Question about Dryers
Dryer squeeks when turning - Dryers
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 07, 2010
Ge frontloader dryer is squeeking incessantly, high pitch squeek driving us all crazy. by manually turning the drum i can isolate the squeek, but cannot see anything wrong. does it need to be taken...
There is a teflon bearing that holds the back of the drum you will need to replace. To get to it remove the top cover, take off the control panel, remove the front cover, take off the belt, then take the drum out, ususlly by lifting it up as you pull it foward. While have it all apart I would reccomend replacing the teflon glides at the front that the drum rides on.
Jan 31, 2011 | General Electric DCVH680EJWW Dryer
My dryer is squeeking when turned on and stops when the door is opened or it is stopped. what could cause this?
most dryers have drum rollers and an idler pulley. either of these could be squeeking. it also could be the motor bearings going bad.
May 24, 2010 | Maytag Dryers
Dryer squeaks when turned on, recently is getting louder and louder as drum is turning. Is it worth getting fixed, it's six years old
The squeek is probably the front 'bearing' which is generally made of felt.
Pop the top, pull off the front, remove the drum. Clean the felt or replace it.
A better alternative is to turn up the radio so you cant hear the squeek.
If you do go to this trouble, you may want to replace the belt while you have it apart.
Personally, id let it squeek. It may be annoying but on the ohter hand, you know when it is operating and when it is finished now.
Oct 21, 2009 | Dryers
When I turn on the dryer it makes a sqealing noise. Belts seem ok.
there are wheels that hold the drum in place they have berrings that tend to go bad i would replace them it should fix the squeek. also you can put some bar soap aon the beld to quite the squeek if it is not the holding wheels
Jul 21, 2009 | Whirlpool LER5636P Electric Dryer
Squeeking noise when dryer barrel or blower wheel turns
Sounds like the fan blade hub has become worn. Remove the front to gain access and secure a hose clamp around the hub. It may be necessary to trim away some of the plastic vanes to allow it to fit snugly.
Apr 26, 2009 | Dryers
Dryer making squeeking noise
Check the dryer belt tensioner and pulley assembly. It be wearing out. You'll need to remove the back cover of the dryer to do this. Turn off the gas and/or electric before working on the unit.
Mar 26, 2009 | Maytag MDE9316 Dryer
Dryer was squeeking now not spinning
It sounds like the dryer belt is wore out or broken, you can usually order a replacement belt from the maker of your dryer at there website.
Mar 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My GE Profile Squeeks
Yes it still squeeks and it still drys and it kinda stops being so loud after the dryer has been drying for some time. Need help on solving this iissue and how to fix it.
Thanks,
Elaine Mohr
Nov 09, 2008 | GE Profile Harmony DPGT750EC Electric...
Squeeking in lower dryer
remove the rear panel. unplug dryer before doing anything
Oct 24, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
Top Dryers Experts
