Question about Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge
Spa has been off for about 6 months, due to short in element. and blew breaker. Changed element but pump wont start now and temp on controller keeps flashing and changes temp readouts up and down but pump wont start and temp wont stop in one spot. Any ideas ? Balboa VS Series control with waterway pump and control
    Problem Solver:
  • 9 Answers
I suspect the motor shaft has rusted in place. Remove the pump and try to free the motor shaft. If there is rust around the shaft spray in some wd-40 and let it sit a while.
At the far end of the pump is small cap which pries off. Inside there is a slot on the motor shaft you can use to turn the shaft with a large screwdriver.
Once the shaft can turn reinstall.
Posted on Jan 27, 2011
Intex spa pump wont run have cleaned flow sensor changed water changed filters have only had three months
check fuses if on while empty bad temp sensor heater element and high limits popped
Sep 03, 2017 | Intex Pool & Spa
Blew a hose and now the gfi breaker wont stay on,will stay on when i unplug pump to genius 3000 spa manager
need to test pump possible damage -- short --bearings seizing or binding--open winding s ---the pump is either pulling to many amps in an attempt to start or has a short causing the gfi to pop
Sep 22, 2016 | Arctic Pool & Spa
The pump shorts out when heater is put on
Electric spa control?
what do you mean pump shorts out? Are you saying a breaker trips or a GFCI trips?
if so, it has nothing to do with the pump, if it's already running. But once the heater engages and the breaker trips, then you have about heater element.
Mar 28, 2015 | Pool & Spa
Signature Titan II keeps tripping the breaker
check to see if recirculation pump is working if so check to see if heater element is not shorting out
Jul 13, 2014 | Qca Spas Jewel Series Topaz Plus Hot Tub
An Emerald Spa 1998 keeps tripping the breaker
with power off take cover off control box remove heater element lead make sure to take a picture or a drawing to see where they go back turn on breaker with wires taped up if it doesnt blow breaker you need a new heater element
Jul 10, 2014 | Qca Spas Jewel Series Topaz Plus Hot Tub
Breaker for hot tub keeps tripping
Leaking heat element.
2 GFCI on same circuit.
Rat-chewed wire. Inspect wiring.
Nail through wire.
Melted wire nut in junction box.
Undersized wire and breaker has been overheating breaker, and breaker has gone bad.
Shorted breaker. Move wires to different same-size breaker.
http://waterheatertimer.org/How-to-wire-GFCI.html#2-pole-gfci
http://waterheatertimer.org/Color-codewire.html
Apr 21, 2013 | Pool & Spa
My spa depot hot tub keeps popping the breaker
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
What type breaker?
GFCI or ordinary heat-rated breaker?
Do NOT use two GFCIs on same circuit.
Spa needs GFCI to protect people while immersed in water.
You might have dangerous short, or leaking element, bad switch, bad wiring, bad electrical connection, or undersized wire and breaker.
If breaker is undersized for load, it can get loose on the busbar and then start arcing, and then tripping. Use nose to smell for burning. Feel breakers to see if they are warm. Move wire to different same-size breaker.
Mar 18, 2013 | Pool & Spa
Watkins vanguard spa will not heat
bad heater element if ok bad recirculation pump
Aug 21, 2017 | Pool & Spa
Control flashes oh
This code is for an OverHeat situation.
This could happen for a number of reasons. The most likely are either a clogged impeller inside the circulation pump, or a clogged cartridge filter.
Even if the filter looks clean, they only have 6 months recommended use in a residential hot tub before invisible debris start to clog them. Once the filter is clogged, the flow of water is greatly reduced. Once the water flow is reduced, the water flowing through the heating element starts to OverHeat due to being in contact with with the heater for too long.
Cut the power to the spa off, remove the filter element, reapply power to the spa, and check for the code. If it does not reappear, simply get a new filter element.
If the code reappears, clean out the pump impeller. and reset power again.
As a last resort, you might have to check the thermistor. Its rare, but a thermistor can fail and show a false high temp reading.
If you need more assistance, contact me @ adamh@newconceptchem.com
Feb 23, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
I am experiencing a small problem. My pump motor does not operate consistantly all the time. There are times when the controls sends a signal for the motor to start-up. You can hear the HUMMMM of the...
Most likely you received the Hi temp signal, because you had no flow due to the pump stopping. You could have a problem with the control system for the pump motor, or the motor could be having problems. If this motor has a capacitor, it could be failing causing the motor not to start. The bearings could be going bad, and that's keeping it from starting.
Jul 10, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Waterway Spa Pump Executive 56 Frame 4hp Dual Speed 2" Intake 2" Discharge  Logo
223 people viewed this question
Top Waterway Garden Experts
Ian Kime
Ian Kime
Mike Raino
Level 1 Expert
john h
Are you a Waterway Garden Expert? Answer questions, earn points and help others
