Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Hissing freezer Hi i have a fridge with a small freezer compartment at the top,while defrosting it i accidently pierced a small pin sized hole. now its making a hissing noise can anyone help me? thanks
  • 2 more comments
  • criago Jun 15, 2008
    thanks for your answer.Is the gas bad? And is the fridge totally gone too?
  • cn_ad Oct 17, 2008
    I have a similar problem my teba fridge, I accidently pierced a hole with in the freezer during cleaning, although I managed to seal this hole with epoxy multi-purpose seal, fridge and freezer is now warm. Please could you make any other suggestions in order to rectify this problem. Much appreciated if you could.
  • 1,512 Answers
Hi criago
I am very sorry to say that you have pierced the coolant tubing, the hiss you here is the coolant gas escaping. Your Fridge Freezer may be unrepairable because it is very hard to get into the area concerned.
Sorry to break the news to you.
Posted on Jun 15, 2008
  • Graeme Ross
    Graeme Ross Jun 15, 2008
    the gas is bad for the environment... but wont kill you. Unfortunately, both fridge and freezer will gas out and not work anymore for you. Sorry
Temperature sensors
I have an E402 fridge (403 litre model with freezer on bottom) . I just dismantled the freezer back wall due to a bad defroster element and noticed that on the back wall of the freezer is a small raised "cavity" or "slot" that the black thermostat fits into nicely. In my fridge, it is above the Collins coil and a bit to the right of centre(closer to the wire entry hole). Hope this helps
Feb 15, 2014 | Fisher and Paykel Active Smart E522B...
Water is dripping into fridge compartment from section separating fridge and freezer compartments, otherwise, both seem to be working fine. unit was new in 2001, model ET21PK.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 09, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
My 10 year old Roper fridge stpped keeping the fridge part cold but the freezer is working fine. Is it worth fixing?
Sure it's worth fixing, in fact you can probably do this yourself. This is usually caused by either a broken defrost heater, defrost thermostat, or defrost timer/control. Take all the food out of your freezer and remove any shelving that might be in the freezer. Remove the rear panel in the freezer and you'll see ice blocking the air ducts going into the refrigerator compartment. Use a hair dryer to carefully thaw ALL of the ice. Also check the defrost drain while you have it apart. The defrost drain is located in the freezer, in the middle. It's a small hole going out of the bottom middle of the freezer. Pour a coffee cup of hot water down the tube. If it drains, you're okay. If it puddles up, you have an ice blockage and you need to pour more hot water in the hole until it drains freely. Reassemble your freezer and if the problem comes back in a couple weeks or months, you know you have a bad part. Usually the defrost thermostat. It's a small round part that is about the size of a golf ball. It has 2 wires going to it. See if it's bulging.
May 26, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
It's too cold in the top freezer, yet not cold at all elsewhere
if your freezer is cold but your fridg isn't then you have a defrosting problem. behind the back wall of your freezer you will probably find a very large mass of ice. unplug your ref and using hot water melt the ice. you will need several large towels for this since it will make a mess. once the ice is cleared if you have an ohm meter you can check the defrost element you are looking for continuity( closed circiut) if that tests ok find the defrost termintor(also called a bi-metal defrost) it is about the size of a quarter and is usually located in the top left side of the freezer. It will be clipped to one of the tubes. if it looks like it has popped then it is bad. If the bi-metal looks ok you will need to hook the element back up and go to the control panel in the fridge. looking up at it you will see a small hole and a gear inside that you can turn with a slotted screwdriver. turn it until you hear it click and the fans stop running. if the defrost heater comes on then change the defrost timer(the part you just turned)
Apr 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
Haier Fridge and Freezer
The compressor and Freon are all one sealed unit,never heard of a separated system. by turning it on you will just drain the rest of the freon.
Feb 16, 2009 | Haier HTQ21JABWW Top Freezer Refrigerator
Zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Jun 12, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
2,342 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Alan Moore
Level 1 Expert
