Question about Dell XPS 410 PC Desktop
Yes my dell xps 410 is barely used but the problem im having is when i turn it on that the picture is snowy u know like when the cable goes out or when you cant get no reception i cant get nothing on please any info will b helpfull thanks
    Novelist:
  • 109 Answers
That's a very strange problem. The typical problem with a monitor is that there is no signal, and so the screen goes into a "screen saver" mode. It sounds like it is behaving as if it were a TV. Does your computer have a TV tuner on it? Some models have this option. I'm just wondering if you might have accidentally changed something. Was it working fine up until just now?
Posted on Nov 07, 2010
Dell xps 410 desktop: trying to restore to factory settings. Operating system is Windows Vista. I know to get to the restore menu its f8 for vista,however the choice
That is a problem, did you happen to make a recovery DVD disc? if so! you are in business, but if you did not contact Dell's customer support and technical department, they may have a solution.
Mar 27, 2012 | Dell XPS 410 PC Desktop
My dell xps 410 will not go online thru either of the ethernet ports on the computer. im using my phone with usb tether and it goes online fine. it says it need the ethernet controller driver but...
Hello, look at this link, you should have installed the bottom driver, but take care! if you've got a LAN card as well, you might have got the MOBO one disabled in bios, so best to take out the LAN card, find out what it is and look for a driver for it, meanwhile, with it removed, install the LAN driver for the MOBO LAN port, (bottom driver on this link ) and see if it appears in your 'Network Connections' (Check in bios to see if it's been disabled, though)
Regards, nicam49
The link: http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=DIM_PNT_9200_XPS_410&os=WW1&osl=en&catid=&impid=
Aug 22, 2011 | Dell XPS 410 PC Desktop
Have a Dell XPS 410 with 32 OS. Want to upgrade to a 64 OS. Need info
With the 410, you will need much more RAM before having a 64 bit OS becomes useful. I assume that you have the default 2GB. In any case, all you need is to buy a x64 OS and install it.
Jul 09, 2010 | Dell XPS 410 PC Desktop
Blinking yellow power button xps 410 will not turn on
I suggest replacing the memory as the diagnostics lights suggest.
Memory can and does fail in some cases.
May 04, 2010 | Dell XPS 410 PC Desktop
XPS/Dimension 410/9200 Desktop, And Virtual Memory!!!!
you can set your virtual memory as high as 512 depending on what you want to do with your pc are you gamer if so reduce that setting if not and you using it for applications setting it higher will acheive better results.
Jan 26, 2010 | Dell XPS 410 PC Desktop
I had to install a new motherboard in my xps 410 i used all the parts from the old one when i turned it on i tells me (system dose not support the installed processor ) the motherboard is the same one as...
Yes, it's the BIOS at fault here. Use an older processor (anyone as long it fits the socket will do) to run it for now.
To update the BIOS you have 2 options: 1 - install completely (drivers, programs ,all) Windows, go to Dell and download (as in Save, not Run) the BIOS update utility (it's an exe) unto your pc, boot into Safe Mode and run it. This way has the advantage that is easy but you might stumble into problems with the WGA  - you might have to reactivate windows by phone.
2 - use the linux way - http://liquidat.wordpress.com/2007/05/20/howto-update-bios-on-linux/   For that you will need at least basic knowledge of command line operations - practically you will have to manually input 2 commands: one to goto the file ( cd place_of_file) the other to exectute it (run name_of_file). Best way if you know what you're doing it.
Oct 25, 2009 | Dell XPS 410 PC Desktop
Have dell xps 410 was on a network took it off now pinter wont
Click on HP's link http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=303756&lang=en& and select your Operating System. Then Download the driver for your printer. Follow the Instructions and Install it.
Oct 21, 2009 | Dell XPS 410 PC Desktop
DVD burner won't burn using Premier Pro.
have you set it as your primary recording device under options?
Sep 21, 2009 | Dell XPS 410 PC Desktop
Dell XPS 410 PC Desktop Logo
99 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
