Question about Sharp Microwave Ovens
Sharp Microwave/Convection vintage 1994, model # 9H84B turntable has suddenly stopped turning. When functioning, table could start rotation in either direction.
  • Sharp Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Nov 07, 2010
Sharp carousel ii microwave
Turn table does not turn , sharp convection microwave R-9H84B
Can I fix this myself? or do I need to have it serviced?
Dec 06, 2013 | Sharp Microwave Ovens
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
I have a Sharp convection over model R-9H84B and the turntable piece is broken. One of it's three tabs is broken off so it will no longer turn the table. Do you know where I could get one of these?...
They aren't cheap, but I found them here:
http://www.repairclinic.com/PartDetail/Glass-Tray-Drive-Coupling/1266724
I was looking because after 15 years, my drive coupling cracked out where it connects to the turn table motor. Getting it out isn't that difficult - just remember to unplug the oven before you work on it. If the old coupler won't come out with gentle and even prying, flip the oven upside down - there is a small door on the bottom help shut with a single philips (+) screw which will give you access to the motor. Remove the two philips screws and lift the motor out and then use your screw driver to gently encourage the coupler out. I found removing the motor was the easiest way to install the new coupler - install the coupler then the motor while holding the coupler in upside down. I have the model with the door opening like a conventional oven door and it will not want to stay open for you while the oven is upside down. Either have some one hold it open while you have an arm in there or be prepared to have your arm squeezed a bit.
Cheers,
David
Oct 24, 2010 | Sharp R-9H84B Microwave Oven
We have a sharp r-9h84b convection microwave and the carosel has stopped working when the tray is in place. Any thoughts the carrosel seems to rotate very slowly when there is nothing on it.
It's almost certainly a bad turntable motor.
The part number was RMOTDA079WRE0 but it is listed as no longer available.
In some cases, older microwaves are available locally at repair shops or on Craig's List.
If you want to keep your eyes open, this same motor was used in the following Sharp models:
R9A20
R9A50
R9H11
R9H60
R9H66
R9H71
R9H73
R9H76
R9H80
R9H81
R9H81B
R9H83
R9H84
R9H84B
R9H91
R9H91B
R9H93
R9H94
R9H94B
Good luck.
May 23, 2010 | Sharp R-9H84B Microwave Oven
Turntable has stopped turning
Remove the turntable plate from the oven. Put a cup of water inside the oven, away from the turntable drive gear. Turn the oven on and look through the door to see if the drive gear is turning. If not, then the motor is probably defective and needs to be replaced.
Nov 15, 2009 | Sharp R-303CW Convection / Microwave Oven
R9H84B Sharp Microwave Convection from 6-6-1997, power stopped and turntable stopped. Light works and sounds like the power is working but nothing gets hot.
Is this the unit with the door that swings down like a conventional oven?? I think it is. This sounds like a door switch but could be a magnetron or cook relay on the control PCB.
Sep 11, 2009 | Sharp R-9H84B Microwave Oven
Faulty microwave function on the SHARP R-957 model (900watt)
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 10, 2008 | Sharp R-930AK Convection/Microwave Oven
Sharp Carousel Model R-9H56
Check that the plastic connector from your motor to the turn table is not broken , mine broke and it took weeks to solve the problem. Try rotating the part that protrude into the oven. If you can turn it by hand it is broken, lucky cheap to replace
Nov 21, 2007 | Sharp R-510HW Microwave Oven
Microwave Ovens Logo
135 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
