Question about GE JKP27 Electric Double Oven
GE model JKP27 Beeping, keypad does not work except off and start keys, showing F7 or 350 (temp) Any suggestion? Thanks a lot.
4 Suggested Answers
  • 234 Answers
SOURCE: Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Posted on Apr 27, 2009
localwonder
  • 6784 Answers
SOURCE: beeping with f7 display
HI this is a touch pad or key pad issue. In most models, the touch or key pad are integrated. In this case, you will need to replace the entire control board or EOC(clock).
Now, if the touch or key pad is separate from the main control board, and linked, via linking ribbon, i would advise to use the procedure below to isolate the problem area.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Posted on Oct 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: The F7 alert keeps flashing/beeping on my JKP27 GE
Ya either have a stuck keypad or a bad oven control. To see what it is you push the clear/off pad, disconnect the ribbon from the control and wait 32 seconds, to see if the if the F-7 code occurs again, If it don't then bad keypad, if it does then bad control.
Posted on Jan 28, 2010
Testimonial: "Thanks so much for getting back to me about this. I'll try this to help me diagnose the problem. Thanks again!"
JKP27B0W1BB WHEN I PRESS ALL THE KEYPADS AT TOP THEY ALL WORK EXCEPT THE START BUTTON ...
It is a good chance that that button is bad on the keypad. the key pad will need to be replaced.
Feb 02, 2014 | GE JKP27 Electric Double Oven
GE model # jkp27 error code F1 what should I do?
Hi ssantillo,
Usually F1 error code means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be cancelled, replace the oven control (also called clock or ERC), touch pad, or both.
Hope this helps.
Thank you for using FixYa.
Apr 27, 2011 | GE JKP27 Electric Double Oven
The F7 alert keeps flashing/beeping on my JKP27 GE electric double oven even after clearing it or cutting the power to the oven for a period of time. Any suggestions? Thanks!
Jan 28, 2010 | GE JKP28 Electric Double Oven
Error code F2 keeps beeping! Will not reset. Any
thats the oven sensor , replace the sensor and your good to go
Jun 17, 2009 | GE JKP27 Electric Double Oven
The oven is flashing code F7 and keeps beeping
HI, this is an issue that concerns either the key pad or the control board.
May 15, 2009 | GE JKP27 Electric Double Oven
Oven shows F7 error problem with irritating beeping sound
F7 stuck keypad
Stuck keypad may mean relay is turned on.
May 13, 2009 | GE Profile JKP56 Electric Double Oven
Error code F7 keeps coming up, what does this mean?
F1 error and beeping. Don't bother getting GE out there. Cost me $90 to learn they don't make the clock. WOuld have been $500+ for the control panel anyway. Better off just buying a new one. Planned obsolescence I guess. I won't buy GE again.
Mar 16, 2009 | GE JKP27 Electric Double Oven
GE digital Timer Oven
most of the time turning the breaker off for a few min will be a temp. solution but it it comes back then the ERC which is the clock itself needs to be replaced
Nov 22, 2007 | GE JKP27 Electric Double Oven
Ovens Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
