LG 37LG30 37 in. LCD HDTV
Cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 27, 2009 | Zenith B27A11Z 27" TV
Volume trouble with 37LG30
well if you want to get rid of he tv i offer to buy it from you
Habunoki@yahoo.com
Feb 03, 2009 | LG 37LG30 37 in. LCD HDTV
LG 50PX4DR 50 in. Plasma TV Logo
98 people viewed this question
Computer Repairing
Computer Repairing
