Question about Kenmore 16225 Grill
Replaced the tank but now gas wont flow from tank through to the grill... dendendeerhunter@yahoo.com
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
Hopefully this will fix you up.
  1. Turn off the gas at the propane tank
  2. Disconnect the gas line from the tank
  3. Open the grill lid
  4. Turn all control valves to high
  5. Wait for about a minute
  6. Turn all control valves to off
  7. Reconnect the gas line to the tank
  8. SLOWLY turn on the gas at the tank
  9. Light the grill normally
Your grill should now heat normally
Posted on Nov 10, 2010
Why wont my old grill work with new propane tank
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 13, 2014 | Weber Q Grill
Grill is one old and won't light. There is no gas coming from the tank to the grill. Is it the regulator?
age of the grill is irrelevant, i am old and i still can do few thingzzzz...
i assume that your regulator is connected directly to the bottle, then hose to your bottle, then hose is connected to the regulator and other end to the grill?
or it is bottle, hose, regulator, grill?
you need to follow the path regardless, be outside, light breeze is better, no open flame in at least 20m (yards) radius in any direction.
1. close gas bottle/tank
2. disconnect, everything from the bottle
3. crack open tank valve and hear if gas is escaping, close valve back
4. connect regulator to the bottle and again crack open the valve, hear if you have esacping gas, allow actually whiff of gas against your cheek or wetted finger to establish the flow. close the valve
5. connect hose to the regulator (procedure is reversed if first is hose and then regulator), crack open the valve, hear for escaping gas, check against wetted finger and cheek if there is flow, close the valve
6. connect your grill open all valves on it and open valve on the tank/bottle. allow free flow for about 30sec, close valves on grill. vent grill for about two minutes, try to ignite any of the burners. if burner ignite, you solved the problem, if they do not, and you did have flow on all previous stages, close bottle valve, disconnect everything from grill, clean grill valves and nozzles (burner have nozzle inside!), reconnect and vent again, try ignite, if ignition occures, you solve the problem, if not, then you are due for new grill...
if at any stage you do not have gas flow, this meant that this particular piece of equipment is in trouble, this particular piece of equipment need then repair or replacement, under no circumstance pull apart the reducer! NO OPEN FLAME DURING TESTING!!!
Jul 27, 2010 | Weber Q Grill
New Tank won't light Weber Grill
Try checking the regulator, this is the round metal piece connected to the gas line. If this is not level flat the valve inside will not let propane flow through.
Apr 15, 2010 | Weber Spirit? E-310 Propane Grill
Grill does noty get hot
try opening the tank very slowly. if you open it too quickly the overfill protection devise in the tank will restrict the gas flow to the burners. hope this helps.
Sep 10, 2009 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Troubleshooting amana gas grill
From a tag that came with the grill -
"To ensure proper gas flow, all of the burner control valves MUST be off before opening the LP cas cylinder valve.
When turning on the LP gas cylinder valve, make sure to open the valve SLOWLY two complete turns to ensure proper gas flow.
All LP tanks now come equipped with a leak detection device internal to the tank, when gas is allowed to escape rapidly it will restrict the gas supply to the appliance. Opening the valve rapidly may simulate a gas leak, causing the safety device to activate, restricting gas flow and causing low flames or poor ignition.
Opening the valve slowly will insure this safety feature is not falsely triggered."
I would guess you triggered the tank failsafe inadvertently.
Jan 01, 2009 | Amana 5939 Grill
Flame on gas grill is too small
From: http://bbq.about.com/cs/replacementparts/a/aa071100a_3.htm
Symptoms and Solutions Low Flame: The grill just doesn't want to heat up. This can be cause by several things. Taking it from the fuel source to the flame, lets start with the burner. Newer propane tanks contain a self regulating feature that will automatically slow down the flow of fuel if it thinks it's too high. This can be solved by turning the tank valve off completely and disconnecting it. Open the control valves (on the grill control panel) and ten close them. Reconnect the fuel tank and slowly turn on the valve. Now light the grill to see if that fixes it. Otherwise check the control valve(s) and venturi tubes for obstruction and alignment. Make sure that the flow of fuel is continuous. Check the burner for clogged gas holes. You can usually see this problem by observing how the grill burns. If there are spots without flame then you probably have a clogged burner.
Oct 28, 2007 | Patio Classic Barbecue Bucket Grill
Kenmore Elite Grill will not start
The gas regulator that attaches to the tank may be bad.
May 18, 2007 | Kenmore 774 sq. in. Cooking Area Gas Grill...
Kenmore 16225 Grill Logo
203 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
