Question about Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher
Draining water from a dishwasher in preparation for a house removal
My removers have asked that the dishwasher be completely drained of water for the removal - I can disconnect it but how do i ensure all teh water is out?
Best thing is to disconnect all the hoses and ensure that the waste hose is kept high. Put the machine on a couple of chairs and let the machine empty into a bucket thru the hose. Quite a lot of water inside. Tie up the hoses and lead at the top back of the machine.
Happy moving.
Posted on Jun 18, 2008
Water staying in machine after wash completed
Hello. Generally, the problem is debris in the drain pump or in the drain line which goes from the base of the machine up into the drain under the kitchen sink. Begin by removing the lower panel on the front of the dishwasher and disassembling the drain line there. Be prepared for about 3 cups of water. Then REmove the pump and visually examine it on the inside. If you don't find the debris there check the entire drain tube, and the connection area under the sink. J.
Jul 28, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
Not draining water after cycle has completed
Hi
Thanks
Rylee
Dec 24, 2009 | Whirlpool Dishwashers
I have a Maytag MDB7100AWB that won't drain water after completed cycle
Hi
Thanks
Rylee
Dec 23, 2009 | Maytag Dishwashers
Dishwasher does not drain completely DU890SWLUO
Hi
Thanks
Rylee
Dec 23, 2009 | Whirlpool 24 in. DU900PCD Built-in...
The water is not draining. no clog in the drain house or plumbing
Hi
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 09, 2009 | KitchenAid KUDC25CH Dishwasher
Water is sitting in bottom of dishwasher after cycle is completed - fair amount of it
Hi
Thanks
Rylee
Oct 22, 2009 | GE Profile PDW8000G Built-in Dishwasher
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
Runs the cycle but doesn't drain completely
Hi
Thanks
Rylee
Oct 12, 2009 | Kenmore Dishwashers
Water remains in drain after cycle is completed. Odor remains in unit before loading is complete (a day or two) before another wash...Normal?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to some different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose.
Thanks
Rylee
Aug 31, 2009 | Bosch Dishwashers
Bosch 24 in. SHE44C02UC / SHE44C06UC / SHE44C07UC Built-in Dishwasher Logo
100 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
