Question about Arrow T50P ARROW STAPLE GUN
How do I load JT21 staples into a Arrow JT27 Stapler gun?
I was having the problems everyone listed... with the staples loading & firing... I guess the instructions are lousy .. should be ON THE PACKAGE to make it clear.. but.. on the stapler itself on the bottom.. it explains how to correctly load.. you don't put the staples on the piece that slides out.. you slide it out, load the staples in the open tunnel ..then slide the piece back.. that piece is the spring loader... since i finally figured it out ( by coincidence that I turned it over & noticed some faint words printed) - it works PERFECT every time! great little stapler... please fix your directions... seems to be a common misunderstanding!!!
Posted on Aug 30, 2012
SOURCE: How do I load staples
At the end of the stapler opposite where the staplers are driven out is a release.
Push it in and turn it and it should come out with a long spring
Load your staples, put the spring back and lock it.
Posted on Aug 31, 2011
  • 32 Answers
SOURCE: Hi can't seem to reload stapler
All you do is open the end peice and slide the staples in on the two rails, point down. You should be able to see in the end to make sure nothing is blocking the rail with a flashlight. You probably have the wrong size staples. You can only use # 214, 215, 276.
Posted on Nov 26, 2008
SOURCE: I need instructions on how to refill the Arrow T50
remove the spring loaded magazine from bottom rear of unit by pushing down on piece about two inches below curve section of rear end of handle push down gently and pull to rear staples go in front ofin same slot from which this magazine is removed load normally two clips if your dead empty when you return the spring follower back into place it follows the staples if if doesnt go all the way in you probably have to many remove some good luckd
Posted on Mar 23, 2011
  • 2712 Answers
SOURCE: Staple Gun Troubleshooting
Most of the staple gun models lack an "anvil" — the metal plate with curved slots that office staplers use to bend the legs of the staple inwards and flattens them against the paper. Staples set with a staple gun retain their straight legs, and are held in place only by static friction of the legs against the compressed surrounding material, much like common nails. Indeed, some staple gun models can handle brads and nails as well as staples. Some staple guns also use divergent point staples where the legs twist as the staple drives into the surface providing superior holding power.
Posted on Aug 27, 2008
ed_dylp
  • 24 Answers
SOURCE: just got an ET50red electric
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Posted on Jul 31, 2011
Will Arrow #506 staples work in an Arrow JT27 manual stapler?
Hello, there. No, 506 staples will not work in the JT27 stapler. This staple gun takes JT21 staples in 1/4-inch, 5/16-inch and 3/8-inch. Did you have any more questions about your JT27?
Oct 02, 2015 | Office Equipment & Supplies
The manual for a arrow T-27 staple gun
Hi Tim, There are YouTube apps on operating the stapler but I've not found a repair manual online. If it's like mine the spring's attached to the removable loading arm at one end and to the "pusher piece" at the other. So even if the spring's detached you should still be able to use the stapler. Please feel free to correct me if I'm wrong.
Jul 12, 2015 | Arrow Tools & Hardware - Others
Cant open jt27 staple gun to load staples
Hi Maria, I'm sorry you are not having luck with your JT27 stapler. Unfortunately you did not purchase the correct staples for this tool. The JT27 Stapler uses the JT21 staples in a green box. The staples come in 3 different sizes (1/4", 5/16", 3/8"). You can purchase these staples online or at your local Home Depot or Lowe's Store.
As for opening the tool - please see the attached picture for assistance.
May 07, 2015 | Arrow Tools & Hardware - Others
Arrow jt27 staple gun won't load or staple
Everyone here is assuming that you have fully operational gun. I have a business where we use these guns. I can tell you now that 3 out of 5 of the Arrow JT-27 just don't work. The staples won't advance. After looking at the information online, it is probably due to a weak spring. The best solution is to go with a different brand of stapler. This one is just not worth the trouble.
Jan 16, 2013 | Tools & Hardware - Others
How do I load staples into my JT21 staple gun?
Aug 31, 2011 | Arrow Fastener Co. Lt Duty Staple Gun -...
Just purchased t27 arrow staple gun but can't load staples. I have removed spring loader from rear and unsuccessfully trying to load staples from rear. Wrong method? Wrong size staples?
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Aug 24, 2010 | Arrow Fastener T27 Light Duty Household...
Won't shoot staples. Proper loading instructions please.
Make sure the staples you are using are compatable with your gun they should be type 53 or JT21 staples and they are not longer tham the gun is capable of taking I think the maximum capacity for this gun is 5/16 or 8mm.
Turn the gun upside down and pull back the carriage, the staples are laid in the empty chamber in the gun itself not on the carriage points facing in the direction they fire ie points facing you .
Push back the carriage this should slide over the strip of staples until the carriage clicks shut.
You should now be ready to fire, try and keep pressure down on the gun as the recoil can make the gun bounce and you will leave the staples proud.
Hope this helps.
Sep 02, 2009 | Omega Easyshot Staple Gun & Desktop...
JT21 staples
no
will jam stapler
us 9.5mm
May 17, 2009 | Black & Decker 5700 Powershot Forward...
Nov 26, 2008 | Arrow T50P ARROW STAPLE GUN
Arrow T50P ARROW STAPLE GUN Logo
5,911 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
