Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a husqvarna 141, I can start it and it will fast idle. When i kick the high idle down it stalls.
  • 7,733 Answers
Remember taht when you start to cut you need to pull back (towards you) the upper handle this will automate the full trigger for logging.
Posted on Nov 07, 2010
I had to change body chassis on husqvarna 240 chain saw, put back together and started once, then died,now won't start and gas comes out muffler. What did I do wrong
The unit is definitely seriously flooded. Dry the unit out and try to restart. Do not pull the starter rope more than 3-4 times with unit on choke. Kick it back to fast idle to start. If it floods again, recheck your fuel lines to make sure they are correct.
Mar 30, 2017 | Husqvarna Garden
What is carburetor setting on a2.3 chainsaw
There is no fixed carburetor setting on these engines, just two screws to adjust low-end and high-end operation. Special tool may be required, there are about a half-dozen screw head standards. Check eBay for tool. Get the engine to run and idle fast (idle adjust) so it doesn't stall, adjust low-end screw so that engine doesn't hesitate or sputter when accelerated. Adjust high-end screw to run fast and smooth on full throtle. Readjust idle to normal.
Oct 28, 2013 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My e series 142 spins the chain and idles insanely fast when I have the choke pulled out. Then when I give it throttle it calms down and then I can barely keep it idling. with throttle all the way pulled...
Check air filter- clean or replace, Make sure you have fresh fuel, A new spark while you are giving it a service, Do you know how to tune the saw? Start with basic settings 1 turn on the low and 1 turn on the high And adjust from there, You might have turned the idle up too high. The choke should always be fully in when saw is running. Hope this is a good start
Oct 04, 2013 | Husqvarna Garden
My husqvarna 141 will not start??
Very unlikley to be an air lock, more likley to be a massive air leak, check the rubber induction tbe behind the carb mount it may have split, if not then a possible blown crank seal.
Feb 13, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
I have a series 51 husky saw. it starts and runs normally until it gets up to operating temps. then it stalls out and either refuses to restart or just won't restart until it cools down again....
sounds like air fuel mixture screws are out of adjustment..start with the on marked (L)..this is the low speed(idle) adjustment...turn it in all the way just until it stops..but be gentle..then you wnat to turn it out 1 1/2 turns as a starting point..start the engine and adjust it until you get a smooth idle...next, with the saw running, pull the trigger and you should have a smooth response from slow to fast...you can adjust the (H) screw until you get good high speed operation...if these adjustments don't fix the problem thenm yoou may need to have the carb rebuilt( a carb kit is usually only 15-30 dollars)
May 09, 2011 | Husqvarna Garden
2 cycle engine speeds up then stalls
1 turn out is approximate setting fo H and L screws...once running adjust H screw so that it is just rich at full throttle (4 stroking then 2 stroking with out changing screw) once thats right adjust L screw at idle till it starts to pick up speed then just back off 1/8 of turn ....then you can adjust tapered screw to nice idle....if this fails you have carby problem
Jul 26, 2010 | Husqvarna Garden
I have a new hasky 460 rancher stalls when given
If it stumbles at full throttle, the fast (high) idle screw is set too rich. Using your owner's manual, locate the high idle adjustment and back it off in very very small increments. Do this until the saw will run wide open without stumbling.
Jun 06, 2010 | Husqvarna 20" 60cc Rancher Chain Saw 460
1993 Ford E-350 Fuel issue
Have you hooked a fuel pressure gauge to it?
Mar 15, 2009 | 1996 Ford Club Super
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
269 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
