I need a code for a one for all for an emerson tv the urc number is 4021
    President:
  • 1,140 Answers
Your remote is pre-programmed with the following codes for Emerson TVs:
0154, 0171, 0178. 0180, 0236, 0451, 0463, 1944, 1963
Try each of the above codes until you find the one which works best with your TV, i.e. controls the most functions. Please note, if your TV is newer than your remote, these codes may only control basic function or may not work at all.
If you need any further assistance or instructions for programming your remote, please post back.
If your problem has been solved, please be generous and award this solution 4 thumbs-up. This service has been provided FREE - your simple acknowledgement ensures my continued willingness to help you and others in need. Thank you ;)
Posted on Nov 07, 2010
I need remote codes for a dynex tv with a one for all remote model number urc-6011b00
Try using One For All Emerson codes to operate your Dynex TV: 0 1 5 4 ,0 2 3 6 ,0 4 6 3 , 0 1 8 0 ,0 1 7 8 ,0 1 7 9 ,0 0 1 9 , 0 6 2 3 , 0 6 24
Apr 03, 2014 | One For All URC-4021 Remote Control
Tip
One For All URC-4021 Code Entry To program your One For All URC-4021 remote...
To program your One For All URC-4021 remote control to operate your TV you can use the direct code entry function.
To enter for a code for your TV follow these steps:
  1. Turn on your TV.
  2. On the remote, press the TV key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the code list. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the TV and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
____________________________________
One For All URC-4021 Manual
One For All URC-4021 Code List
One For All URC-4021 Code Search
One For All URC-4021 Reassign Key
on May 30, 2010 | Televison & Video
Tip
One For All URC-4021 Universal Remote Code Search
To program your One For All URC-4021 universal remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
I hope that helps.
I Need A Remote Code For An Emerson EWC19T5 and One For All URC 4021 remote
Hello
Setup codes for Emerson Tv with One For All URC-4021 remote control are:
0154, 0236, 0463, 0180, 0178,
0171, 0623
The One For All 4 Device Universal Remote Control is preprogrammed at
the factory to operate an RCA TV, a Toshiba DVD player, a Motorola cable
box, and an RCA VCR.To control devices other than the default brands,perform
the following steps; otherwise skip this section:
[1] Turn on a desired device (e.g.,VCR or DVD player) and, if
applicable, insert media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely before proceeding.
Highlight or write down the codes and device you wish to program
before starting step 2.
[2] On the remote control,press a device key once (i.e., VCR/PVR,
DVD, CBL/SAT,or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo,
or TV/VCR/DVD Player Combo press VCR/PVR once.After programming
a VCR Combo device, you will be able to control channel selection,
volume, and VCR functions.
NOTE: To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD once.After programming
a DVD Combo device, you will be able to control channel selection,
volume, and DVD functions.
NOTE: To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
[3] Press and hold SET until the LED (red light) blinks twice,
then release SET.
[4] Use the Manufacturer's Codes (starting on page 18) to
locate the type of device and brand name and then enter
the first four-digit code for your device. If performed correctly,
the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps 2 through 4 and enter
[5] Aim the remote control at the device and press POWER
once.The device should turn off. If it does not, repeat
steps 2 through 5, trying each code for your brand until
you find one that works. If it still doesn't work, try
Searching For Your Code on next
NOTE: If the device does not have a POWER key, press PLAY
OK.
Sep 26, 2011 | One For All URC-3021 Remote Control
Need the codes for a NIKAI TV, that I am using in Iraq.
Hello
Code for NIKAI TV is not listed in the codes of URC-4021. Coreds for NIKKO TV is there. OK.
Mar 05, 2011 | One For All URC-4021 Remote Control
Tip
  1. Turn on your TV.
I hope that helps.
on May 30, 2010 | One For All URC-4021 Remote Control
Tip
I hope that helps.
Codes
I NEED CODES TO PROGRAM MY TV W/ REMOTE CONTROL URC-4021BOO
Jan 29, 2009 | One For All URC-4021 Remote Control
Urc4021 universal remote
You mentioned that you need the codes for your TV and you are using the URC 4021 remote control Go to the link below then select your model then select TV then the brand of your TV then click search. You can then see your codes
http://www.oneforall-na.com/advanced_search.php
I hope this has answered your
question. If you have more
questions please post a reply and
i would be happy to assist.
Thanks.
Aug 26, 2008 | One For All URC-4021 Remote Control
Remote do t work no more with my tv i need a code for a emerson tv or for the remote it is a URC-4021B00
Her is the PDF manual. It sghows all programming and the codes are in the back.
http://www.hifi-remote.com/manuals/manual.shtml?URC-4021
Please repost if this works for you....
MM85
Jul 26, 2008 | One For All URC-4021 Remote Control
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
