Question about Whirlpool Calypso GVW9959K Top Load Washer
When a load is finished and you open the washer lid, water and what looks like fabric softner is dumped back into fresh washed laundry. Where is the water and softner coming from? It looks to me that it's getting out of softner dispenser and is trapped on top side of seal ring, and when the lid is opened the trapped fluids run back into freshly washed laundry and takes more time in the dryer to get dry.
  • 1,998 Answers
One of the main problems of a calypso and a cabiro which is calypso's sister is not only the electronics but how they handle any type of over sudzing heres a remedy take off the cover of the machine and watch what is happening while the machine is washing this way you can see if the water is getting trapped on the ring also how much water are we talking about becasue you can remove that softner dispenser from the machine and see exactly how much water it holds here is a link of exactly what your looking at although i have seen on these calypso models water stuck in the pump and not go out the drain pipe completly and it runs out of the machine and then before it ends it dumps the remaining water back into the tub heres the link http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fW0601397-00003.png also you might want to stop by your local home depot and pick up a product called AFFRESH if you do have any type of oversudzing this will eliminate that rune the afresh without any clothes and with hot water it supposedly is only for front load washers but this product works great on all machines please message me back with your finds depending upon how much water your talking about is back inside the machine is your next course of action I await your reply thanks again
Rick
Posted on Dec 02, 2010
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
Clothes stink
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hope your filter is clean. Don’t wait for the machine to jam to look into your filter.
You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use very hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Put the Affresh pellet inside the machine, not in the soap dispenser.
You can give me a ‘very helpful’ rating for the free help, can't you. Thanks.
May 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Everytime we do laundry, we have a horrible smell in the washing machine. We have tried bleach and hot water but no success. Any other ideas?
Be sure your using HE Laundry det. only use the recommended amount on the bottle, I use the liquid, the less the better, I use the least amount.....To much soap left in clothes can cause mildew and stinky smell, also I recommend using a fabric softner, it helps to remove the soap....and smells good....also use a good washer cleaner, I use Affresh, they come in tablets, go to www.affresh.com and put in you zipcode to find where you can purchase it in you area......make sure after a load is finished that it doesn't sit in the tub with the lid down for long, removing the laundry promptly will also help with stinky laundry........also, leave the lid or door open for a couple of days to air it out after cleaning.....use the Affresh at least once a month.......hope this helps you
Jan 08, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Fabric Softner
that is normal you can either add water to make it drain or pull out the drawer and dump it.
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Last 2 loads didn't use fabric sofner
Top load washer? check the agitator. alot of times the softner will gum up the inside of agitator and make dispensing hard
Jan 29, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Fabric softner tray is left full of murchy water after wash cycle has finished. Machine is brand new and only been used once. Its a Hotpoint Ultima WDD960 washer dryer.
is the machine got good water pressure cus somtimes little water gets in the fabric soften tay and it dosent flush all the softner out. hope this helps.
Sep 02, 2008 | Hotpoint Ultima WD72 Front Load...
Whirlpool duet fabric softner problem
It obviously is backed up or splashed in from the wash. And if it is just water why worry about it.
Aug 07, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
29 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
