Question about GE Dishwashers
Dishwasher dial cycle broke off, can it be repaired? Model#GSD220 Serial#MG839818B
    Genius:
  • 1,122 Answers
Yes,try ebay first with model number then criagslist in you area,then repair clinic.com,let me know-mike
Posted on Jun 15, 2008
Model #MDBTT792CG serial #16473992CG I am getting
I suspect you have your dishwasher set for a 1 hour delay start. Press cancel and restart in a regular/normal cycle and see if it programs.
Jan 13, 2011 | Maytag 24" Built-In Dishwasher - White
The dial on my model#DU8016XB-1 is frequently VERY difficult to turn, causing me to think I will break it. Once I am able to force the dial to the START position, the dishwasher cycle seems to work just...
HI. Unfortunately, this damaged timer control module will need to be replaced. This type of device is not designed to be repaired. The timer motor mechanism is damaged, thus, causing theses issues you are experiencing. Apparently, part of the timer dial plate has become fused, or the cogs are damaged.
Have the timer control module replaced, asap. It is not repairable.
Dec 11, 2009 | Dishwashers
Dishwasher stalls
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
May 31, 2009 | Bosch SHU4006 Dishwasher
Won't stop cleaning to go to dry
I have not worked with this Kenmore model, but:
It would be good to check the heating element to make sure it has not failed. Some dishwashers will wait forever for the water to come up to temp before it goes to the next cycle.
If the heating element checks out:
-IF it has a knob/dial that you turn to start the dishwasher on any cycle, that timer/controller has most likely failed.
-If your dishwasher does NOT have a dial as described above, then the main controller card (PCB) has most likely failed.
May 05, 2009 | Kenmore 16072 - Multiple Color Built-in...
Cycle Sticks unless I manually move it along
Ya, the mechanical timer/dial is the problem. The heating element just got stuck on as the timer stalled in that dry cycle.
May 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher stalls
SOUNDS TO ME YOUR CONTROL MODULE IS NOT WORKING CORRECTLY
Apr 07, 2009 | Bosch SHU4006 Dishwasher
Dishwasher not working
Difficult to say for certain exactly what will fix your problem but it is not out of the realm of possibility that the inlet valve is sticking closed.. The repairman may have given it a tap to free it up so that when it was energized.. it opened and let water in for the wash cycle..Just because that valve wasn't clogged doesn't mean it wouldn't stick.. If you can access it .. try giving it a light tap on the housing when the DW is cycling.. Hope that gets you going..
Sep 04, 2008 | Dishwashers
Kenmore 665.16705891 dishwasher
First make sure it will run by hitting "cancel' or turning the timer to drain cycle.What is the Model& Serial number???I'll be happy to get this solved for you. :)
May 17, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Jet dry not draining no clog as far as i know
i needed all your all your serial num its important 17
Nov 30, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
57 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
