Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
My fisher and Pykel active smart fridge model E33IT keeps beeping when i open it.??? i have no instruction manual.?
SOURCE: Model E372b Fisher & Pykel - Beeps with Fridge Door closed periodically-Higest shelves warm lower down freezes things
First I would like to say thanks for all the information on the Fisher-Paykel active smart fridge freezer problems. This was a lot more useful than their customer support help line… After a week of hanging on for ten minutes without any answer I had a look on the net and found your site with descriptions of similar problems so I decided to investigate further
I have a Fisher Paykel fridge freezer (model 402B in the UK) about three years old. Although it didn’t seem to be as cold as normal, the first sign of a serious problem was when it started making a rattling or knocking noise from the freezer compartment. Looking inside it was obviously iced up solid and the noise was probably the fan catching the ice. So first thing I decided to try was a days de icing after which everything seemed ok except the green indicator light was now flashing about once every second.
Two weeks later it was badly iced up again so the problem was still there. At first I suspected the fans (which I could never see actually working). I disconnected one and tried it with a 6v torch battery and it spun ok. It was then I realised what was happening - the fans cut out whenever the door is opened so they are always stopped if you look inside.
A closer look at the aluminium heat exchanger(behind the plastic panel at the back of the freezer section) showed there was some kind of heater element clipped along the bottom with feed wires at either side. Obviousely part of the automatic de icing systems. It’s a bit tricky but there an electrical connector plug at the top and disconnecting this enables you to unclip the element and remove it (except that in this case one wire had been trapped at the wrong side of the coolant pipes when they had been fitted so it had to be snipped to get it out). Once out a circuit test showed there was no circuit through the element. So cutting into the two shrouded connections at each end of the element revealed some little components inside which I now know are “Thermal fuses”. One of these had “Blown”. There was a number on the side: - DF 72S which Google revealed is a thermal fuse set at 72 degrees. Although these are listed as spares in all sorts of places non was convenient to the UK. So I found a similar component at Maplins Electronics (R14) set at 92 degrees for just 69p! The reasoning being that the other thermal DF 72S fuse was still ok and the slightly higher use temp at the other end would still blow before anything melted!
By the way you cannot solder these things in so its best to use miniature screwed “block” connectors plus a good covering with insulation tape.
After putting it all back together its now been working for a month and no ice build up… The green light did still flash for a while but went out once the temperature dropped too normal freezing level.
Total cost of replacement parts was under £1 but it took a bit of time find the problem.
Posted on May 12, 2008
  • 3 Answers
SOURCE: I have a Fisher and Pykel Fridge / freezer Active Smart
on reading the user manuals, it suggests actually calling the F&P customer service numbers and telling them the pattern of the lights flashing.
They can ?diagnose the fault from the light sequence and can then tell you what u need to have fixed.
Posted on Jan 08, 2008
  • 3 Answers
SOURCE: Fisher & Paykel active smart fridge keeps
press the select button ( the button that you choose the temperature on the fridge and freezer) and check that the fan on both fridge and freezer are working.
Posted on Nov 07, 2009
rickead1
  • 1998 Answers
SOURCE: Problem with Fisher & Paykel
so both the freezer and the frigerator are both warm then? If this is the case then you can try to remove the rear panel down where the compressor is leave machine off for about ten minutes then plug the machine back in there isa small box like unit or relay on the side of the compressor if your hearing it click on and off or if you disconnect the wires going to it and shake it lightly to hear if something is rattleing on the inside also if you have a multimeter and a pair of needle nose you can do this to test the relay
Remove the cover on the compressor relay box. The cover is usually held in place by retaining clips or tension clips. There are usually three components inside this box: the compressor relay, the compressor motor terminals and the overload protector. The compressor relay is the largest component and will either be wirewound or solid state. If the part is solid state, then you will have to have a professional test the part, as it requires specific equipment for testing. If you have a wirewound relay, pull it straight off of the compressor.
  • 5
    Use a pair of needlenose pliers to pull the connector off of the relay's terminal. Be sure to pull it off by grasping the connector and NOT the wire. Check both the wire connector and the compressor relay for any signs of corrosion.
  • 6
    After you dust the relay off, take a good look at it. You should see two plug-type terminals marked "S" and "M" and the slip-on terminal marked "L." Set your multitester to read ohms (usually the X1 or RX1 setting). Set the relay on a flat surface so that the "S" and "M" terminals are on the bottom.
  • 7
    Insert one probe of your tester into the "S" terminal and one in the "M" terminal. Your tester should have a reading of "zero" ohms. Keeping the probes inserted in the terminals, turn the relay over. You should hear an audible "click" and the tester's reading should change from "zero" to "infinity."
  • 8
    Turn the relay back over. Now, touch one probe to the "S" terminal and the other probe to the "L" terminal. The tester should read "zero" ohms. Turn it over again with the probes still on the terminals and the tester should read "infinity."
  • 9
    Turn the relay back over. Now, touch one probe to the "M" terminal and the other to the "L" terminal. The tester should read "zero" ohms. Turn the relay over with the probes still in place and the tester's reading should not change -- it will remain at zero ohms.
  • 10
    If your compressor relay passes this series of tests, then your relay is not the problem with your refrigerator. If it fails any one of these tests, then take it to an appliance parts shop and purchase a replacement. Replace everything back in its original position and be sure to remove the 20-ohm resistor from the capacitor before plugging the refrigerator back in.
  • note if you are unable to perform these tests please call a technician if you have any further questions please message me back as well as please remember to rate how this opinion has helped in your appliance repair all in all if your machine is warm its either the relay or the compressor Thanks again
  • Rick
  • Posted on Dec 02, 2010
    I had the same problem. The problem proved to be the defrosting element was faulty. The defrost is programmmed to activate every 12 hours or so, and if it does not happen the electronics detects any problem and sets the alarm. Replace the defrost element and everything is fine.
    Posted on Dec 04, 2010
    Why does my fisher and paykel active smart fridge/freezer keeps beeping when I open fridge? As if the fridge has been open for a long time?
    Does the beeping start immediately or does it follow the designed timing as stated on page 12 of the manual? You would have to check with the manufacturer to see if the feature can be disabled. Page 12 of Fisher Paykel Refrigeration User Guide ManualsOnline com
    Mar 08, 2015 | Fisher and Paykel Refrigerators
    I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
    Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
    Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
    Fisher & paykel active smart fridge not keeping cold
    Do you see any ice buildup on the back wall of the freezer or behind it?
    Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
    Fisher and pykel EcoSmart won't start
    You can find a service manual at the link below to assist in repairing your machine.
    Download the smart drive mw511 manual
    Link:
    Mar 10, 2012 | Fisher and Paykel GWL11 Top Load Washer
    Fridge beeping
    the beeping is an alarm certain lights on the display will be flashing when it is beeping record which lights are flashing this idicates a fault code then post your results and i will tell you what the fault code is and what the problem is likely to be :)
    Jun 07, 2010 | Fisher and Paykel Active Smart® E522BR...
    Fisher & Paykel active smart fridge keeps beeping for no apparent reason, while door closed
    Nov 04, 2009 | Fisher and Paykel Active Smart® E522BR...
    Fisher & Paykel active smart E521T
    I would reset the module. Open the fridge door, keep the freezer door closed, then press the mode button (located on the display panel. This will re initiate the electronics
    Jun 07, 2008 | Fisher and Paykel Active Smart® E522BR...
    Jan 18, 2008 | Fisher and Paykel Active Smart® E522BR...
    Dec 21, 2007 | Fisher and Paykel Active Smart E522B...
    Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
    74 people viewed this question
    Top Fisher and Paykel Refrigerators Experts
    Brian Coughlan
    Charles T Nevin
    Charles T Nevin
    Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
