Question about Epson Stylus Photo R200 InkJet Printer
Epson R230 top 2 lights are flashing red paper jam button and ink button but no green button cannot get the printer to start again. Can anyone help??
  • Jimmy Cush May 11, 2010
    Are you using bottomless system to your Epson R230?
If that is the case?
Here is the solution.
Ask your reseller to give you a reseter software.
Maybe because the printer exceeded to it duty cycle.
Duty cycle is printouts maybe about 5000 printouts
Posted on Jun 15, 2008
Epson R230 with green led and red led blinking
This is general error of the printer. When you have to change the new mother board you should be initialized it then it can be ready mode. When you try to initialization you need printer printer adjustment program. You can batter find out from google & write down EPSON Stylus R230 Printer Adjustment program or ink reseat program.
Jun 12, 2013 | Epson STYLUS R230 InkJet Photo Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My r230 is having this trouble: the two red lights are blinking.
If the Ink Out light flashes, the printer is getting low on ink; if it is on solid, the printer is completely out of ink and you need to replace the cartridge; if it is flashing rapidly, the printer detected a print head unit or ink cartridge installation error. If the Paper Out light is on solid, you need to install paper in the printer; if it is flashing, the printer detected a paper jam. When both the Ink Out and Paper Out lights are on solid, the printer thinks that there is a carriage error; if both lights are flashing, there is a fatal error and the printer will need to be sent in for service Source(s): http://www.epson.com/cgi-bin/Store/suppo...
Mar 06, 2011 | Epson STYLUS R230 InkJet Photo Printer
Two red lights are blinking simultaneously...I check if there is any paper jam but i don't see anything. anyone can help me would be much appreciated.
first have you checked any clogged papers? have you checked ink cartridges if yes continue doing the following
Before run adjustment program or software resetter Epson Stylus Photo R220 and R230, set date setting in your computer to 12 January 2006. Appearance of adjustment program Epson stylus photo R220 and R230 like adjustment program for Epson C45. Your Epson Stylus Photo R220 and R230 must be installed correctly in your computer before using the software otherwise so this software resetter will not be used.
Here how to use the software
  • Download and extract downloaded software and run it.
  • Click accept button.
  • Set model name, port selection and destination setting and equal to your printer.
  • Click Maintenance Tab.
  • Check mark waste ink pad counter.
  • And the clear the protection counter (reset counter to zero)
  • Then click Ok, Ok
  • done
download link:
http://www.mediafire.com/?9njmgwlxqgj
Nov 10, 2009 | Epson STYLUS R230 InkJet Photo Printer
Epson r230
Nov 02, 2009 | Office Equipment & Supplies
Printer EPSON R 230
problem about flashing red is solved using SSC ver 4.20 to solve the waste ink.
http://www.ssclg.com/epsone.shtml
Oct 29, 2009 | Epson STYLUS R230 InkJet Photo Printer
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson stylus 880 printer
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons", then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Oct 08, 2007 | Epson Stylus 880 InkJet Color Printer
Epson Stylus Photo R200 InkJet Printer Logo
197 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
