Hello, can you pls help me about my laptop of which when I turn it on to start it, there is a prompt that will appear on the upper left of the monitor that says ILCSU is compressed Press ctrl+alt+delete to restart. When I do that it goes back to the same prompt again and again.
    Guru:
  • 846 Answers
Repair your windows installation using your Operating system disk.
This video will help you
Posted on Nov 07, 2010
How do i unlocked my mini laptop?because its accidentally i locked.canyou pls help me?
You will need to factory restore, this will lose any stored data!
Start the Acer Aspire One's operating system. Wait for the Acer logo to appear on the LCD screen.
Press the "Alt-F10" keys at the same time to bring up the recovery menu. Press "Enter."
Click "Next." Follow the prompts that appear on the screen to restore the operating system back to factory settings.
5
Use the drop-down boxes to select the time zone and language information for your Acer Aspire One. Restart the netbook when you are prompted to finish restoring the computer.
Dec 27, 2014 | Acer TravelMate Computers & Internet
Msi netbook
If you press F8 just before the boot starts, select repair and follow the prompts,
Feb 20, 2014 | Computers & Internet
I need to reset tecra m2 to factory settings, 0 option does not work or f8 pls help??
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Apr 09, 2013 | Computers & Internet
I install some games in my computer called "iDate"
everytime i open idate ..message box pop in the left top of laptop it says "critical error" how can i fix it ?? :( i really want this game ..
Mar 25, 2011 | Microsoft Windows 7 Home Premium 64BIT...
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
On my Windows XP laptop I cannot get the wireless to work. All it says is "limited or no connectivity" when it connects. I have tried a million things, and nothing works! What can I do?
Disconnect your laptop wireless connection from the wireless acess connection. (Reboot your laptop if necessary). Then reconnect your laptop wireless connection, if your wireless network is a secured wireless network, your laptop will prompt for a network key ie your wireless network SSID password. Make sure the network key correctly entered ie.("Most wireless password keys are Upper or Lower case sensitive")
If the problem persist, then use the "Command Prompt"
Start ->"Run" ->Type "CMD" ->The command prompt will appear, then type ie without the quotes,
1. "ipconfig /release" -> enter
2. "ipconfig /renew" -> enter
3. "ipconfig /flushdns" -> enter
Hope it helps.
Nov 17, 2010 | Microsoft Windows XP Professional
Hello , i have a Acer aspire one and i have wireless problems. I cannot connect to a network ... and even on cable it does not work. My wireless finds the network but just won't connect. if i try to...
Your 'autoconfiguration' settings have been changed.
Do this......go to the start menu and type 'services' in the search bar and press enter.....when the window pops up showing the services, make sure that the left column is focused on 'services'
now, scroll all the way down on the middle column and find the services labeled; 'WLAN Autoconfig' and 'Wired AutoConfig'
These should be set to automatic.
to do this, simply double click the service, and select 'automatic' in the 'startup type' drop menu.
you may have to click start on the left upper portion of that window, but next time you start your system it should automatically search and connect with a valid ip
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Nov 16, 2010 | Acer Aspire One AOA150-1126 Notebook
Hi, i want to reset a bios password on Acer extensa 5220. Taking out the cmos battery didn't help. Thanks
The bios is accessible by pressing F8 (IF Windows) after starting your computer.
Oct 06, 2009 | Acer Computers & Internet
AFTER FLASHING MOBILE DEAD POWER IS`NT ON.
It sounds like you've had problems writing a custom ROM to your phone. You have done it correctly using the CID unlock. Are you using the same WM6 ROM that you have done before?
Firstly, turn off your XDA Orbit.
Then hold down the voice recorder button on the left side of the phone
Then press and hold the power button on the right side of the phone, whilst still holding the voice button on the left.
This should get you into "bootloader mode" which will display a screen with red, green, blue and white stripes - yu should now be able to instlal your ROM using the RRU from the computer with USB connection
If that is not possible, you can install the ROM from a microSD card if you first format the card into Fat32 file system from your computer, then copy the NBH file from your ROM to the microSD card. You will need to rename the NBH file from the ROM to ARTEIMG.NBH for this to work.
Enter bootloader mode and you should see a prompt to press the volume button downwards to start the ROM installation process.
See this page for more information on the MicroSD ROM installation:
http://wiki.xda-developers.com/index.php?pagename=Artemis_SD_Card_Flashing
Nov 09, 2008 | O2 Xda Orbit Smartphone
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
