Question about Cadet Manufacturing Hot One® RCP502S Heater
Need wiring diagram for cadet the hot one heater so i can install new fan motor
  • 4,356 Answers
You do not need a wiring diagram to replace the fan. TURN OFF POWER.
The fan will have two wires coming from it to two places. Make a little map of that location. There is usually a quick disconnect, you unplug and swap.
Posted on Nov 07, 2010
I have a 1987 mobile home with a coleman electric furnace model 3400-812. I need a wiring diagram for the repairman to use to rewiring all the new parts. He has installed a new fan blower motor, new...
5cd0d9d4-9d59-458b-ae93-d14f7aa016ab.jpg728c66bc-7660-4666-bc17-bdfa1b3130ed.jpgded744e2-3c31-4bc2-aec3-aa2d40664be6.png
I mean this respectfully, if the technician cannot wire a unit without a wiring diagram , he is not competent to do the work.
It is really very simple, If you look at the power lines entering a building, ther are but 2 hot legs of 115 volts for 230 volts and a earth / ground, every wire we will ever see are these 2 hot legs or a combination of them.
Every circuit requires 2 sides/legs of power, a device and a switch, begin at L1 go through switch to load return to opposite side of power from where you began, very simple.
If you do not know this a wiring diagram will tell him nothing but how to blindly try to follow some diagram he has no grasp of the theory behind or he would see how simple his dilamna is.
Oct 19, 2013 | Coleman Heating & Cooling
I bought a fan motor for my hp 2100, when i went to swap it i found the new fan had 1 less hot wire than the old 1. when i installed it, it does not work. could i have bought a 110 motor when i need a 220?
old motor has data needed for replacement. hp, sf ,rotation ,rpm, volts and amps.plus capacitor size required. the extra wire can be for a capacitor conection usaly brown in color and if you look at the label it will tell you how to eliminate the need for this wire.
Aug 21, 2013 | Hayward Heat - Pro 2100 Heat Pump Pool...
I am an electrical contractor of 20 yrs in spokane, Wa. I have used cadet heaters for most of that time. I have an apartment that I built and have rented out that is heated only by cadet heaters. In the...
i am also an electrician. we have had the same problems on our properties.the motor goes out which in turn keeps the element on and gets hot and burns up, setting a small fire. more smoke than fire. cadet needs to put a safety cut out so that when you lose the fan it shuts the element off and the other way around as well.
these are dangerous and will be replacing 100's of them
Jan 24, 2011 | Cadet Manufacturing Com-Pak Max CM202...
I need a diagram on abaseboard heater
The common usually goes staight to the unit, and the other wire, goes through the thermostat, and the ground wire hooks directly to the chasis of the heater.
If it is a 120 Volt, the white wire should be the common, and the black runs through the thermostat.
If it is a 220 Volt, it doesn't matter which wire goes through the thermostat.
Mar 31, 2010 | Cadet Manufacturing 6F1500W Baseboard...
I just need a wiring diagram---with a thermostat-- for a cadet FX-152 , 240 volt ,1500 watt wall heater
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Jan 15, 2010 | Cadet Manufacturing CADET SL Series Small...
I need to see a diagram on how to take apart and install a new wheel for pushing out the hot air to the outside.
Since you did not provide a make and model I cannot give you specific diagram or instructions. Here is the general procedure to replace a fan wheel that is attached to the shaft at one end of the motor.
Disconnect power. Remove drum drive belt from the small wheel at the motor. It should have a spring tension wheel that can be loosened to remove it. You shouldn ot have to remove the belt from around the drum. Remove the screws/bolts that hold the motor in place. Disconnect wiring if necessary. Keep track of what wire is connected to each terminal so you can reconnect easily. Lift the motor out and install the new fan wheel on the shaft (after removing the old wheel.) Reverse the procedure to re-install.
Jul 08, 2009 | Dryers
A diagram of how to install a heater fan in a 1992 pickup
well its an easy replacment unhook the power and ground wires on the motor remove the bolts and remove the motor install the new one
Jan 11, 2009 | 1991 Chevrolet K1500
Dayton model 3e473a
there's a high limit switch inline with the motor - may need replacing.
Dec 26, 2007 | Heating & Cooling
Install and hot wire heater
You can be assured that the element is 240 volt. The fan motor is also rated at 240 volt. the wires you have black - black are the connections you make to the line. Use a 12/2 with ground. Use a double pole 20 breaker in your panelbox. The green wire is the equipment ground - connect this to the bare wire from the 12/2. On the 12/2 cable - there will be two colors, one black and one white. Wrap a couple of turns of black tape on the white wire both at the heater location and on the white in the panelbox. connect the 12/2 to your 2 pole breaker, the black wire and the taped white to the breaker.
Sep 05, 2007 | Fahrenheat FFH1615 Heater
Cadet Manufacturing Hot One® RCP502S Heater Logo
418 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
