Question about RCA HD56W66 56" HDTV
No power at all no lights or anything. replaced the power fuse which was blown still no power rca hd56w66 also replced dp410&dp411 diodes and the fl100 fuse
  • RCA Master
  • 8,457 Answers
The whole dawn power supply board is shorted and dead.U have the equipments,a good trouble shooting and electronic skills,trouble shoot all those transformers out put,check all the primary and secondary out put of those coils of those power transformers?Some of those power tranformers are dead needed replacement.Or try website like Tvrepairworld.com to buy a whole refurbish power supply board for the replacement
Posted on Nov 07, 2010
What would cause my magnum 257 not to power up or turn on?
the power wires not being heavy enough.blown fuses reverse polarity diode blown. overpower diodes blown.lean towards the overpower diodes.
Jul 01, 2012 | Radio Communications
HD56W66 powers on screen flashes foe a few sec.
On your Deflection board Look for Bad capacitors CP150 2200uf 16v CP114 CP120 in same circuit they will be puffed up on top if they are replace all 3 capacitors.other 2 are 220uf 35v and 330uf 35v
Mar 17, 2010 | RCA HD56W66 56" HDTV
Rca hd56w66 convergence problem. ladywinn said it was a fuse where do i get replacement fuses?
that tv has a convergence module and a convergence power supply it also has a block fuse on sweep module but i can promise you replacing a fuse will not correct your prob. the fuse is there for a reason if it opens there is a prob.but i dought its opened its located on sweep module there will be 3 block fuess in a row on the left side of the sweep module they are small red blocks good luck
Feb 03, 2010 | RCA HD56W66 56" HDTV
Rca hd56w66 no power not even the green light power board looks good suggestions to find the problem?
Check the fuse. Its located on the right side looking in the rear of the TV its the small board where the power cord plugs into. The fuse is on that board.
Jan 01, 2010 | RCA HD56W66 56" HDTV
RCA Model# HD56W66
If you do not even get the power light to come on-start at the beginning---follow the power cord into the set and look for the fuse--this is where to start.
Let me say something to you? I am more than happy to help you--the reason I am here.
If this set had a shutdown problem the light for power would still come on---The typical resolution is to start where the power (120 volts ac comes in) and see what you have.
All these sets are very well protected--if you had a power outage or lost power and do not even get a click or the power light coming on you may be a lucky person---a completely dead set is better than one that has the power light on but does not work.
Let me know what you find--ask me questions--I am here to help but the more you can tell me the better the chance I can help you.
If this helped you rate this solution as I do this here for free.
Remember: Any questions let me know.!!!
Regards, SD TECH
Dec 18, 2009 | RCA HD56W66 56" HDTV
RCA hd56w66
DO YOU STILL NEED HELP WITH YOUR TV IF SO ,I WILL TRY AND HELP! First ck capacitors cp150 cp114 cp120 2200uf 16v and 220uf 35v if 150 is puffed up on top replace all 3 capacitors also ck Ribbon connectors there is 2 of them thst conect deflection board to SSB board. resolder all pinns on FBT flyback transfomer.
May 28, 2009 | RCA HD56W66 56" HDTV
RCA TV blown fuse
Hi
you have bad Rectifier Diode or Ic regulator.. check first the unregulated power supply before you go to regulated power section! then check,.
Thanks!
Likha
Oct 23, 2008 | RCA F27242GY 27" TV
FL231 fuse on RCA hd56w66??
the rca itc222 comes in both 56 and 52 version.. If you do not have the convergence option in the customer menu under setup then there is a high chance that the fuse will be the trouble
Oct 02, 2008 | RCA HD56W66 56" HDTV
Distorted Screen for RCA HD56w66
convergence is the problem. first question do you have convergence in the customer setup menu. if you do not it could be a special small fuse if you do have "convergence" in the setup menu then you most likely have a convergence power board issue. and generally they are replaced. in our shop such board replacement average 124 labor and about 100 for part. if the fuse bout 15 for part and 80 for labor. there are solder connection that cause the blown fuse
Feb 20, 2008 | RCA HD56W66 56" HDTV
Neff combi blown diode.
If the diode failed by opening, there may be no other damage. If the dioded failed by shorting, the alternating current may have damaged other components. Ohm it out. You can get diodes from digikey.com, mouser.com, or radio shack or any electronics or appliance supply. If the diode is charred and you can't get the part number, the oven rating can be used to select a replacement. Since the fuse was 10 amps, the diode should also handle at least 10 amps. If you can power the unit and read the voltage at the diode input this will give you the power (volts times amps). It's always worth trying as it's cheaper than replacing the unit.
Oct 14, 2007 | Neff H7871N2GB Convection / Microwave Oven
RCA HD56W66 56" HDTV Logo
90 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
