Question about Sony Ericsson P910i Cellular Phone
Virtual keyboard flip open... i cannot use the virtual keyboard to type in characters... it just popped up INFORMATION Corrupt... how can i ever use it again...
  • ALJHED Sep 12, 2008
    sony ericsson p990 flip open... i cannot use the virtual keyboard to type in characters...
    it just popped up &. how can i ever use it again
    President:
  • 1,944 Answers
I would back up all my data and try a master reset of the phone. If this doesn't help, I would try to flash the firmware.
http://www.sonyericsson.com/cws/support/softwaredownloads/detailed/updateservice/p990i?cc=gb&lc=en
Posted on Jun 18, 2008
..can i ask something? can the virtual keyboard of
HI, SORRY TO INFORM YOU THAT THERE IS NO SENSOR FOR SAMSUNG S8300 Ultra Touch platinium-red Cell Phone still. please don't forget to vote me.
goodluck.........
Jan 21, 2011 | Samsung S8300 Ultra Touch platinium-red...
Tip
Short cut keys for Blackberry phone,storm,curve,pearl.bold
Typing shortcuts keys for BlackBerry
These shortcuts keys can be used when typing text in Blackberry:
  • If you want to type the alternate character on a key, hold the Alt key and press the character key.
  • For an accented or special character, hold the letter key and roll the trackball left or right. Click a selected character.
  • To type a symbol, press the Symbol key. To view more symbols, press the Symbol key again. Type the letter that appears below the symbol to insert the corresponding symbol.
  • To insert a period (.), press the Space key twice. The next letter is capitalized.
  • To capitalize a letter, hold the letter key until the capitalized letter appears.
  • To turn NUM lock on, hold the Shift key and press the Alt key.
  • To turn NUM lock off, press the Alt key.
  • To insert an at sign (@) or a period (.) in an email address field, press the Space key.
  • To type a number in a number field, press a number key. You do not need to press the Alt key.
  • In order to type a number in a password field, hold the Alt key and press the number key.
  • To type a letter in a number field, hold the Alt key and use the multi-tap input method to insert the letter.
  • If you are typing input languages, hold the Alt key and press the Enter key. Select a language, then release the Alt key.
Know more about Windows 7
Windows 7 keyboard Shortcuts
on Dec 05, 2009 | Cell Phones
When i slide my phone open to use the keyboard the screen goes blank and the phone turns off. what is happening and can it be fixed?
The problem is from the flex of the phone.
The flex is the mechanism that assists the phone in flipping.
It is faulty and is not allowing the free flow if information from the board of the screen side of the phone.
so it seizes whenever you slide the phone.
it can be fixed.
all you have to do is replace the flex and it will work perfectly again.
take care
Jun 18, 2010 | LG Neon GT365 Cell Phone
How do i replace flex cable on a razor phone can u show video
Ok..#1.take the battery out..
then youll have to remove the 2 screws that hold the modem part of the phone in.gently pryup on the modem ,on the side with out the usb charger port..slip a thin flat tipp screw driver in there and slide it towards the bottom of the phone. there are littler plastic clips carefull not to break them.then youll see where the bottom of the flex cable plugs in.unplug it.then flip the phone over,in the 4 cornors of the screen side of the flip there are tiny little rubber plugs. pop them out and undo the screws in there.near the top of the screen there is a little slot on the right side of the screen ..gently pop the cover off the screen..unplug the flex cable from the screen.and carefully remove the screen.be careful not to damage the buttons on the sides of the screen.then close the flip and turn the phone over..looking into the battery part of the phone,on the top right hand side of the hindge there is another little screw,remove that.then again turn the phone over and stick a flat tip screw driver into the open hole and pop the chrome roller out.then very carefully youll be able to seperate the 2 halfs. look on the back side of the keyboard youll see little metal tabs folded over that holds the key board in place..the keyboard and the flex cable are one piece, just revers the procedure to replace.." BE VERY CAREFUL RUNNING THE FLEX CABLE THREW THE HINGE AS IT CAN DAMAGE VERY EASLY." IF YOU NEED MORE ASSISNT CONTACT WWW.PHOENIXTEC.CA they are very helpful
May 11, 2010 | Motorola Mobility RAZR V3
Motorla razr v3xx
well pop the back off ,remove the battery.then there are 2 screws that hold the modem in place.remove them and very carefully pry the modem off.there are 2 plastic tabs near the bottom of the phone 1 on each side.careful or they will break.`then there are 4 screws on each side of the screen,when opened..they are under little rubber pucks.remove them and separate the 2 half's..Unplug the flex cable from the screen and carefully remove the screen and camera assembly.be carefully not to tear off the flex cables that hold the 3 buttons on the screen in..then if you'll turn the phone back over.where the battery goes in on the hinge .you'll see another screw.remove that and flip the phone over again.carefully pop the chrome hinge pin out.then you'll be able to separate the 2 half's.then there are 6 little metal tabs that hold the keyboard in place.pry them up and carefully remove the keyboard and flex cable.careful around the hinge,where the flex cable runs threw.
now moving on to the modem, on the bottom you'll see 2 little plastic tabs carefully open them and remove the brass retaining wire and the modem will then come out..get your new covers and reverse this process and you'll be good to go.
May 11, 2010 | Motorola Mobility RAZR V3xx Cellular Phone
Uncaught exception: java.lang.nullpo inter exception note keeps coming up
Hi, you get this error message when attempting to access a corrupt contact list database on the BlackBerry smartphone, BlackBerry Device Software or software application component has failed, or there is corrupt data from a wired or wireless synchronization.
Isolate the corrupt data by turning on advanced logging for Intellisync
1) Turn on advanced logging for Intellisync.
2) Once the corrupt data entry has been isolated, delete it from the desktop email client and the BlackBerry smartphone.
3) Synchronize again.
Clear the contact list database on the BlackBerry smartphone.
1) Open BlackBerry Desktop Manager.
2) Click Backup and Restore, and then select Advanced.
3) From the Device Databases list, select Address Book, and then click Clear.
4) Return to the BlackBerry Desktop Manager window.
5) Synchronize the contact list with the correct translator in Intellisync.
I hope this information will help you
Nov 17, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Qwerty key issues
try running a megnet over the back of the screen when you slide it open, it worked for mine
Sep 27, 2009 | LG Xenon GR500 Cell Phone
My blitz doesnt text
Try this. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Hope this helps, let me know if this works or if I can help you with anything else.
JimmyC
Aug 05, 2009 | UTStarcom Blitz Cell Phone
Keyboard will not work
Try this and see if this works for you. Touch Keypad simulates a wireless phone keypad on the touch screen to allow you to enter text, numbers, and symbols just as if you were using a wireless phone keypad. Touch Keyboard simulates a 20-key QWERTY (typewriter) keyboard on the touch screen to allow you to enter text, numbers, and symbols similar to the way you would using a QWERTY keyboard. To use Touch Keypad or Touch Keyboard:  In a program, tap the Input Selector arrow, and then tap Touch Keypad or Touch Keyboard. To type lowercase letters, tap the keys on the dial pad or keyboard. To type a single uppercase letter, tap the Shift key and then tap the corresponding key. To type all uppercase letters, tap the Shift key twice. To change back to all lowercase letters, tap again. To enter a space after the word, tap the Space key. To start a new line, tap the Enter key. To backspace and delete a single character in any input mode, press the Back key. To open the Symbol pad, tap the Symbol key. To change the input mode:  Tap the Input mode key to switch to a different input mode: XT9 (predictive), Multitap (abc), or Numeric (123).
Let me know if this works for you, if not let me know.
JimmyC
May 07, 2009 | UTStarcom Blitz Cell Phone
Nokia n80 keyboard problem
These symptoms are showing that the T9 dixtionary is activated o fur phone, u just open message setting option and turn off ur t 9 dictionary
Oct 03, 2007 | Nokia N80 Cellular Phone
Sony Ericsson P910i Cellular Phone Logo
139 people viewed this question
Top Sony Ericsson Cell Phones Experts
Prashant  Sharma
Prashant Sharma
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
