Question about Sanyo SCP-2700 Cell Phone
My keyboard is unreponsive. Is there anything that can be done for this, or does this mean I need a new phone?
    Sergeant:
  • 389 Answers
You more than likely need a new phone. Just take it to your service providers, and show them the issue with the phone, and they should trade it out for one that works.
Posted on Nov 07, 2010
I have 2 Kyocera 7135 smartphones, and each has a problem. 1. This phone will not select anything via screen/stylus interface. If you tap a designated space (e.g. [DONE]) it either fails to select it, or...
The first phone seems to have a problem with the keyboard is in need of replacement.
The second phone has a problem with firmware, and is not upgradable.
Cannibalize keyboard from second phone on first one.
Jul 24, 2008 | Kyocera Cell Phones
I have a microsoft keyboard that is wireless that will not work. the mouse works and the buttons at the top and side work that open up things like the calculator and put your computer in sleep mode but the...
If you say that yo bought another keyboard and it acts the same ..this means that the issue is not from the keyboard..If you also got a receiver for the second one ..and it still done the same after you pair it ..it means the the issue is in the operation system and it needs to be reinstalled..Probably it has some missing files that operates the keyboard signals..
If you have a recovery partition use it and make a recovery of the system to the factory settings ..after that run again the driver for the keyboard and pair it again and will work ..
During the installation use a normal wired keyboard cause the communication its ending during the installation for the wireless ones..
If you do not have a recovery cd ..(or you have one just with the drivers ) you will need a boot-able one with the operation system ..and do not forget to save the important files to another partition from the C drive (my documents too) cause on all installation processes the C partition is formatted and you will loose them ..
Dec 28, 2010 | Microsoft Wireless Keyboard / Optical...
I've got the Blackberry Curve 8520... Yesterday the 'ALT' key got stuck, and wouldn't come off, so i done a battery pull... but when i turned it back on, most of the keys didn't work.... so i cleaned the...
Yes, your never suppose to put it under heat to dry, nor put any type of spray because spray obviously contain water, which kills your phone. So, if even the battery isnt orange indicating 'water damage', the keyboard itself is damaged. If possible, which is the best solution: you should call your cellphone provider and tell them that your phone all of a sudden stopped working, and most likely they will look into getting you a new phone. But dont tell them what you did, because they wont do anything about it after. Also, connect your phone to Desktop Manager on your computer and back up on all your information (phonebook, bbm contacts, ect.) so nothing gets lost, if anything was lost.
Good luck,
sp
Aug 16, 2010 | RIM BlackBerry Curve 8520 Smartphone
Turned on computer screen had black background with yellow lines.Then turned off turned on said no signal
certainly graphics card related, and usually means that the graphics card has become unreponsive. Likely causes include:
- Overheating.
- Overclocking.
- Insufficient Power
- Hardware failure. .
Nov 10, 2009 | Gateway GT5220 PC Desktop
Keybord layout
Have you tried reseating the keyboard? This means you need to remove the keyboard, pull the keyboard connector off the motherboard and then reseat the connector. If this does not work, sounds like you need a new keyboard. Spill anything on it lately? Is it dirty, full of crumbs of food?
Apr 01, 2009 | Dell Inspiron 6000 Notebook
My blackjack's keys wont work
First off, how do you know it's the keys, rather than something else? More details are always helpful. An important question is, can you see or hear anything at all, by any means? If someone calls you, does the screen light up?
If you see incoming calls, but can't answer them because the keys don't do anything, then I'd ask if the phone might have the keyboard locked. You'll be able to tell because you'll see "Unlock" in the lower left of the screen when someone calls or you press the power button (top left edge, above the screen). If it's locked, pressing the "..." button to the left of the wheel will tell you how to unlock it (just the "*" button down by the "0" button on my Blackjack).
If you don't see anything when someone calls, you might want to figure out if the phone is working at all.
A couple of ideas (sorry if any of these seem obvious - it's bad form to miss simple solutions):
1. Is the phone powered on? You can turn it on by holding down the power button (top left edge, above the screen) for several seconds. If you make it to 10 without the phone coming on, then it might be the screen, the battery, or the phone itself.
2. Is the battery dead? Try plugging the phone in and then holding down the power button, as above. If it still won't work, try removing the battery, then plugging it in and doing the same thing over again. When you plug the charger in, you should see a Duracell-like image on the screen, even if the phone is turned off. If you still don't get any sounds or anything on the screen, it sounds like the phone has serious trouble - probably needs professional help.
3. If you hear sounds ("swooshing" on mine) when you turn it on or off and the keyboard lights up, but don't see anything on the screen, it sounds like the screen might be bad - probably needs professional help.
4. Finally, you could try connecting it to your computer with the sync cable. I haven't done that with mine, so you'll have to read the instructioins, but it might let you know that the phone is working internally, but having communications problems through the keyboard and/or screen. If that's the case, you can try fixing it yourself or get an estimate from a professional. Good luck!
Mar 29, 2009 | Samsung BlackJack Smartphone
Microsoft wireless comfort keyboard 1.0A
Check if there is anything stuck or jamming the button before buying a new one, but i think it is likely you'll get a new one. Because sometimes the key won't work, as somthing is preventing the trigger.
Sep 02, 2008 | Microsoft Multimedia Optical...
Handset is lit up but unresponsive
posible or you need to intial reset the whole system completly make sur all your hand set indicate on the base make sure the power is reading ok
Aug 31, 2007 | Uniden TRU8885 Cordless Phone
Sanyo SCP-2700  Cell Phone Logo
62 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
