Question about Sharp Aqous LC-26D5U Television
Sharp dtv e202 error was received - Sharp Aqous LC-26D5U Television
Try just changing the channel to the one set up to receive broadcasts. That worked for me-- the TV was working great until I pressed Input and for some reason that changed the channel away from channel 60, which is the one programmed to receive broadcasts from Dish Network. When I entered 60, the message went away and I got my programming back.
Posted on Jan 18, 2011
Sharp tv error code e202
Use the remote " Source" button. Press it until you see a picture.
Mar 05, 2015 | Sanyo 42 in. LCD TV
Canon image class all in one 4412 printer error code e-202-2002
Same problem on an older LC-C3742U SHARP AQUOS. Other tv in my house receives ch 4.1 at the same cable spot and bad tv will not receive this ch in the good tv's spot so I know it is the tv. It receives all other channels well just not 4.1 which shows E202.... Tried your reset protocol but it merely started the tv and held the channel it was last set on.
For more help visit cbr tech solutions
Apr 20, 2014 | Office Equipment & Supplies
Sharp aquos instructions
That means the channel is active but but there is a problem with the delivery by the broadcaster, not a defective TV.
Dec 28, 2013 | Televison & Video
Comcast tv failed receive broadcast e202
Check the input cable to the TIVO is is firmly connected at both ends?
Dec 16, 2013 | Tivo Televison & Video
Failed to received broadcast E202. what's wrong?
It means that the tv doesn't gets the correct signal from the cable or the antenna - check them.
Oct 07, 2011 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Error Code E202, no picture, Sharp Aquos LC-45GD1E
Ur tv is not getting a broadcast signal,or ur tv cable or free air signal not getting from air antena,cables or dishes signals,or strong enough comming through.Get a better antena,like a digital antena,or a roof antena for better free air signal,cables or telicoms signals check ur boxes,push the power button OFF/ON to reboot it,to get signal back.
Apr 05, 2010 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Turned on set....screen all black except a dark blue rectangle in center which reads:Failed to receive broadcast [E202]
That message is presented when a selected digital channel is too weak to decode. Let us hope that something was accidentally changed:
Is the channel legitimate?
Is the antenna/cable still connected (to the Digital input)?
Go into menu - setup - channel setup. Is the selection of either cable or air channels correct for your situation?
Use menu - setup - Antenna Setup-DIGITAL to examine the signal strength. Is there nothing at all, or is it just a question of strength?
Odds favor a change in channel setup that you would not have made intentionally, or a simple physical problem (input cable, etc.). Start from scratch, and check the settings and connections you originally made. Hopefully it will be simple and cheap!
May 22, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Error e202 in canon 6330
E202 That is scan problem scan switch scan motor or may bi image processor board.do not forget to rate solution.by MIAN JEE
Feb 20, 2009 | Canon imageRUNNER 5570 Copier
37 inch Sharp Aquos. "Failed to receive Broadcast [E202]"
This is basically a message for no signal on the tv, make sure the tv itself is on the correct input for the type of cable used. The inputs are labled by numbers on the back of the tv. The input can be changed by the button on the side panel of the tv.
Aug 13, 2008 | Sharp Aqous LC-26D5U Television
Sharp Aqous LC-26D5U Television Logo
1,363 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
