Question about Cozy (W352E) Heater
Where I do I light the pilot light on my Cozy Wall Heater? I know it needs to be lit somewhere on the bottom of the unit but I cannot find the spot and my heater will not turn on. I am a senior and not very technical but I watch the PG&E service man light it once so I thought I could remember but I simply don't. Any advice?
  • 4 Answers
In front of the burner it is next to a copper tube(black if it has been burned)! it angles a little towards the copper tube! u turn the knob on gas valve to pilot then hold down and light hold for one minute then turn it to the on position (u might have to push down slightly as u turn the knob) make sure u have thermostat to the lowest setting before u light the pilot so it won't turn on while u have your face too close to the heater then turn your thermostat up to desired temperature when it is on the the on position! Good Luck!!
Posted on Nov 08, 2010
Help! I have a cozy wall heater model W355F-D. I have never ever lit a pilot light in my life and honestly, Im a little nervous. Can you maybe help me and walk me through it?
You should have control knob on the gas valve that has off, pilot and on , turn knob to pilot and hold in you should have igniter button press this in and it will spark at the pilot you may have to press this a few time to get pilot to light . when pilot is alight still hold knob in for 30 seconds then turn to the on position .
Nov 19, 2016 | Cozy Heating & Cooling
Cozy dual wall heater, makes loud noise and shakes heart when it starts
check gas pressure, natural gas 3.5 and propane 11, also if you have stainless steel burners drill out the first series of holes on the carry over tube to match other holes use 1/64 drill bit.
Feb 27, 2015 | Cozy Heating & Cooling
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
The pilot will not stay lit in our Cozy Direct Vent Wall Furnace CDV335B. Problem occurs with winds. Last heating season, replaced powerpile, thermostat, ignitor, gas valve, and pilot burner. Any...
There is a wind shield for this unit, call 502-589-5380 and ask for a drawing for the wind shield and have it made out of 26 gauge sheet metal.
Nov 27, 2010 | Cozy (W352E) Heater
I have a cozy gas heater in my converted garage, and it won't stay lit any longer. I light it, but by the next morning the pilot is out and the room is cold. What part would I need to fix it? Thank...
if you can re-light the unit all parts are good,if the vent pipe is ran thru the side wall and up this is the problem the vent temps on these unit are low which can not over come the cold air and can not start a draw ans backs into the unit and puts out the pilot.
Oct 05, 2010 | Cozy Enclosed Front Console Heater 70,000...
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Pilot lights fine, furnace fires up, when it turns off the pilot goes out
need to have at least 3 feet of vent out of the roof, if it is to low the coll air will cold soak down to the pilot and shut it down.
Nov 08, 2008 | Cozy (W352E) Heater
Cozy dual sided wall heater
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Dec 19, 2007 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
157 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
