Question about Frigidaire Ovens
My oven is not ligthing up - Frigidaire Ovens
  • Frigidaire Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Nov 07, 2010
Blomberg BEP 906. After power went out a couple
Hello.
When baking or cooking common foods in your oven, it is important that the oven heats to the proper temperature. Otherwise, the food in your oven could become over- or undercooked. The electric ovens are able to be calibrated if only slightly off, however, if the temperature is 25 degrees off or more, you should replace the oven sensor. The oven sensor is the device in the oven the detects the temperature. The control board increases or decreases the oven temperature, depending on the oven sensor reading. Before calling a repair technician, attempt to calibrate your oven or change the oven sensor.
Instruction
1 Turn on the oven and set the temperature to a medium-heat setting, such as 350 degrees.
2 Allow the oven to preheat and then open the door and insert the oven thermometer.
3 Allow the oven thermometer to remain in the oven for a few minutes and the look at the temperature reading, comparing it to the oven temperature setting.
4 Recalibrate the oven if the temperature is only slightly off, or replace the oven sensor if the temperature is greatly off, such as 25 degrees or more.
Calibrating the Oven
1 Turn off the oven to prior to calibrating.
2 Press and hold the "Bake" button until the calibration settings are displayed on the display.
3 Use the arrow buttons or "+" and "-" buttons to adjust the temperature the number of degrees that the oven is out of calibration.
4 Press the "Start" button to save the calibration settings.
Replacing the Oven Sensor
1 Unplug the oven from the wall or cut the power to the oven in your breaker panel.
2 Open the oven door and remove the oven racks.
3 Locate the oven sensor, located at the top-center of the rear oven wall.
4 Remove the mounting screw securing the oven sensor to the wall and then pull the oven sensor away from the wall.
5 Remove the cable connected to the terminal on the rear of the oven sensor and then discard the oven sensor.
6 Connect the cable to the terminal on the new oven sensor and then reposition the oven sensor and secure it using the mounting screw.
7 Replace the oven racks and then restore power to the oven.
Thanks.
Dec 23, 2011 | Ovens
When you turn the temp knob the light will come on the panel but the oven will not light. Stove works fine. We have had this unit for 12 years. Thanks Bob.....
can you hear gas coming in when you turn the know to "ligth" if not the you may have either a bad gas valve or the safety feature has detected something wrong, and has shut the gas off to the oven. first determine if you do indeed have gas., how does the oven light, is it pilot lit, or does it have a glow plug, if its pilot lit, make sure the pilot is running. if its a glow plug, you should be able to see it glow when you turn the oven on, if its not glowing it has to be replaced (or maybe the wiring has gone bad). either way that's where to start.
Mar 19, 2011 | Ovens
I can't get the stove to heat up! The pilot light is on and the burners all work
check the bottom pilot ligth in the boril at the back to the top that poilt ligth it for the ovens
Oct 18, 2010 | Ovens
I hVE ligth bulb that broke off in the oven how
I usualy use needle-nose plyers, but have herd that you can use a potato to shove it in the socket and turn the broken bulb end out. Make sure you unplug the machin first.
Jan 11, 2010 | Ovens
Oven not getting hot but oven fan ligth working
If it is a fan assisted electric ovenn, and the fan is working o/k, then you need to replace the oven element, usually located at rear of oven compartment.
Please rate my solution.
Thanks.
Nov 14, 2009 | DeLonghi Ovens
Jenn-air model s176w-c oven
You have a fault in the controller module. I suspect a bad power supply capacitor is feeding dirty voltage to the control electronics.
Unplug the range, then open the control panel (usually you get into it from the back). Remove the control module (warning: handle it only by the edges to prevent damaging the circuitry with static electricity from your fingers). You may not have to disconnect everything at this point; you just need to see the component side. Look for any electrolytic capacitors that have a domed top instead of a flat top. Normal is flat top; domed capacitors are burned out. Also, if you see a smaller electrolytic capacitor that has obviously had its can enclosure pushed off the base, that would be bad. See the photo for a comparison of bad (marked with red boxes) vs. good capacitors.
These capacitors are relatively inexpensive to replace, usually less than $1.50 US from on-line sources. I recommend using the Panasonic FR series as the most reliable replacements. It should be much cheaper to pay a TV technician to put in the parts than to buy a replacement controller. Note: if this is what you find, and you want to take the module out for service, first go to a computer parts store and beg an anti-static bag from them. Make sure it's big enough to hold the controller including the keypad (keypad connectors can be tricky; if you don't know how the latch on the connector works you can damage the connector or keypad cable, so leave it attached and let your technician worry about it). I don't have the service info for your model, so I wouldn't know what kind of latch it uses without seeing it. Again, handling the module only by the circuit board edges or whatever mounting frame it is in, place it in the antistatic bag for transport. DO NOT USE AN ORDINARY PLASTIC BAG; these generate static charges instead of protecting from them.
Jul 10, 2017 | Jenn-Air Ovens
My vulcan burners lit but I can't get the OVEN pilot to light . What are the steps to light the oven ?
use matches,the pilot ligth is hard to replace unless in the tecnician can do,and hard to find the parts.
tnx.gerbee
Jul 04, 2009 | Vulcan GCO2D Gas Single Oven
The oven is thermador ct227ncprs01
if the heating ligth is not coming on it will be must likely an exaust problem either the sail switch is bad or it has a bad fan exaust motor.
Mar 18, 2009 | Ovens
No power to oven
No watvto know about the fuse without a model #
Nov 04, 2017 | GE JTP27 Electric Double Oven
Ovens Logo
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
