Question about Marantz DV3100
I have a Marantz DV3100, the unit stopped playing and will not eject tray and now the display window is lit up with all indicators showing.
2 Suggested Answers
  • 411 Answers
SOURCE: Marantz Model DV6600 DVD rewind is
Usually means the lens needs cleaning. Occasionally, it's a case of the drive binding. Try running a lens cleaner through it first. You'll want the type that's got optical quality brushes built in to the bottom of the disk.
If that doesn't fix it, it's likely a drive issue, which means it's time for replacing the unit - costs more to fix than replace.
Posted on Jul 05, 2011
Nakamichi DR 10 does not eject. I loaded a cassette, pressed 'Play' the cassette played 10 seconds and stopped. The display showed 'ERR'. I removed the cover, nothing immediately obvious. The cassette...
The DR1o might have a Sankyo transport and they have sense fingers that become tarnished. This needs to be serviced to make the deck work. It is possible that the deck is still in play mode which blocks the eject from taking place. Unplug the unit and open it up and rotate the worm gear with a finger and the door will eventually open up but do not force things as understand the size of motor in the unit that normally turns the worm gear.
Sep 19, 2013 | Nakamichi Audio Players & Recorders
Some buttons not available
How long have you owned the unit and how long has it been doing this? Once I have more info I can assist you further.
Thanks,
Lee
Sep 01, 2008 | Kenwood KNA-DV3100 Car Video Player
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
I have a lifestyle 18 bose system which only plays region 2 DVDs. How can I get it to play region 1 as well?
Hi, check below the media center/DVD player as to what region your system was fixed into (indicated by a number inside a globe). This is located underneath the unit just beside the serial number. FI the system indicates that your system indeed is set to region-2 then proceed as follows. IF it marks a different number region, then bring the unit to the Bose service center.
Steps in UNLOCKING REGION CODE of media center:
1. Load a DVD and wait for the display to show "REGION CODE ERROR, CONTACT BOSE"
2. Once this comes out, press eject button on your remote control but do not remove DVD disc
3. Press the following button commands in sequence (make sure they are in sequence and are pressed by looking into the media center display where a small green dot should blink indicating that each command is received).
4. First you need to initiate the system region change on the remote control:
a.while the tray is out and the DVD is still in the tray, press and release "RIGHT" arrow button
b. then press and release "UP" arrow button
c. after, press and release "SHUFFLE" button
d. then press and release "STOP" (black square symbol) button
e. lastly, press and release "MUTE" button and system should go on mute (indicated in the LCD display
After this, you now can change the region code by doing the following button press on your remote control:
1. While the DVD tray is out still and the DVD disc is in the tray, press and release "STOP" button (black square mark)
2. Press and release "SHUFFLE" button
3. Press and release number "0" button on numeric keypad
4. Lastly, press and release "ENTER" button on your remote control and the DVD tray should go back inside the DVD. The disc then should start loading and playing resumes.
5. Allow the DVD disc to run for a few minutes (if you want enjoy a full movie) to keep the region change resident before switching off again.
Now enjoy your Bose Lfiestyle DVD System REGION FREE!!!
Do note, this does not apply to Bose DVD system that are locked to region-1
Glad to be of service always!
Mar 03, 2009 | Bose Lifestyle 18 System
I have a jvc th-p7 cinema system. and when i try to open the tray it say's locked. but i dont know how to take it off?????
You can lock the tray and prohibit the unwanted disc ejection.
On the center unit ONLY:
While the system is turned off
• The system turns on and "LOCKED" appears on the display
window.
• If you try to eject the disc, "LOCKED" appears to indicate that
the tray is locked.
To cancel
Carry out the same operation again.
• The system turns on and "UNLOCKED" appears on the display
window.
Nov 27, 2008 | JVC Televison & Video
Locked dvd tray.
with the unit off press and hold the stop button and the eject button.
Jul 08, 2008 | JVC TH-S11 Theater System
Marantz CD48 - CD spins backwards
Check the small signal transistors BC338 and BC328, they're under the transport mech and will be near where the spindle motor plugs in to the PCB.
One of the transistors acts as a brake which momentarily puts the motor in reverse polarity to stop the CD rotating during 'stop' or 'open tray' modes. The reason the CD is spinning backwards is that the transistor which drives the spindle motor forwards during playback is faulty and is triggering the braking transistor hence spinning backwards.
The transistors should be 'BC328-25' / 'BC338-25' (25v)
Replace these and all should be well.
Hope this helps
Sep 05, 2007 | Marantz CD-48 CD Player
Lock and Demo Play Display
while the demo is playing you must press "Play"and "Stop" buttons, then display shows DEMO OFF and you can now take the DEMO CD out.
In some models you need to turn off the power and turn it on while pressing the EJECT Butoom.
SONY SPECIALIST
Dec 29, 2006 | Sony DAV-X1 System
Marantz DV3100 Logo
105 people viewed this question
Top Marantz Televison & Video Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Marantz Televison and Video Expert? Answer questions, earn points and help others
