Question about Irons
Clean iron with.....
You wrote clean the iron with : "CLR" product. Can you please write out the name, what it is the "CLR" ??????????? Thank you. Marilyn
  • mimi777 Jun 15, 2008
    Thank you very much your fast help.
  • 975 Answers
CLR stands for Calcium Lime Rust
Here are also a link for other options on cleaning iron ,
http://wiki.answers.com/Q/How_do_you_clean_steam_iron
Posted on Jun 15, 2008
My brand new Hamilton Beach steam iron is shooting out rust on my clothes. How can I get it stopped?
Clean it.
Tip & How-To about Irons
Cleaning a Laundry Iron Get some CLR descaler and mix it to the directions. Turn the iron on and set it to steam. Turn the iron off and put the CLR into it. When it has cooled a little, sit it faceplate down in an oven proof dish. Leave it over night. The CLR will drip through and sit in the dish cleaning the inside, and the topside of the soleplate. The next day, fill with water and shake upside down to empty any remaining CLR and scale through the fill hole. Keep filling and shaking to empty until the water comes clean.
If you don't want to use CLR, you can use white vinegar undiluted.
Posted by Andrew... on Mar 18, 2016
Cleaning Laundry Iron
Aug 07, 2017 | Hamilton Beach Irons
My steam iron has calcified outlets although have regularly emptied the machine through the outlet, therefore not working properly
its a great iron no argument there
de scaling products can only do so much
even if using demin water or filtered water
they dont last forever
Nov 09, 2016 | Tefal Irons
My iron is steaming out rust coloured water how can I clean it please
Having been asked this many times, I wrote it as a Tip to save me writing each time.
Apr 24, 2016 | Oreck Cordless Steam Iron
How do I clean my iron? It sometimes stains my clothes and drips water from the bottom. Please help. Thank you.
Mar 18, 2016 | Rowenta DX9800 Iron
How do I clean my iron? Sometimes my clothes get stained and water drips from the bottom. Please help.
CLR
Clean distilled
Use CLR or any other lime scale remover you can find. Pour out any water in the bottom chamber and put some CLR into it. leave it for 10 minutes to an hour. Run it to have some CLR so though any passages, then pour out any remaining CLR and replace with water again to wash out the CLR. When you are satisfied that the CLR is all rinsed and replaced with clean water, then it is safe to iron again. CLR can alway be put on a cloth and wipe the iron surface or any deposits.
Oct 15, 2013 | Tefal GV7070 Iron
Clean iron?
Hello tcant....
  • 1 Fill the iron's steam receptacle with white vinegar or CLR, a product used to clean coffee pots. CLR is available in department stores.
  • 2 Plug in and set the iron to its steam setting.
  • 3 Operate as usual. When the vinegar or CLR begins to steam, operate the iron as you would normally. Press it over an old, clean towel as the vinegar or CLR loosens sediment and dirt from the appliance.
  • 4 Continue ironing until all of the cleaning solution has steamed out. Repeat the cleaning process if necessary until the iron no longer oozes discolored liquid and the ironing surface is clean.
  • 5 Fill the iron steamer receptacle with distilled water and set the appliance to steam.
  • 6 Continue steaming until the smell of vinegar or CLR is gone.
  • 7 Prevent future mineral buildup by using distilled water for steam in your iron, rather than tap water. Joe. Thanks for choosing Fixya!
  • Jan 12, 2011 | Black & Decker ICR250 Iron with Auto...
    LIMESCALE BUILD UP
    To prevent lime build-up, use distilled water instead of tap water. I buy bottles of distilled water for use in my irons and steamers and have never gotten calcium or lime build-ups.
    You can buy a product by the name of CLR (stands for Calcium, Lime & Rust) which can be found at stores such as Target, Walgreens, CVS, Walmart, etc.) to wipe the build-up from your iron. You can also run this solution through your iron to clean the build-up from the inside.
    May 12, 2009 | Irons
    How to clean
    heres a link to help you out , also I recommend to get "CLR" cleaning product , hope it helps AJ
    Jun 12, 2008 | Rowenta DX6700 Iron
    Dz9080
    A pint of white vinigar in the reservoir and steam it thro will clean it up a treat. Steam some clean water through afterwards before using it on your clothes. Best Wishes Rick
    May 08, 2008 | Rowenta Steam Generator DG050 Iron
    Irons Logo
    183 people viewed this question
    Top Irons Experts
    Are you an Iron Expert? Answer questions, earn points and help others
