Question about Battery Technology Battery Averatec 3700 3800 Liion Repl SA2008001 2305026000 (AV3700)
Its true if not working the fan of processor not working the unit ???
    Scholar:
  • 33 Answers
Yes and no.
If the fan is not working, the unit will still work, but get very hot. If the laptop won't power on, the fan won't work, either.
Can you elaborate on this? Sounds like you got a replacement battery and the system is still not working. Can you remove the battery, but plug in the external power supply, and then power on the laptop? If the laptop comes on then the problem is not the battery. The problem is with the motherboard.
If it won't power on, as described above, you either have a bad power supply or a dead motherboard. Both can be replaced. You will have to do a search on the Internet to find a good replacement motherboard. The power supply is available to Office Depot, Staples, etc. and can be purchased around $80. The price on the motherboard depends on the supplier.
Hope this helps.
Posted on Nov 07, 2010
Previous CPU Fan failure
You have me at a loss
"Previous CPU fan failure", and What?
1) Was the Processor fan replaced?
2) Was the top of the Processor, and bottom of the Heatsink properly cleaned, and fresh, new Thermal Paste PROPERLY applied?
3) Is there a CMOS Error Code stored now?
4) Will Mary ever find true love, and will Biff return home?
Just wanted to see if you were following along
Clarify further as to what the problem is.
Post back in a Comment.
Regards,
joecoolvette
Mar 07, 2013 | Dell OptiPlex 760 PC Desktop
Computer was running . but the processor area was very dusty so i open the processor fan and clean then i locked the fan and when i on the computer then fan some moves then stop.what i do
how did you lock the fan ?
you might need to replace the fan
check the power lead/s to the fan
this could be a problem with your power supply unit and electrical leads
if the PSU units fan is not working the psu is fauty
check all leads that attach from motherboard to you hard drive
check that your dc/dvd drives are working
make sure the electrical leads and connections are secure
and clean all dust from electrical connections
hope this helps
Oct 12, 2011 | Intel D945GCNL Motherboard
The heater fan won't stop, even if i turn off the key the fan still turn, unable to control it, it only turn at one speed (not the fastest one), i check the resistor it look like there's a short in it, the...
Your impala doesn't have a resistor , it has a blower motor control processor and it doesn't work the way you think it does
Chevy Trailblazer EXT Blower Motor Won Turn Off
Blower Motor Control Processor
The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module provides a PWM signal to the control processor in order to command the blower motor speed. The processor supplies 12 volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
HVAC Blower Motor Circuit
May 27, 2017 | Chevrolet Impala Cars & Trucks
TRUE GDM 26 merchandiser has sealed lines to the freeon and cant access. The fan blows warm air and all the lights work. It just doesnt cool.The compressor was cleaned only 2Xs in 3 years.
What do you mean the compressor was cleaned. It sounds to me you need to clean out the condenser coil. free it from all dust and debris. + Does the compressor work and what gas is in the system, does the condenser fan work. I'm assuming that when you say the fan works, it is the evaporator fan inside the cabinet working. You will have access the condenser fan either from the front or rear of the unit. The condenser unit is normally extracted from the rear. it should slide out but take care not to kink any of the pipework.
Apr 17, 2010 | True GDM-26 Refrigerator
Thermal occurrence, the computer keeps shutting down and sending a message of thermal occurrence.
It is very likely that your computer has excessive dust keeping the fans from distributing air for cooling within the unit. It can also be an issue with the power supply fan not working. First, verify the fan is turning properly. If not, replace the power supply. The same thing can be true for the cooling fan for the processor. Check to make sure it is running. To do so will require you to look at it with the side cover off and computer running thus posing a RISK of ELECTRICAL SHOCK. UNLESS YOU ARE CLEARLY VERSED IN HOW TO DO THIS, I ADVISE TAKING IT TO A COMPUTER STORE.
If these two fans are working properly, cleaning the dust inside the computer is the next step.
Disconnect electrical cord from the computer, ground yourself by touching the case to eliminate static electricity, remove side cover from the computer.
Using "canned air" widely available at computer or office supply stores, blow out the dust from the power supply and interior of the computer.
Oct 02, 2009 | Dell Computers & Internet
Top fan on True T19 noisy
no all the fans have to be working for the unit to work correctly
Feb 22, 2009 | True T-49 Side by Side Refrigerator...
Computer freezes constantly - has to be hard rebooted
HI it can be true if the fan stops processor overheat to prevent overheat. it should work all the time (when your pc is on ;))
Aug 15, 2008 | IBM ThinkPad T30 2366 Notebook
Fan stopped
If the fan has stopped, then the processor will overheat. Most vendors have protection so that a non-working fan is detected and the unit will not power up with detecting its rotation. Seems like a repair shop job I'm afraid.
Nov 25, 2007 | Toshiba Satellite A135-S2276 Notebook
Battery Technology Battery Averatec 3700 3800 Liion Repl SA2008001 2305026000 (AV3700) Logo
Top Battery Technology Computers & Internet Experts
Alun Cox
Computer Links
Terry Schallert
Are you a Battery Technology Computer and Internet Expert? Answer questions, earn points and help others
