Want to set the date and time for your mobile phone? Follow these easy instructions. From a Home screen, tap the Arrow icon to display all apps.
Navigate: Settings > Date & time.
To use network-provided values, turn on the following:
Automatic date & time
Automatic time zone
When manually setting data & time, perform the following:
Automatic date & time and Automatic time zone settings must be turned off to manually adjust date and time.
Tap Set date.
Adjust the date then tap OK.
Tap Set time.
Adjust the time then tap OK.
Tap Select time zone then select a time zone.
If desired, tap Use 24-hour format to turn on or off .
Because HP Solution Center uses Adobe Flash, you will need to change the date of your computer to before January 12, 2021 (since Adobe Flash is no longer supported).
Using Windows 10, go to Settings >> Date & time then turn Off "Set time automatically" and click on "Change" to Set the date manually and select 2020 and click on "Change". This will need to be repeated each time the printer reboots.
In HP Solution Center, choose "Status" to view the "Cartridge(s) Expired warning and click on "OK" to Dismiss this message.
Select Menu > Settings > Date and time.
To set the date and time, select Date & time settings.
To set the formats for date and time, select Date & time
format.
To set the phone to update the time and date automatically
according to the current timezone.
You can get more help from downloading the manual from Nokia at http://nds1.nokia.com/phones/files/guides/Nokia_7020_UG_en.pdf
At standby the display will show the date and time. Once the standby display is set, it will automatically be
updated.
General Description
Setting the Date and Time
1 SET MODE (1-8)
2 USER PARAMETERS?
3 DATE & TIME?
4 01-01-2001 15:00
5 Enter the new date and time.
Ex: Date : 10th
December: 12th
Year : 2001
Time : 3:00 PM
If you make a mistake, use or to move the cursor
over the incorrect number, then overwrite it with a correct
one.
10-12-2001 15:00
6
7
1 2
2 0 0 1
1 5 0 0
Set the date and time You can set the date and time from the front panel. When a fax is transmitted, the current date and time are printed along with the fax header. The date and time format is based upon the language and country setting. Normally the computer software sets the date and time automatically. 1. Press Setup. 2. Press 3, then press 1. This selects Basic Fax Setup, then selects Date and Time. 3. Enter the month, day, and year (last two digits only) by pressing the appropriate number on the keypad. The underline cursor presented initially beneath the first digit advances automatically to each digit after, each time you press a button. The time prompt automatically appears after you enter the last digit of the date. 4. Enter the hours and minutes. The AM/PM prompt automatically appears after the last digit of the time is entered. 5. Press 1 for AM or 2 for PM. The new time and date settings appear on the front panel.
Hi there, my name is Alex and I am here to help solve your problem
A common problem to signing in to MSN Messenger is the date and time set incorrectly. You can locate this at the bottom right hand corner of the desktop. After setting the time and date correctly, you should be able to sign in without problem.
If Messenger gives problems and the date and time are both set correctly, exit MSN Messenger and exit the icon which is located in the system bar (next to the time and date) and then open MSN Messenger again.
I hope this problem helps..... If you have any questions or more problems, please feel free to ask me.
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet
Options. From the Internet Options dialog box, go to the Connections
tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN
checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block
access to secure sites". If this cures the problem, make sure that
Microsoft's MSN Messenger is allowed full access through your firewall.
