Question about Whirlpool LER4634J Electric Dryer
What could cause no power supply to my dryer - Whirlpool LER4634J Electric Dryer
  • Whirlpool Master
  • 43,501 Answers
There are a couple of things...
First check the circuit breaker in your electrical panel....even though it says it is on turn it off and forcefully slam it on again...
Next thing would be to check the wiring in the outlet and plug...these wires can heat up become loose and then not make contact. If the outlet or the plug looks burnt or is brown at all replace both the outlet and the dryer cord....
Next check the wiring at the dryer....same thing... look for brown or burnt wires...replace the wiring as needed....
Make sure to turn off all power before checking anything!!! Electric can be deadly!!!
If all of this check out then the problem is internal in the dryer...of course using an electrical meter can make the job much simpler.... the power can then be checked at each stage...a meter can be purchased at many dept. stores or Walmart for around 20 bucks....
Set the meter for an A/.C voltage setting of greater then 240 volts.... the reading across the two hot lines should be at least 220 volts...be very careful when trying to get these readings on hot wires...
Heatman101
Posted on Nov 07, 2010
Cloth not dry
Check for a build up of lint in the exhaust duct, an excessive build up will block air flow.
Also 220VAC electric dryers use different legs of the electrical supply. (two 110VAC legs tied via a common neutral make 220 VAC) One 110VAC leg runs the motor and controls while the other supplies power to the heater.
It is possible that one side of the 220VAC has a blown fuse and is not supplying power to the heater element.
Other possibilities:
Blown out heater - requires replacement
There is a safety switch attached to the shaft of the motor. THis switch relys on centrifical force to close and is intened to kill the power to the heater if the motor and its attached blower stop turning.
If the motor is not turning fast enough of the switch is worn then it is possible that power to the heater circuit is not being completed. It doesn't take must of a speed reduction to cause a problem. Lint build up on the drum bearings can cause enough drag to slow the drum slightly. Combined with a worn/dirty switch and the switch fails to operate.
Finally there is a blower attached to the motor shaft. The blower is made of plastic and somtimes the blower comes loose on the shaft. Usually you hear a rattling sound or sounds after the dryer drum stops as the loose spinning blower spins to a stop. ( A tight blower stops with the dryer drum) A loose blower doesn't move enough air and causes your dryer to run longer.you can find about uniforms: https://www.mysocceruniform.com/customsocceruniforms.html
Mar 06, 2014 | Maytag Neptune MLE2000A Front Load Stacked...
When I press the button to start the dryer, the water intake starts. The unit is a stacked combo washer dryer. When plugged in and set to wash no water comes in. Only when the dryer button is pressed does...
Hello Julien, thank you for your inquiry!
Based on the symptoms you are describing it sounds like your laundry center is experiencing an issue with the power supply. Either the power supply is not connected correctly or it's an internal power supply issue within the unit. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Oct 19, 2013 | Frigidaire FEX831CS Top Load Stacked...
My dryer does not get hot
  1. Considerations
    • A dryer needs the proper voltage to produce the correct amount of heat. If your dryer isn't heating properly, it's possible that the power supply is the problem. Make sure that the dryer is firmly plugged into the outlet, and if you have a circuit breaker or fuse panel, check to make sure that everything is in working order.
    Theories/Speculation
    • Several things affect a dryer's ability to do its job. If an external source isn't causing the problem, then the dryer probably has a faulty part. Possible culprits include a damaged or burned-out heating element, a blown thermal fuse or damaged wiring, all of which will require replacing.
    Warning
    • The San Diego Fire-Rescue Department recommends having your dryer serviced by a professional repair person. If the problem is caused by something within your dryer's mechanism, you could make matters worse by trying to find and fix the problem on your own. With the exception of checking the dryer's external power supply, you should leave troubleshooting to a professional.
RATE THESE AFTER READING
Jan 15, 2013 | Dryers
My dyer does not get hot
  1. Considerations
    Warning
PLEASE RATE THESE SOLUTION
Hoover 0910dryer not heating. element replaced not long ago
Hi, the possible causes are: Possible Causes: The wall receptacle, power cord (plug) and electrical supply must be in good condition and wired correctly for the dryer to heat.
  • Supply Issue - Loose or missing connection on supply wire from circuit breaker.
  • Plug Issue - Loose or missing connection in the wall. Defective, worn or damaged wall plug.
  • Cord Issue - Loose, missing or incorrect connection of the power cord to the dryer terminals.
If gas dryer and does not heat, Gas Dryer heats with a gas burner, make sure the gas supply line valve is open.
Also, for electric dryer,
Electric dryers require two 30 amp breakers or fuses in the house electrical box to run and heat. If one breaker is tripped or one fuse is blown, the motor, the timer and lights can work but the dryer will not heat.
May 01, 2010 | Washing Machines
Not drying clothes completely
Jul 19, 2009 | Estate Dryers
No heat on Whirlpool leq8000jq1. Is it just the heating element?
There are several things that could cause this problem, here are a few common things it could be, before doing any checks you should always make sure you disconnect your appliance from it's power source.
  1. bad heating element, you can check the heating element for continuity with an ohm meter.
  2. bad thermal fuse
  3. faulty power cord
  4. bad thermostat
  5. tripped breaker or blown fuse from house power supply, check to see if you have 240 volt supply to your appliance.
Mar 15, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Hot leg of power supply cord melted
This is almost positively caused by a poor electrical connection. If the connections at the cord to the dryer are good and tight, check the receptacle that the cord plugs into. Turn the breaker off, remove cover or receptacle, and tighten all connections. If necessary, replace the dryer receptacle along with installing a new cord.
Dec 11, 2008 | Dryers
Dryer Cord melted....
The power cord overheats and melts due to a failing power cord receptacle (the contacts loosen over time). To correct this problem, the receptacle and power cord should be replaced.
Jun 18, 2008 | Dryers
Does any hotpoint dryers have a reset?
BEFORE WORKING ON ANY APPLIANCE BE SURE TO UNPLUG IT TO KEEP FROM BEING SHOCKED OR DAMAGING YOUR APPLIANCE
possible cause
1.no power---check fuse & power supply
2.loose wiring---check terminals & wiring
3.door switch---make certain door is closed properly to actuate switch
4.defective motor-- check motor
5.defective timer--replace
May 26, 2008 | Hotpoint NVL333EY Electric Dryer
Whirlpool LER4634J Electric Dryer Logo
54 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
