Question about Dell Inspiron 700M Notebook
Buenas noches, apenas enciendo mi portatil dell 700m me pide clave de bios, la lleve a un tecnico y creo que no la trabajo bien y no la logro desbloquear, que puedo hacer?? soy de colombia y la verdad no tengo dinero para comprarme un portatil, este me lo regalo un familiar y que mirara si lo podia arreglar mil gracias
  • Anonymous Mar 20, 2014
    le pusieron una clave no la se
  • Anonymous Mar 21, 2014
    la ensiendo me pide clave
  • Dell Master
  • 7,733 Answers
Use a floppy disk or USB memory key to create a password reset disk using the following Microsoft instructions: How to Create a Password Reset Disk
The easiest way to recover from a lost password situation is to use a password reset diskbuenas noches, apenas enciendo mi - extlink.gif. If you have a reset disk, follow these steps:
  1. At the Windows logon screen, click Reset password.
  2. Insert the recovery diskette or USB key.
  3. Follow the instructions on-screen to create a new password.
  4. Log onto the account using your new password.
new_note.jpg Note: Password reset disks are valid for the account they were created on. If you use a password reset disk to recover your password, you do not need to create a new reset disk afterwards.
Issue 3: Resolve Error: The User Profile Service Failed the Logon
The following Microsoft Knowledge Base Article provides instructions on how to resolve The User Profile Service Failed the Logon. User profile cannot be loaded error.
"Error message when you log on to a Windows Vista-based computer by using a temporary profile: "The User Profile Service failed the logon. User profile cannot be lbuenas noches, apenas enciendo mi - extlink.gifimg src="http://i.fixya.net/uploads/images/extlink.gif" alt="extlink.gif" class="h_mi" /> Article ID: 947215.
Issue 4: If You do not have a Password Reset Disk
If you have lost or forgotten your password, and a password reset disk is not available, reinstalling the operating system is the only recourse. For information on reinstalling Windows, refer to Dell Knowledge Base Article, How To Restore or Reinstall Microsoft® Windows® on a Dell™ Computer
Posted on Nov 07, 2010
Mr garcia mi carro se apaga cuando lo quiero prender ,parece que la alarma se activa y no me deja prender el carro
viejo tengo un camaro chevrolet modelo 80 pero excelente motor ,,venia funcionando bien , y ahora lo enciendo y se apaga , creo q es el distribuidor, no se creo ,,q sera ,,la bateria esta cargada , el alternado le pongo un bombillo ala salida y prende ,,q sea,,por q se apaga cdo lo arranco
Jan 06, 2013 | 1992 Lexus Es 300
Tengo un problema con un cadillac deville pasa el aseite al anticonjelante se calienta y pierde mucha fuerza asta no kerer correr mas el mecanico dice poder correjir el problema cambiando los empakes pero...
el problema de aceite mescandose con el anty congelante es por lo regular empaques de cabeza pero en algunos casos puede ser solo empaques de manifool de admission o en terminos usuales diriamos empaques de la arana asegurese que el mecanico le de un precio en caso de que solo sean los empaques de arana por logica seria mucho mas varato que los de cavezas. el caso de la cantada a que se devio le faltava agua? o estava tirando talves bueno a menos que la transmission no trabajava bien antes de la primer calentada estaria en mal estado pero si trabajo bien antes no tendra ningun problema. espero este comentario le ayude para ahorrar algo de dinero y trabajo buena suerte, informeme de lo que acontesca y grasias.
Feb 23, 2011 | 1998 Cadillac Catera
Tengo una lapto pavilon dv-2500 que no me deja arrancar ningun sistema operativo me pide un password que no me acuerdo de la clave. como podria reseteriar esa clave y que me inicie el sistema operativo ,,,...
Deberias abrir el portatil y reiniciar el sistema basico BIOS, es decir, acel clar CMOS, es bastante complicado y arriesgado, por lo que deberias ir en un sitio con un soporte tecnico informatico para que te solucionen el problema.
Muchas gracias por utilizar FixYa
Jan 19, 2011 | HP Pavilion 2500 Notebook
Hola,mi monitor SONY SDM-HS 73 -HA DEJADO DE FUNCIONAR -UN TECNICO AMIGO HA TESTADO Y ENCUENTRA EN LA PARTE DE LOS INVERTERS UN ELEMENTO QUEMADO-DICE QUE ESTA PLACA HAY QUE CAMBIAR ENTERA-COMO SE PIDE...
no estoy seguro pero creo que el problema esta en el circuito integrado GM2121 que esta precisamente en la placa que mencionas...ya que a pocos minutos de estar encendido recalienta mas de lo normal...
Aug 28, 2010 | Sony SDM-HS73P 17" LCD Monitor
MI PROYECTOR EMPIEZA A ENCENDER Y SE APAGA.
buenas noches. tengo un problema con mi proyector.. hace unos minutos encendio y se veia la imagen pero luego lo desconectaron y cuando volvi a encender solo prende la luz de power pero no sale la imagen quen podra ser???
Aug 29, 2009 | Dell 2200MP Multimedia Projector
Cuando enciendo me pide clave
Hola,
\Necesitas limpiar tu memoria cmos/bios para borrar claves de acceso y te permitan a tu disco inicializar el sistema operativo. Localiza la pila de alimentacion del cmos, el problema es que en ocaciones vienen bastante escondida al grado que necesitas remover tu motherboard para tener acceso a ella. remuevela por unos minutos, reconecta y al encender tendras que inicializar datos(fechas, hrs)
Podemos remover el password por $49 usd.
10001 buckwood ave 79925 El Paso Tx.
Contac us if you are interested
Thanks, please leave feedback
Vcrtech
support@vcrtech
vcrtech@hotmail.com
www.vcrtech.com
Apr 28, 2009 | Compaq Armada 1590DMT Notebook
Rubenhdzf@hotmail.com
I think your in SAP mode.....couldn't unstand a word your saying.
Dec 21, 2007 | Mitsubishi VS-50609 50" Rear Projection...
Dell Inspiron 700M Notebook Logo
345 people viewed this question
Clive
Clive
Alun Cox
