Question about Garmin zumo 550 GPS Receiver
When i turn the unit on the only thing that happens the screen come on the bar does not move like is doesn't know what to do. i push the reset button it stay the same. this a x3-03 unit. new garmin zumo 450 has a dead bettery that will not take charge from wall unit. A blur screen appears briefly and then the unit shuts down. I have tried repeatedly to charge the unit.
    Genius:
  • 1,847 Answers
May i have the make and the model no#
Posted on Jun 15, 2008
I have a GE photophone Model #TC27956FE1-A. I had photos on it and I unplugged the phone to move it to a new location. Now I cannot get the pictures or the caller id to work. I have just a blank screen...
You can try pushing the reset button on the back of the unit. I have one too and the same thing is going on with mine but the reset does not work for me. I think the unit is of low quality parts and it is most likely dead as far as photos are concerned. Hope this helps.
Jun 14, 2011 | Health & Beauty
Palm life drive frozen on "palm one "screen
When you see the first screen (the orange one) hold the UP button as the bar moves across the bottom of the screen. Let go right before the screen goes to the silver logo. If it continues and opens Prefs, then you need to delete the program causing it to reboot. If that doesn't work, do a Hard Reset. A Hard Reset will erase everything on your lifedrive, so only do it if you have to. Hold the Power Button while you push the reset button. Continue with the instructions to finish erasing your device.
Feb 17, 2010 | Palm LifeDrive Handheld
Screen changes colors only
Hold the Vol+ Vol- buttons down and turn on the power switch in the back of the unit.
The screen should turn blue and some square in the middle of it.
The noisy square is actually the bios being reset.
Once the unit turns itself off, you can turn it back as usual.
Note: Some of these units require a 3 button reset.
In that case hold Vol+ Vol- and Menu at the same time while you turn the power switch on in the back of the set.
I hope it was helpful.
Jul 07, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
Frozen
press the MIDDLE BUTTON and MENU button at the same time
or
press PLAY and the MIDDLE BUTTON at the same time till you ipod resets
Jul 02, 2009 | Apple iPod mini 2nd generation MP3 Player
Touch Screen on my Garmin doesn't work
I believe simply pushing the reset button will fix your problem. The reset is located under the frame around the screen. To remove the frame, use your finger nail to carefully lift it off the screen. Then just push the reset button and you should be back in business.
please rate my answer as a fixya! Thanks.
Feb 14, 2009 | Garmin nuvi 200W GPS Receiver
Signal
First thing ensure that the TomTom is fullly charged using the home charger.
Press the small reset button on the base (700) or do a factory reset.
The other thing to try is tap the GPS signal bars to go to the configure and check in the top right hand corner there is a circle with yellow and black esgments if this is moving then your TomTom is looking for a signal. Move around and you should find that the bars at the bottom will start to move and the small screen on the right will start to indicate circles. When the bars start to move you are getting GPS signals when the bars change to blue there you have a coordination for your position. Some areas are worse than others so move out of your house if after doing above does not get a signal
Aug 14, 2008 | Tomtom ONE 3rd Edition GPS
HP Pocket Pc won't turn on
I assume you have already tried a reset with the stylus in the hole in the side of the unit, if not try it.
if you want to try to hard reset. (this will reset to the settings it came from the store with). Try one of these two techniques.
1. hold the power button while inserting the stylus into the reset hold until the screen flashes.
2. hold the power, calendar, and email button while pushing the stylus in the side/bottom of the unit until it resets.
Jan 28, 2008 | RIM BlackBerry Pearl 8100
Magellan 2200T won't completely boot up
Reset unit, and then turn off, but hold power button for at least 10 seconds, then power back on, and when ever you turn off unit, hold power button for 10 seconds, had the same problem with mine, this solved it, it seems that just turning off the unit till screen shuts down puts it in a sleep mode. Hope this solves your problem.
Dec 18, 2007 | Magellan RoadMate 2200T GPS Receiver
Doesn' t turn on
reset the device by pushing the reset button near the plug on the bottom of the unit , then it will come on i presume you upgraded by the internet you need to use a paper clip to reset the unit
Sep 25, 2007 | Tomtom GO 700 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
63 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
