Question about Mitsubishi LT37131 37 in. HDTV LCD Television
My Mitsubishi LT-37131 was damaged when my electrical circuit lost the neutral wire. The voltage going to the tv was 250 volts between the hot and the neutral. The tv will not turn on and it it doesn't even have a power available light. I did look inside and verified that the glass fuse is good. Which board would you suspect is damaged?
  • 11,361 Answers
It should have MOV (130~150V rating) across the Line and Neutral after the fuse, unless this TV was made to work from 100~240v range. You should check to see if the 5vdc standby is evev working right now, withot it, nothing else will happen. Checkt the DC voltage on the large electrolytic cap (the one with 150~300uF 350~450VDC rating) in the AC primary side, it should be connected to the bridge rectifier, it should have around 160vdc (120v x 1.414) on it.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 07, 2010
I replaced the starter relay on my 2007 2.7 dodge charger and it still won't start
Well you need to go here www.bbbind.com for free wiring diagrams , an then go to youtube an watch a few different videos on starter system trouble shooting .An voltage drop testing an basic electrical system testing . Then you need a DVOM - digital volt ohm meter , an do some testing . rather then having people on here tell you it could be this or that , you have to test . Oh yea check out how to test a relay .
Nov 23, 2015 | Dodge Cars & Trucks
Frigadare Dryer
Basic Dryer Electrical
Electric dryers in the US operate on two 110 volt A/C circuits. The two 110 volt circuits combine to deliver 220 volts A/C to the dryer heater. 2-dryer-plugs.gifSee the basic dryer heat circuit. The dryer motor operates on 110volts A/C. Dryer receptacles have an L-shaped neutral post. You can check the voltage to your dryer by slightly sliding the cord out of the receptacle and using the leads from a multi meter to check for voltage on the blades of the cord that slide into the receptacle. Between the left and the right blades you should read 220 volts. Between the left or right blade to the center blade (the L-shaped blade) you should read 110 volts AC. The 4-post receptacle above has the L-shaped neutral and a seperate ground. It requires a 4 wire cord and the ground wire is isolated from the neutral on the dryer.
Technicians check for voltage when the dryer is attempting to start or not heating for a very specific reason. Checking for voltage without the dryer plugged in does not tell the full story. A dryer heater uses 220 Volts and draws about 20 amps when it is heating. Checking for voltage from L1 to L 2 on a defective circuit may show 220 volts but when the heater kicks in and starts to draw 20 amps the voltage may drop off to 0 volts. Imagine the wiring to your dryer was stranded wire. Stranded wire is composed of a number of small-gauge wires bundled together to make a larger wire. What if all but one of those stands were cut and only one small wire was completing the circuit? Reading voltage at the receptacle without the dryer plugged in you would read 220 volts from L 1 to L 2. However with the dryer plugged in and the heater attempting to draw a heavy current, the electrons (current flow) would be dammed up behind the cut and only a small amount of current would pass through the wire. Certainly not enough to make the heater heat. There are a lot of things that can cause a partial circuit but the result is the same as the stranded wire example. Many a heater or dryer motor has been changed needlessly because of a loose connection in the fuse box / circuit panel or some other dryer electrical circuit problem.
Aug 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
I have 2 hots from 240 raceway and common neutral a 250 watt bulb on 1 hot a 40 watt bulb on other hot cut neutral wire they stay on but 40 watt gets bright the 250 watt goes dim why is that
You change circuit from parallel to series..
In parallel (with neutral connected) each bulb receives full voltage, and then each bulb runs at watt rating.
In series (with neutral cut) the circuit is still complete through the two hots... except the voltage drops after each bulb... which affects the watt output on each bulb.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 17, 2015 | Hardware & Accessories
Mitsubishi LT-37131 has darkening spots on screen
Take a photo of what it looks like (take several) and post here or on a photo sharing site--indicate location of photos so I can see what it looks like.
In case you need it here is a listing and source for parts for this set:
http://www.shopjimmy.com/mitsubishi-lt-37131
May 27, 2012 | Mitsubishi Televison & Video
Coiled neutral out of arc fault breaker is hot and cannot figure out why. This is a new addition to our home and I have checked the wiring going into the breaker, it is as shown on the package. Volt meter...
The white coiled wire should be connected to the neutral bar with all the other white wires. The neutral from the circuit it controls should then be connected to the breaker. If you're reading your meter between the hot conductor (black wire) and the neutral (white wire) that would be normal. If you remove the wire from your neutral bar to test it, and you have a load on the circuit you will be reading voltage out through your load and back on the neutral and it would "appear" to be hot. But why would you remove the white wire? What is the original problem, is the breaker triping?
May 18, 2010 | Siemens Seimens Arc Fault Breaker
When we measure from hot to neutral we get between 40 & 50 Volts
this is "phantom voltage." To be sure of this you can try shorting the hot with the ground. Should not short. The voltage isn't dangerous. It often happens when two hot wires are in the same cable. For example a 12/3 romex with a shared neutral. When one hot wire is turned off and the other is still energized, voltage can leak from one wire to the other, causing a reading of 50 or so volts on the non powered wire.
Nov 17, 2009 | IDEAL Vol-Con Xl Voltage/Continuity Tester
Flotec 1/2 hp pump won't run. 124v line voltage. But L1 to L2 shows -00.1 to -00.4 Power supply line is 12/2 to a on/off switch and 14/2 to pump from switch. Distance to service is less than 100 feet
With your volt meter, check the voltage at the circuit breaker or fuse to the neutral bar. If you have 120 volts there, then go to the switch and check the 12/2 hot wire to the neutral wire, if you have 120 volts, then check the 14/2 hot wire on the switch to the neutral wire.
if you have voltage going into the switch and existing the switch, then check all the connections between the switch and the pump.
When you're testing for voltage, do not test the hot wire to ground. You have to make sure that the neutral wire is not broken someplace in the circuit
Nov 08, 2009 | Flotec Corrosion Resistant Shallow Well...
MY LG DLE5977 Electric Dryer will not power on
Check the junction connection behind the dryer where the power cord and terminal block to make sure that the screws are tight.  Then use a volt meter to check for voltage.  The 2 outside wires should be hot leads and the center is neutral.  Check hot to hot and you should get 240 volts.  Check hot to neutral and you should get 120 volts.  If you get those voltage readings, then you have a control board malfunction and needs to be replaced.  There is no reset switch within the dryer for the control board.
Jun 09, 2008 | LG DLE5977 Electric Dryer
Mitsubishi LT37131 37 in. HDTV LCD Television Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
