Question about Kitchen Ranges
What color do I connect to R W and Y my stem only has two wires Green and Red?
  • Kitchen Ranges Master
  • 43,501 Answers
If you only have two wires connect then to the R and the W.... that is it...hook the red to the R and the green to the W and your good...
heatman101
Posted on Nov 07, 2010
Electrical box has one red and one black wire and the switch has two balck wires and a green wire. How do I connect them?
If I understand correctly, you are replacing a switch that has a black and red wire?
And your new switch has 2 black wires + green wire
The green is color-code for ground, and it always connects to bare ground wire.
The switch wires are not color-coded (both are black) so they can connect to either of the two wires that came off old switch.
If switch does not operate, they try reversing the two black wires.
As a general rule, the wires inside your box are color-coded.
The color-code information says:
The black is the Hot from breaker box. This wire carries electricity from the breaker to the switch.
The red wire goes to Load (fan, light, motor). This wire carries electricity to the Load when you turn ON the switch.
Oct 23, 2010 | Solar Leviton Decora Sureslide Dimmer...
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
I got a car stero with a cd player, the one I am taking out was
THe speaker wires from "new" radio will be in pairs ie;GREEN/ RED/ GREY / , They look like they are the same color but you will find a "tracer color" on one of the paired wires, ie plain GREEN / GREEN with a thin black stripe etc. The single Red will be Battery power the Orange will be Ign / accessory for the radio station memory. the other wires will vary but should be (possibly) panel illum/ power antenna/ aux power and ground wire . The radio will ground off the antenna connection .but should be connected at a later time . good luck .
May 03, 2010 | 1998 Chevrolet Lumina
Replace 3 way dimmer but different color wires how to connect?
you will want to make the following connections
existing-black wall to black dimmer now connects to red dimmer
existing black wall to red dimmer now connects to black dimmer
existing red wall to black dimmer now connects to red dimmer
Green wire connects to bare copper wires in wall
Apr 26, 2010 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
The wall switch that I am replacing, with a 3-way dimmer switch, has 2 black wires, 2 red wires and a green wire. The new 3-way dimmer switch has 2 red wires, 1 black wire and 1 green wire. Question: How...
Ok the RED is Phase and the Black is Neutral... Green is Earth. you have an IN, Red wire, and an OUT Red wire, the rest just go color to color. So in the socket, one Red wire goes to one Red wire from the dimmer, the other Red wire in the socket, goes to the other Red from the dimmer, then Black to Black, and Green to Green. Be careful do NOT work on it live.
Feb 26, 2010 | Lutron DVW-600PH-IV Slide Dimmer with...
Kenmore model 110 ele dryer has 3 wires giong into outlet but outlet is going to be connected to a 4 wire supply. red black white green which color is hot what color is ground how do i connect the...
This sounds like you should call an electrician, or someone that knows wiring. Red and Black are both hot, White is neutral, and Green is ground. Remove the ground strap from the center of the terminal block to the case. Put green wire to the case, white in the middle, and red or black to either side. Your last question I do not understand. But it sounds like you need an electrician to connect a 4 prong receptacle, with the proper 4 conductor wire to your breaker box.
Jan 01, 2010 | Kenmore Dryers
Wiring electric oven
Hi, yes connect red to red, green to green, black to black, black is neutral, red is live and green is ground, which means you're using 220 volts.
Aug 08, 2009 | Kitchen Ranges
Amana dryer, changing out the electrical plug from 3 to 4 prong
For example; Green wire goes to green screw on machine. White in the middle, red on left, black on right. (observed small color coded wires connecting in back-ground as well.)
In general, each color should match. Meaning, white with white.
Jan 27, 2009 | Dryers
Need to change the cord on my Maytag MDE6000AYW from 3 prong to 4 prong. The (4) prong cable has black, white, green, red cables. Which colored cable connects to which terminal inside the dryer?
BLACK and RED are 110-120VAC each. WHITE is NEUTRAL - does not carry power. GREEN is GROUND. The Black, Red, and White Wires should connect to the terminal block & should correspond the colored wires already connected to the block from the machine. The Green wire should be grounded to the equipment chassis. I hope this answers your question.
Jul 13, 2008 | Maytag Dryers
I have to change the power cord of my dryer. the new power cord has 4 pronge. the 4 wires colors are red,white,black and green. on the dryer i have only 3 wire: red,blue,black. i want to know witch wire...
  • green = ground (attach directly to the case, should be a green painted screw near the opening
  • red = hot 110v connect to the red on the dryer
  • black = hot 110v connect to the black on the dryer
  • white = neutral connects to the blue (only if the blue is in the middle)
  • neutral is always in the middle with a hot wire on either side of it.
  • also make sure all the connections are tight
let me know if you need more help Mike
Jul 01, 2008 | Dryers
Kitchen Ranges Logo
44 people viewed this question
Top Kitchen Ranges Experts
Craig Butler
Craig Butler
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
