Question about Sony VAIO VGN-NR385E Laptop
I have had my Sony Vaio VGN-NR385E laptop for three and a half years. I was working on it last night and it suddenly shut off completely, as if I had disconnected the wall charger without the battery in place, but both the battery AND the wall charger were still in place. I tried turning it back on, but nothing happens. There are no indicator lights on the computer, and the AC adapter still shows a green indicator light (AND is outputting the proper voltage), so I don't know what I should do! Please advise.
    Habit-Forming:
  • 66 Answers
Sounds like it over heated. Do have a cooling pad under your laptop? Hit me back, let me know please.
Posted on May 23, 2017
  • 883 Answers
SOURCE: Sony Vaio VGN-B1XP Stopped charging
try removing the battery that may have gone bad.
Posted on Sep 04, 2007
  • 238 Answers
SOURCE: Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Posted on Dec 20, 2007
  • 846 Answers
SOURCE: sony viao wont boot, battery light flashes amber
Move the power jack around while plugged in, does the blinking on the battery stop when you hold it in certain positions? If so, your dc-jack needs to be soldered, but i probably was loose already before you started using it. It could be a broken motherboard issue as well. You can try to open the laptop and check the dc connection. There is a Laptop Repair Guide that shows you how to take apart a laptop, the sony may be made in a similar way. Sony Repair NYC
Posted on Jan 17, 2010
  • 72 Answers
SOURCE: Sony vaio VGN-N220e power failure
check your power adaptor
Posted on Mar 09, 2010
EMKartha
  • 163 Answers
SOURCE: Sony VAIO VGN-FE770G only runs on AC power, battery not working
This looks like the system is not able to sustain itself on the battery power. I have a doubt here. Is it a new or an old laptop. Either Case we have to suspect the battery charging and battery condition. One another reason could be that the battery contact is not good. But this could be of the least chance as the manufacturing of such devices would be perfect in all standards. Lets check the battery power first.
A sony Vaio never operates if the battery is not detected or the battery is not charging, while the system is up and running, you can see a small picture of the battery in the system tray which is at the right bottom corner of the screen. Run your mouse over the same and you will find a tooltiptext message and you can see if the battery is charging or not. If not, your hardware has a problem. If its charging but the battery charge is not increasing, then you have a battery problem. If its a battery problem and that the system is under warranty, you can well get a replacement for free. Hope this resolves the issue. Good Luck.
Posted on Mar 14, 2010
Testimonial: "Thank you for your help - I really appreciate it! My computer is 3 years old, so I suspect the battery is defective. "
Sony VAIO VGN-NR385e vista windows crashed
Is it telling you you don't have an OS?Could be HDD has died.That would be relatively an easy fix and not too expensive.See if you can find a working hdd the same type ,pop it in and see if your restore disks will work.
Aug 01, 2012 | Sony VAIO VGN-NR385E/T Core 2 Duo T5550...
Hello my cd rom soednt work. I have a sony vaio vgn-nr358e tried to uninstall the drivers and still no good. thank you
Hi welcome to Fixya.
You can try this link http://support.microsoft.com/kb/929461 if this wont work then it could be the hardware CD/DVD needs a replacement.
Thanks for contacting Fixya. Bye for now.
Jul 16, 2011 | Sony VAIO VGN-NR385E Laptop
Iafter i formated my laptop i lost my vga for sony vaio vgn-nr38e
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows XP or Vista drivers you require. Pleaseclick on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
Nov 24, 2010 | Sony VAIO VGN-NR385E Laptop
Sony vaio VGN-NR385E laptop battery not working
give your battery to compny shop if it is in warnty they will chang your battry. if not give for repair it
Aug 24, 2010 | Sony VAIO VGN-NR385E Laptop
The left button of Mousepad(one on laptop, but not touch pad) is often not working and sometimes need to press hard. Model VGN-NR38M, Sony Vaio. please help
I had the same problem . The micro switch needs to be replaced . All push button micro switches have a certain amount of "clicks" before they loose ability to make a good contact . Your left click switch has exceeded its life and can no longer make a clean contact without more pressure . Eventually the spring in the switch will fail thus stick permanantly.You will have to take it to an authorized Sony Service center or maybe an office machine service department might have the replacment . I fixed my own with an old mouse microswitch .
Jun 26, 2010 | Sony VAIO VGN-NR385E Laptop
Left mouse button of Sony VGN-NR38M (nt touch pad) is not working often, and some times need to press hard, please help
mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
Jun 25, 2010 | Sony VAIO VGN-NR385E Laptop
I CANNOT START MY SONY VAIO LAPTOP - THERE IS A MESSAGE THAT APPEARS EACH TIME WHICH SAYS "CONGIFURING UPDATES STAGE 3 OF 3 0% COMPLETE - DO NOT TUR OFF YOUR COMPUTER" - THEN IT SOMEHOW SHUTS DOWN??? THEN...
Sort of sounds like a virus. I had a Sony VAIO laptop for about 8 years. During that time until I got KASPARSKY internet antivirus I had many problems. Sony was a lifesaver. Call then at 888-467-6972. Out of the at least 10 times that I called them they talked to me without charging me anything except for one time. They charged me 19.99. However, if you are like me it didn't matter how much it cost. You should call them.
Jun 10, 2009 | Sony VAIO VGN-NR385E Laptop
Sony VAIO VGN-NR385E Laptop Logo
93 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
