Question about Canon PIXMA MP160 All-In-One InkJet Printer
After I finished printing and was still using the printer, it turned off and quit working. I really think it just the power supply but how do I go about replacing just that? However and suggestions will be helpful.
  • 197 Answers
You'll need to check for accessories by that model
Posted on Jun 15, 2008
Printer won't turn on
Best bet is a low voltage power supply (assuming it is a laser printer), but without knowing what kind of printer it is specifically I can not provide any more details than that.
Jul 24, 2015 | Office Equipment & Supplies
Stylus R220. Just replaced the black ink and it still won't let me print. Keeps saying REPLACE CARTRIDGE. I'm using a Mac. Supply Levels Utility is completely useless. Says Information Not...
Try to clean cartrige and cartrige carrier conector place with soft erager.Then put cartrige into cartrige holder then gentaly push top of the cartrige sothat a `cat' sound happend, then turn on printer.
I think you will relive
Thank you
Sep 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Last night I have given print with my printer after finishing my print job i turned it off. but today when i try to power it on but i can't. I don't understand why this happening.
check the power chord of your printer. You can it by the use of multi tester by testing end to end of the power chord. If the power chord is good check the fuse of the printer. If the fuse is good there possible that there is trouble on power supply of your printer which is need to open your printer and test all the electronics components inside.
Aug 08, 2011 | Epson LQ-2180 Dot Matrix Printer
Lexmark x75 all in one. Started with communications device error. could not print. went through troubleshooting-still wouldn't print. started printing randomly(not initiated by me). Couldn't clear print...
Hi. That's quite a problem you have there. Have your attention first on the power supply. It does get hot but it's unusual if it gets very hot. Take out the power supply (the black box behind the printer where the power cord is attached). Check the power specifications. Most of the Lexmark power supply has input ranging from 120-240 Volts and an output of 30 Volts. Make sure you're plugging it in the right voltage range. Check if you're using power surge protectors or power strip, disconnect it and plug directly into a properly grounded wall outlet. Power surge protectors can also draw power away from the printer. When everything's well, try printing again. Hope this helps.
Mar 18, 2010 | Lexmark X75 All-In-One InkJet Printer
Printer problems
Not good, ma'am.
Try unplugging the power cord for 10 seconds.
Remove the toner cartridge, look for a jam.
Make sure the paper supply is pushed forward.
Jan 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
Printer not communicating with computer
(1) Try a power cycle: Try turning the printer off, then unplug the power supply from the printer, then unplug the USB cable from the printer then the back of the computer; wait 30 second; then plug the USB cable back into the computer, then back into the printer then plug the power supply back into the printer and turn it on – run a test print: Start>Settings>Printers>Right-click on the printer>Properties>Print Test Page
(2) Update the USB drivers
Jan 01, 2009 | Lexmark X5470 All-In-One InkJet Printer
Out of toner........ but not really.....
Print a Supplies Status page to see the actual pages printed...
To print the Supplies Status page from the printer, on the printer control panel, select
Reports Menu, Supplies Status, and then Print Supplies Status page.
If the page count from the Supplies Status page indicates that the toner should not be in need of replacement then you have a bad cartridge. Actually, the cartridge is probably fine but the chip on the cartridge has got a problem. Return the cartridge to O.D. and get another one. Unfortunately, chips that don't work properly in not all that unusual so HP has a pretty easy return policy.
Hope this helps.
Mar 07, 2008 | HP Color LaserJet 2600n Printer
Printer won't print
paper start to feed but after some time not working
Nov 15, 2007 | HP LaserJet 1100 Printer
Printer Problem
power supply is probably faulty on the printer
Jul 11, 2007 | HP DesignJet 10ps InkJet Printer
Printer won't release patper after printing
Print a self-test page from the unit to verify that it is working correctly. On the unit front panel, press Setup, press 1, and then press 5. CAUTION: Jammed paper must be removed using the rear access door with the power cord disconnected to avoid mechanical damage. Do not remove jammed paper from the front of the unit. Turn off the HP product and turn it around so the back of the unit faces you. Disconnect the power cord from the back of the all-in-one. The power cord must be disconnected to allow the paper feed rollers to turn freely. Locate and open the rear access door by pressing in on the left side tab and then pulling the door toward you. Figure 2: Removing the rear access door Inspect the pressure rollers on the rear access door and verify that they are clean and turn freely. Clean the rollers if needed with a soft towel lightly moistened with water. If the rollers do not turn freely, replace the rear access door. Click How to Buy on this page to order replacement parts. From the rear access door opening, remove the jammed paper. Remove the remaining paper from the paper supply tray. Discard any paper that is damaged or crumpled and then re-stack and reload the paper into the paper supply tray. Reinstall the rear access door. Reconnect the power cord to the unit and turn the unit on. Ray
Jun 18, 2007 | HP Officejet 4215v All-in-One Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
16 people viewed this question
old marine
old marine
