Is it possible for a washing machine motor or other part to leak anything toxic such as any lubricants or other solutions?
  • 4,349 Answers
Yes, there are bearings and they use grease, so when they die, grease escapes. usually this or rust is all that happens in the tub, which I presume is your issue.
Below the machine there are more items, but they do not affect the inside of the tub..
the transmissions have lube that drips under the machine, and belts leave a really black material around...
Posted on Nov 07, 2010
What does it mean when a washing machine motor hums and does not move until you push it?
Disconnect the power locate the motor. Remove the belt. Try turning the motor by hand that's a turn kind of hard lubricate both spindles with some WD-40 maybe even some penetrating oil then turn it as you spread if it loosens up you know it was a lubrication problem if not then you have to replace motor or the bel remove the belt. Try turning the motor by hand is a turn kind of hard lubricate both spindles with some WD-40 maybe even some penetrating oil then turn it as you spread if it loosens up you know it was lubrication problem if not then you maybhave to replace motor
Aug 02, 2015 | Washing Machines
Leaking washing machine
the seal round the cap on the filter is possibly damaged solution is new filter housing or complete pump assydo not overtighten they are fairly straight forward to fit hope this helps
May 06, 2014 | Candy Washing Machines
Finding a non-toxic lubricant
It would be fine to use a "toxic" lubricant as long as it wasn't oil based. Also, run the washer at least three to four times empty before using it on dishes.
Feb 23, 2014 | GE Nautilus 24" Built-in Dishwasher
Airpot problems
Lube the moving parts with crisco shortning. See if it is leaking air. The crisco should seal and lube it. Also using crisco wont cause any issues with a lubricant that is toxic.
Jul 12, 2013 | Update International Psvl30bksf 3. Liter...
Older model washer will not ajataite
Possible that there is no output to the motor from the program controller while the cycle come to the mode of spin/wash.
You need to check the voltage to the motor, if there is no voltage the controller is faulty. If the motor hums then check for faulty capacitor or FRICTION on the spindle. If so remove and reset with lubrication.
Jan 24, 2013 | GE Profile WPRE6150KWT Colossal Capacity...
Error code e7 on trojen staminia 310 - already tried switching off and on again. I washed machine and mistakenly got the motor wet.
see the next steps. God bless you
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Nov 16, 2012 | Exercise & Fitness
Admiral Top loader leaking water
water inlet vale has internal malfunction
Jul 20, 2008 | Admiral AW22 Top Load Washer
Leaking
Inspect the hose that connects the drum to the pump for leaks.
Oct 11, 2007 | Maytag MAV7600 Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
