Aiwa z-m2700 midi system. we've had it for many years. the cds are not being read and it just keeps switching to the next disc..and it just keeps doing that. is it a problem with the lens? if so where can i arrange for repairs and how much roughly would it cost?
  • hipergogo May 01, 2009
    Ive the same problem it won"t read Cd's it just keeps skipping them
  • 1074 Answers
SOURCE: DVD Player reads Unreliably
your dvd needs to be serviced have a tech look at it, if that does not fix your problem replace your dvd for another one. good luck
Posted on Jan 06, 2008
SOURCE: aiwa nsx k570
i need the circuit diagram for the CD player in NSX K 570 Aiwa 3 CD changer music system . I am Located in mumbai colaba. 9819890987
Posted on Apr 15, 2008
  • 3422 Answers
SOURCE: Aiwa Compact Disc Stereo System Model- NSX-51G
see if the player tries to read the disc. Load a disc and listen.
Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track. Please refer to the image i have attached.
Posted on Jun 24, 2008
  • 15 Answers
SOURCE: My dvd player won't read the disc.
I had a similar problem with my Yamaha DVD player which just kept displaying "reading, reading and reading"- eject-no disc or disc error. I took it into be repaired and was told it needed a new optical lense-cost $120.00 plus fitting.I was told not viable to fix. Not convinced I had a look on the internet and a suggestion given was to buy a can of Air Spray from **** Smith,$14.00 later and blowing the proverbial out of the inside of the unit-Bingo it works for about an hour and then, away we go again-reading reading reading - eject-no disc. Back to the internet and i found a DVD technician who advised the more often than not the problem is a dirty optical lense, and he has saved 100's from the grave by the following method. The most effective way to clean it is with a cotton wool bud soaked in Isopropyl Alcohol and give it a good rub without damaging it. I got the Isopropyl alcohol for $12.00 a 250 ml bottle from the local chemist and did what was suggested. IT WORKED and is still going- not sure for how long but the bonus is I can use the remainder for rubbing down my tired old body, as after shave or a refresher, in addition to fixing DVD's so not all is lost. It's worth a try considering I was going to throw the Yamaha away. Thanks to the internet and the good people who share their knowledge I am happy again.
Hopefully it will work for you. If not, don't forget the other uses for the alcohol.
Posted on Mar 10, 2009
  • 133 Answers
SOURCE: cd tray stays open
There could be damage to the tray contact switches
(these tell to the control unit the position of the tray - open/closed), so that the control unit can start/stop and reverse the direction of the tray ejector motor.
These contacts are located somewhere underneath the tray (usually near the front unit cover), and since you mentioned that the tray was bumped while it was open, it is possible they were damaged. Also, the behaviour of the tray suggests that the control unit can no longer tell whether the tray is open or closed so it operates the tray motor in a wrong manner, which, again, points to these same contacts as the possible cause.
Repairing the contacts may be a somewhat delicate procedure, first you need to locate them (it may require partial disassemby of the tray mechanism), if they are bent a pair of tweezers might do the job, if there's hard damage, it's probably better to replace them (scrapped CD ROM units or a dead CD unit might be a good source, they just need to be of the same dimensions).
There may also be other causes for this malfunction, i just mentioned the first thing that i would check.
Hope this helps somehow.
3rq8 (Triarcuate)
Posted on Jul 16, 2009
I have an old Aiwa stereo with a 5-CD changer. The remote control has RC-7AS05 on it. How can I program the CD player to play the CDs continuously?
Press the RANDOM/REPEAT button and watch the unit's display. There will be a graphic changing to show the different functions: Disc repeat....All Repeat.
Try out the different modes unit you find the one that plays all the discs in the carousel.
Sep 16, 2014 | Aiwa Audio Players & Recorders
I have an old Aiwa NSX-V150M Compact Disc Stereo System. I cannot load CD's into the unit. Pressing the "Load" button causes the internal mechanism to cycle up and down 5 or 6 spaces and then a "CHECK"...
Hi! I also have an (old) NSX-V150M that does nearly the same, I suggest two problems on mine: 1) maybe the laser assy has to be changed because it doesn't detect the actual CD anymore and skips to the next one. 2) there is a tiny limiting switch on the moving platform that seems defective, or the rubber belt (?) is too stretched, so that it doesn't detect when the CD is in place from the changer. Then the unit starts again "CHECK"ing, as when the memorized list of CDs doesn't match the detected list of CDs. For the first one, maybe the Sony KSS210 or KSS213 spare part could be used, not sure of it. For the limiting switch, I have glued a match to keep it in place to keep the CD part quiet. Result: no more CD playing for now, but the unit doesn't "CHECK" anymore, and tuner and amplifier still work great. Need to look inside one of these days.
Jan 09, 2013 | Aiwa Audio Players & Recorders
I have my late husband's Pioneer PDF906, (100 disc capacity) and I created eleven music CDs on my computer which play perfectly in my computer, my car and my DVD player, but with the PDF906, only the...
The last 3 discs might be CD-RW which can be rewritten, but not all cd players will be able to read them. Just go to the store and buy some CD-R disks and re-burn the last 3 disks. That should solve your problem.
Jul 28, 2011 | Pioneer PD-F906 100-Disc CD Changer
The CD player does hardly read self- burnt audio CDs although every one of my other cheap Players i have at home or in the car can read them.
The answer depends upon the age and precise version of your Bose system. Not all CD players can reliably read CD-R and CD-RW discs, and even those which do are sometimes picky about the brand of recordable disc in use.
In my experience, all of the Bose Wave systems I've worked on have contained surprisingly cheap/average parts inside considering the luxury price-tag. Either stick to using other cheaper (and often far better) CD players for CDs you've burned yourself, or look into getting the CD laser pick up inside your Bose replaced with one which is known to have no issues with CDs of different reflectivity to standard pre-recorded CDs.
Jul 06, 2011 | Bose & Wave& Music System
Hi! I have a problem for reading CDs with an aiwa hifi system
the spindle motor goes bad a lot on these aiwa cd unit
May 12, 2010 | Aiwa NSX-DS55 CD Shelf System
Aiwa xd-dv370 doesn´t play lens cleaner disc
The lense of the player may have gone week, since you have been using it for a long time. Replacing lense will be a solution to this.
Jul 09, 2008 | Aiwa XD-DV370 DVD Player
Aiwa nsx k570
Mar 18, 2008 | Audio Players & Recorders
CD Changer
Common Problem with AIWA 3 disc machines. I have 3 in my service shop right now. For tray not rolling in on it's own, the drive rollers have to be changed, along with the Drive Belt. Also, for CD not reading, try CD lens cleaner.
Sep 10, 2006 | Aiwa NSX-A115 Shelf System
Won't read disc
The laser lens in your CD might be dirty or failing. Try the following solutions: Clean the laser lens with a DVD player lense cleaning disc. Lense cleaning discs are available at many electronics retail store. Sorry i can't help you more.
Dec 04, 2005 | Aiwa NSX-A115 Shelf System
221 people viewed this question
